Pearl Posted April 21, 2003 Report Share Posted April 21, 2003 Is it possible to use the LED-Rings with 15+1 instead of the normal 11+1 solution?I think, I have to modify the maps in lc_ledrings.inc but I dont't know exactly how or where to modify the "link" to the last LED.Code in lc_ledrings.inc ??:... ;; move table entry (TABLAT) to [iNDF0], don't increment here movf TABLAT, W IFSET MIOS_PARAMETER1, 6, iorlw 0x08 ; set 12th (center) LED if bit 6 of received CC value is set movwf INDF1...Thanx Pearl Quote Link to comment Share on other sites More sharing options...
TK. Posted April 21, 2003 Report Share Posted April 21, 2003 You could changeIFSET MIOS_PARAMETER1, 6, iorlw 0x08 ; set 12th (center) LED if bit 6 of received CC value is settoIFSET MIOS_PARAMETER1, 6, iorlw 0x80 ; set 16th (center) LED if bit 6 of received CC value is setbut note that Logic/Cubase sends 12 different patterns only, therefore more than 11 LEDs doesn't really makes sense in a LC emulation.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Pearl Posted April 21, 2003 Author Report Share Posted April 21, 2003 Hi ...I thought about switching Houston <-> LC but that doesn't work, because Cubase only supports one Houston in its setup and I want to use 16 MF.But, where is the difference between IFSET MIOS_PARAMETER1, 6, iorlw 0x08 ; set 12th (center) LED if bit 6 of received CC value is set and IFSET MIOS_PARAMETER1, 6, iorlw 0x80 ; set 16th (center) LED if bit 6 of received CC value is set  I thought after ";" are only remarks ??Bye Pearl Quote Link to comment Share on other sites More sharing options...
TK. Posted April 22, 2003 Report Share Posted April 22, 2003 Hi Pearl,ok, with the houston emulation it makes sense, as it controls the LED rings directly.The difference of the two code lines is not only the comment, but also the value which will be "or"ed to the LED pattern: 0x08 for the 12th LED, 0x80 for the 16th LEDBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted November 24, 2005 Report Share Posted November 24, 2005 oops sorry wrong topic :-X... then why don't delete it? ;) Greets, Roger Quote Link to comment Share on other sites More sharing options...
