swoki Posted January 22, 2007 Report Share Posted January 22, 2007 Hello there!this is Dinos, hailing from Athens, Greece... :)...so, I found this beatiful community, spent lot's of time reading the wiki, the forum, and ucapps.de... I ordered everything I needed (from Mike's shop) for a simple monophonic, MBSID (also, using a 2x20 LCD, some buttons and an encoder, as a control surface). I must admit that I had never, ever soldered a single joint in my life, so... this whole project is a challenging task for yours truly. I got access to a probably malfunctioning C64 (no PSU... so, I couldn't even test the SID chip...), and cannibalized an 8580 chip.Last Saturday, I started soldering the DIN module (it seemed ideal as a starting/experimenting point, since, even if I completely ruined it, I would be able to get sound out of my MBSID... I would just be left without a control surface). I think that I made it... :) (I don't have a way to test it at this point, though...)The next step was the CORE module, which I started soldering today... this is what my messy desk looked like before starting workingWell... problem is, that I messed the bridge rectifier placement, soldering it a little bit on the right hand side of where it was supposed to be... :-[, and lacking a desoldering pump, or something, I just stopped working on it until I get to buy one...I will keep everyone updated... :)cheers!(wish me luck!)(sidenote: as I said, I actually DON'T HAVE a C64 PSU, so, I'll have to figure a way out to power my thing... I've spent some time reading all relevant threads, feeling lost in subjects I have inadequate knowledge of, but I'm confident I'll work this out... :)) Quote Link to comment Share on other sites More sharing options...
Wilba Posted January 22, 2007 Report Share Posted January 22, 2007 Welcome!For a total newbie, that's great soldering. ;D A tip: when you get your desoldering pump, try sucking up some of the excess solder from those joints. A good soldering joint is a neat cone shape, not a blob.I strongly recommend a C64 PSU, this will save you a lot of time and is a "known good solution".Good luck! Quote Link to comment Share on other sites More sharing options...
moebius Posted January 23, 2007 Report Share Posted January 23, 2007 Welcome!If You don´t have a desoldering pump - I´d rather say, get a solder wick (braid) instead. The work You have done is excellent, don´t let people destroy what You´re doing.Didn´t Your board have a proper solder tap?Moewbius Quote Link to comment Share on other sites More sharing options...
tarzan boy Posted January 23, 2007 Report Share Posted January 23, 2007 I 3rd the kudos. My newbie solders a year ago were shit compared to this, although by the time I got to my DINs and DOUTs the solders were looking a little better ;)You're in Greece, I'm in Italy, and I have 6 extra C64 PSUs. I hope you find one your ways, I would offer to ship one for cost but the problem is that 'cost' for shipping from Italy is rather outrageous-- you're better off finding one there. Quote Link to comment Share on other sites More sharing options...
swoki Posted January 23, 2007 Author Report Share Posted January 23, 2007 moebius: what's a soldering tap supposed to be? (I can sense a weird joke in the air... but I thought I should still ask...) ...and what's with the capital Ys? ::)thanks anyway, people... :) although, the rest of the day was a disaster... I started working on the SID module, mixed some capacitors, misplaced them, desoldered them without a pump/braid, had solder spread all over the place... and on top of that, I managed to break off the corner of the core pcb... (don't ask me how :-[). I think that I got it back together succesfully though... (and I also think I'm an idiot...)as far as the PSU goes... I think I'll follow your advice, and if all else fails, ask for tarzan boy's help (thanks in advance! :))I'm off to buy a pump... or braid... I don't know...cheers! Quote Link to comment Share on other sites More sharing options...
moebius Posted January 23, 2007 Report Share Posted January 23, 2007 Hi ya! Sorry for me bad enklish.Solder taps are the spots to solder on.. Usually round and with hole in the center :D I´m sorry, I´ve made a board with previous layout and the legs for the rectifier needed bigger drill. There wasn´t much space to solder there.Cap Ys are for life.. Plain and Simple; "How Do You Do" :D I hope You´ll get the Braid.. :DMoebiusp.s. You are doing fine! Quote Link to comment Share on other sites More sharing options...
swoki Posted January 23, 2007 Author Report Share Posted January 23, 2007 :)hehe... ok... no prob...I went for the pump... and it worked like a charm... the core module is fully soldered... BUT...for testing purposes, I used a wall adapter to power only the core. It's a 9V/1A one (I use it for a Boss stomp-box), so, I guessed it would be fine. well.... it wasn't... the wall adapter's output showed something like 8.5V on the multi-meter, but I was getting only 1.1-1.2V everywhere on the core, plus the 7805 was getting too warm (being plugged for less than a minute, and touching it for a single moment almost got me a nice burn). any suggestions? ???ps: I should probably check for short-circuits, since the core actually came up rather messier than the DIN... :-\ ...is there any chance that a short would 'cause what I'm describing?edit: I also tried with a 12V/1A adapter (being ultra fast, to avoid burning the 7805), and it still gave me 1.1-1.2V Quote Link to comment Share on other sites More sharing options...
Jaicen Posted January 23, 2007 Report Share Posted January 23, 2007 That's a simple one, you've got the regulator the wrong way around! We've all done it (some of us more than once ;D Quote Link to comment Share on other sites More sharing options...
swoki Posted January 23, 2007 Author Report Share Posted January 23, 2007 That's a simple one, you've got the regulator the wrong way around! We've all done it (some of us more than once ;Dhmmm... I really wish this is it... but, it definitely looks right... (it looks like here http://www.ucapps.de/mbhp_core.html)... the metal thing is on the side facing the little bridge, the resistor and J4... ??? ...do you think I should solder it the other way round?edit: being the impatient lad I am, I tried soldering it the other way around... I got the exact same measurments... hmmmm... doesn't sound bright... Quote Link to comment Share on other sites More sharing options...
