Sasha Posted February 2, 2007 Posted February 2, 2007 Here is wow I illuminated the pannel of the controller for Ableton Live I am building for my friend.The idea was to illuminate the pot outer groves on panel similar to the original Ableton Live but coloured white. For illumination are used 2 superbright LEDs per pot. The panel is made of steel - waterjet cut, but you can have same results using regular CNC mill. Under the panel is 1st white acrylic subpanel which carries all pot (2nd) subpanels and button PCBs. This is just trieout. I need to finish all the boards and start asembling it, and then I am going to publish the results. For now here is few pics.
audiocommander Posted February 2, 2007 Posted February 2, 2007 beautiful :Dare the LEDs dimmed and therefore reflecting the pot's state or just illumated all the time?Cheers,Michael
Sasha Posted February 2, 2007 Author Posted February 2, 2007 No, LEDs are just for illuminating.you're a good friend.What can I do... he knows shit about electronics, and I am always in the mood to help people with same interests as myself. And he made for me the panel on picture, so he is also good friend too. :)
Sasha Posted February 2, 2007 Author Posted February 2, 2007 And I must say something about that knobs... These are best knobs I`ve ever seen. They are from Sibalco and cost 1EUR/piece. They are very well made, soft touch, pretty narrow which is good for dense packing on panel. Really good ones, but bit expensive if you need much. He gave 80 EUR just for this controller. ::)
Resident-RobB Posted February 3, 2007 Posted February 3, 2007 A very nice result!I thought about doing this for my push buttons, mayby I still will do, this is looking real slick! About the knobs: I spent about 60 euro's on roughly 70 spare knobs for my project. Since I am attaching my controller to my DJ mixer I wanted the same ones. The deal was 1,20 per knobs, the bill I received, was 0,80 per knobs. Allways a pleasure ;) A litlle discount for high numbers? ::)
Sasha Posted February 5, 2007 Author Posted February 5, 2007 Thank you. About the knobs... it is really strange that plastic knobs are often more expensive than pots itself. Plastic and rubber is very cheap and making knobs are not so hi-tech. Pots are much more complex to make. Here in Serbia, I can buy almost 3 pots for a price of good plastic knob. ???
stryd_one Posted February 5, 2007 Posted February 5, 2007 Damn man that looks niiiiice :DI like the way you guys are helping each other out, it's nice to see people being pleasant to each other (so rare these days it seems) , and the end result is a pair of super slick midiboxes :)
midgetfidget Posted February 9, 2007 Posted February 9, 2007 it'd be great to have rgb leds that could change colour according to wht the encoder is assigned to. EG red for res, green for cutoff etc etc.
Sasha Posted February 9, 2007 Author Posted February 9, 2007 Yes, it would be cool. Some people from comunity already done some RGB LED customisation for their boxes. Also, the Robert Hanke`s (Monolake) Monodeck II has RGB LEDs. Monodeck 2 is actually midibox based. Monodeck 1 was Doepher.
NeurDis Posted April 1, 2007 Posted April 1, 2007 That's awesome!I'm working on something that's sort of the ghetto version of this.;D I basically have a clear plastic case for my SID. I made some reverse stensels for the knob/button labels so when I spray paint the box, the lettering will still be see-through but the rest will be black. That way the light only comes through the labels and lettering.I would totally do it this way if I could though :)
stryd_one Posted April 1, 2007 Posted April 1, 2007 I had that same idea a while back... Where are you gonna get the lettering to use as a stencil for labels? There's no way you could cut lettering that small practically... What kind of paint are you going to use? Most spraypaint is kinda translucent, so it won't block the backlighting. Of course you can do a few layers of paint but then you need very thick stencil material....I'd be interested to see how you're planning on getting around this stuff! :)
kris Posted April 1, 2007 Posted April 1, 2007 your work looks amazing as usual sasha really nice touch for an abelton controller i look forward to seeing it finished he is a really good friend if he can cut panels for you like that im still waiting to hear from a friend of a friend about laser cutting my latest panel (its frustrating but waiting can be good sometimes) regards kris
NeurDis Posted April 1, 2007 Posted April 1, 2007 Where are you gonna get the lettering to use as a stencil for labels? I have some sticky back printer paper that I'm going to test. I was thinking of printing out the lettering and then cutting along the lines. Then I would stick the letters on to the box and paint it. I'm worried that the paint will bleed or soak through the paper (there's a pretty big chance that it will, but that's what testing is for). If luck is on my side, then I would be able to peel/scrape off the sticky letters. and expose the clear, unpainted plastic. If it does bleed a little, I was thinking of sanding off the parts that bleed. There's no way you could cut lettering that small practically I'm planning on making the letters pretty big. I'm only making a step A CS. The main design that I'm shooting for would have a couple of large (as in 50pt font or more) logos that said "MIDIbox SID" on the side of the case. Then I wanted to have lines going from each button to the LCD to indicate which button went with which parameter. I was planning on using large symbols rather than letters. I also wanted rings around the buttons. What kind of paint are you going to use? Most spraypaint is kinda translucent, so it won't block the backlighting. The paint type is still undecided. I've been wondering how make the paint less see-through, and haven't come up with much. I was thinking of trying a layer on the surface and on the inside. What I really want to find is somthing that is waterproof that has a sticky back on it. I'm thinking of contact paper, but I don't think I can print my stencel on that. I only half-expect it to work. I acually kinda like how it looks clear with the lights in it, so if the test run doesn't work I'm just going to leav it clear.
NeurDis Posted April 1, 2007 Posted April 1, 2007 Sure thing!Actually, I just posted a question in the SID section regarding a problem with the Step A CS. Once I get that squared away I'm going to start the painting.
Sasha Posted April 2, 2007 Author Posted April 2, 2007 your work looks amazing as usual sasha really nice touch for an abelton controller i look forward to seeing it finishedThank you kris, controller is almost finished. All electronics mechanics, few subpannels, but big job left to do is panel LED illumination. The problem is mounting so many LEDs for illumination. It takes 2 LEDs per pot window, and so little space to position it. Also, I make one error designing the acrylic subpanel and place the hole too close to the window, so we are pretty much stucked now, but we will sort it up somehow. he is a really good friend if he can cut panels for you like that im still waiting to hear from a friend of a friend about laser cutting my latest panel (its frustrating but waiting can be good sometimes)Hey, I am making this controller for him! He don`t own waterjet machine, but his father have friend who made us small favor. It is really not big deal for them. While they are cutting some big job they added 2 more panels. ;) I've been wondering how make the paint less see-through, and haven't come up with much.NeurDis, I`ve done some thinking and experimenting with backlit illumination and it is not so complicated or hard to achieve. First, I don`t think you can make it using handcut paper stancils. You can if your letters are pretty big but still not out of paper. For making proper stencils use PVC sheets cutted on PVC cutter. Those cutters are not so hard to find, all sign making service have one of those. You just give them a vector drawing and that is it. Bare in mind that you cannot have super small letters with this technique. Here is the picture of the coaster I`ve made using PVC masking. I tried to cut it by hand but I wasn`t satisfied at all. ...back to your question. Once you mask your panel you can spray it black in two layers and it will block the paint perfectly. If you want to use lets say white paint, paint your panel white in two layers and after it paint it black. This is only useful if you are painting transparent panel from back side.I always force people to try laser for this kind of job, because it is cheap, quick and very precise.Again... all express stamp making service own laser cutter/engraver! Having your lettering or signs illuminated is very easy and quick. You just spray your transparent acrylic panel with few coats of paint and give to the engraving service to engrave it. It will burn it just slightly to take away the paint and make it transparent. I will post an image of experimental piece of board I`ve done it some time ago when I get back home.
stryd_one Posted April 2, 2007 Posted April 2, 2007 You really are quite the craftsman hey sasha! I love the coaster artwork :D I feel like I've seen it before somewhere, weird. Again... all express stamp making service own laser cutter/engraver! Thanks for the tip mate. I know that you have mentioned a few times that there is a type of store that all have an engraver... But I can't seem to find any stores by those names... For example, I googled "express stamp making service" but just found lots of unusual stuff that didn't seem right. Do you know if they go by another name?
kris Posted April 2, 2007 Posted April 2, 2007 yea i can never be botherd with leds i might make a panel with them once just for the experience maybe even with labels just for stryd yea if you put it like that i suppose hes getting the best end of the deal i know how valuble i reliable plate cutter is vinyl sign cutters is that the type of place you want regards kris
Sasha Posted April 2, 2007 Author Posted April 2, 2007 You really are quite the craftsman hey sasha! I love the coaster artwork Cheesy I feel like I've seen it before somewhere, weird.Thank you stryd. Sure you have seen it before. It is well known Richie Hawtin aka Plastikman logo. It is designed by his friend from high school or something. Maybe you have seen it on his covers or in one of his videos (Plastikman - Plastique) I just love the design, just right for that name. :)Thanks for the tip mate. I know that you have mentioned a few times that there is a type of store that all have an engraver... But I can't seem to find any stores by those names... For example, I googled "express stamp making service" but just found lots of unusual stuff that didn't seem right. Do you know if they go by another name?I advise you not to google, rather take a walk in some shopping mall or wherever you have shops like copier services, photo stores stamp service or such. Don`t look for sign laser engraving. Just look for engraving service and ask about techniques they are using. Mechanical, laser, etching... Ask them, they know about they competition so they probably can direct you to somebody.I maybe confused you when I said express stamp service. I tried to google it and I mostly get post stamps. I had in mind this kind of stamp:Maybe they are comming by other name, but my english is very limited. I can tell you again. In fucked up serbia there is alot of engravers, stamp services sign makers, and most economical way is to use laser cutters. Try to find a company that can make you acrylic illuminated panel for your business. Only acceptable way for them to make it is using laser. Mechanical CNC cutting would be slow and thus expensive and it is reserved mostly for metal. Sorry I cannot help you enough, but I personally didn`t know they exists until friend pointed mi out, so now I can find and chose the cheapest one. Price and quality have nothing in common for cutting, when it comes to engraving the bigger resolution the better. I engrave in resolution 700lpi.I hope I helped a bit.
Sasha Posted April 2, 2007 Author Posted April 2, 2007 I just remembered the maker of x0xbox are doing laser engraving. Here is the link, but I would never do mailorder engraving. http://www.adafruit.com/laser/You must be seen this at make`s website
stryd_one Posted April 2, 2007 Posted April 2, 2007 OK now I'm with ya, thanks bro! :DSerbia ain't all bad - it has a friendly midiboxer, so it's automatically cool ;D
Sasha Posted April 2, 2007 Author Posted April 2, 2007 No, it`s not all bad but I would rather "hairstyle" australian sheeps and make some boxes in freetime than be here, but it is almost impossible to get there without job offer. :(
stryd_one Posted April 2, 2007 Posted April 2, 2007 Well you'll be welcome here bro. There are quite large Serbian communities in .au :) But it is really hard to get a visa here, or worse still a citizenship :(You should look into work in the mining industry, a lot of guys do that, and the money is good... So long as you aren't claustrophobic!
Sasha Posted April 2, 2007 Author Posted April 2, 2007 It is large community because much Serbs get into some imigrant refugee program because of the local war. I am refugee too, (used to live in croatia ex yugoslavia) but was under age than to apply for imigration, now is too late. :(About mining industy... not problem for me... I am earning 250 EUR per month here, so you got the point...Lots of people tried to come over regular imigrant program but not much chance if you are not very qualified or you have job offer. No need to say you have to pay all the papers which is not cheap, and it is not guarantie you will be acceped.I think Australia will stay just an dream for me and all connection I have with it is my beloved didgeridoo. But, what can I do... life is a bitch.
