andrea Posted February 19, 2007 Posted February 19, 2007 hi,I was wander if someone could help me with this project.I would like to build something like Velocity Converter from Midi Solutions...http://www.midisolutions.com/prodvel.htmDoes anyone know some DIY project for that converter?ThanksAndrea
stryd_one Posted February 20, 2007 Posted February 20, 2007 You could easily code something like this with the C interface if you have some programming skills?
bill Posted February 20, 2007 Posted February 20, 2007 To my knowledge, a mbhp version of this do not exist yet, but if you are able to describe with enough precision what it's supposed to do, then i guess someone (maybe me) can help you to do it.It should not be much complicated anyway.
andrea Posted February 20, 2007 Author Posted February 20, 2007 Thank you Bill, you are wery kind.The converter that I am talking about is similar to Velocity Converter from Midi Solutions but a more simple one could be usefull.The converter is able to transorm a velocity value of an incoming midi message into another value. In this way you are able to change the velocity curve for your MIDI keyboard.It means that it let's you remap the function which maps the strength you hit the key to the volume the note plays.The problem is that my keyboard doesn't have a function to customize the velocity curve. When I use it with a external sound module the dynamic response is completely different. For example, you have to hit wery strongly (I mean very!!) if you want to send a velocity level of 127 to the expander. There is a freeware software that allow you to change velocity curve : Midi velocity curve changer (Trombettworks Software)http://www.trombettworks.com/velocity.phpbut I am looking for something that works without pc.I am sure that this can accomplished with MIDIBOX, but unfortunately I am just a piano player and I don't have any programming skill.This can be an additional use of mIDIBOX that can solve a lot of problem in a simple way. Thanks Andrea
bill Posted February 21, 2007 Posted February 21, 2007 What about the curves ?Should they be linear ? (initial value * boost factor)Should they be transposed ? (initial value + gain)or maybe precalculateds ? (then give the values or formulas)Make the curves editable from a control surface will make this project lot more complicated, so i guess it's not what you want, right ?bill you are a BIG man!wtf ? you mean, i'm "fat" ? how do you know that ? ^^
QBAS Posted February 21, 2007 Posted February 21, 2007 wtf ? you mean, i'm "fat" ? how do you know that ? ^^ ;D
bill Posted February 21, 2007 Posted February 21, 2007 Does anyone know some DIY project for that converter?ThanksAndreaCheck this : http://www.midibox.org/dokuwiki/doku.php?id=velocity_converter
andrea Posted February 21, 2007 Author Posted February 21, 2007 Hi, you are right bill, I don't need a unit with curves editable from a control surface but I am interested to have just a fixed and precalculated conversion between velocity in input and velocity in output.I mean, using Midi Velocity Changer, I found the suitable conversion curve that I need to adapt my keyboard to the expander.This program is able to display the change between in and out and so I have a table of conversion of vel. in to vel. outHere I reported a piece of that table for example:In OUt000 --> 000001 --> 002002 --> 003004 --> 007005 008 ...103 119104 119..125 127126 127127 127I need just a unit that apply this fixed conversion between midi velocity in Input and midi velocity in output. Eventually it could be interesting the possibility of choosing diffrent conversion table (precalculated with Velocity Changer) from the control surface...but it is not necessary. I will be very happy to have just a single conversion table. with this unit I will be able to play live my keybord and my expander without a computer with Velocity changer.Thank you bill!!!!By
bill Posted February 22, 2007 Posted February 22, 2007 Ok, it's your turn to work a bit :fill (replace the "0" with your values) that array thanks to your values. const char curve1[127] = { //out // in 0, // 0 0, // 1 0, // 2 0, // 3 0, // 4 0, // 5 0, // 6 0, // 7 0, // 8 0, // 9 0, // 10 0, // 11 0, // 12 0, // 13 0, // 14 0, // 15 0, // 16 0, // 17 0, // 18 0, // 19 0, // 20 0, // 21 0, // 22 0, // 23 0, // 24 0, // 25 0, // 26 0, // 27 0, // 28 0, // 29 0, // 30 0, // 31 0, // 32 0, // 33 0, // 34 0, // 35 0, // 36 0, // 37 0, // 38 0, // 39 0, // 40 0, // 41 0, // 42 0, // 43 0, // 44 0, // 45 0, // 46 0, // 47 0, // 48 0, // 49 0, // 50 0, // 51 0, // 52 0, // 53 0, // 54 0, // 55 0, // 56 0, // 57 0, // 58 0, // 59 0, // 60 0, // 61 0, // 62 0, // 63 0, // 64 0, // 65 0, // 66 0, // 67 0, // 68 0, // 69 0, // 70 0, // 71 0, // 72 0, // 73 0, // 74 0, // 75 0, // 76 0, // 77 0, // 78 0, // 79 0, // 80 0, // 81 0, // 82 0, // 83 0, // 84 0, // 85 0, // 86 0, // 87 0, // 88 0, // 89 0, // 90 0, // 91 0, // 92 0, // 93 0, // 94 0, // 95 0, // 96 0, // 97 0, // 98 0, // 99 0, // 100 0, // 101 0, // 102 0, // 103 0, // 104 0, // 105 0, // 106 0, // 107 0, // 108 0, // 109 0, // 110 0, // 111 0, // 112 0, // 113 0, // 114 0, // 115 0, // 116 0, // 117 0, // 118 0, // 119 0, // 120 0, // 121 0, // 122 0, // 123 0, // 124 0, // 125 0, // 126 0, // 127 }; If you are motivated, "draw" many curves, and give them different names like curve1 curve2 curve3.
andrea Posted February 22, 2007 Author Posted February 22, 2007 Ok bill, you are great!!The most important is curve 1 (that is curve that I usually use).I can draw more curves, but I need time to set up my feeling with the dynamics. I think that you can edit random curve 2, curve 3..(just putting random values or leave linear relation:000---000, 001---001... 027---027 etc...) and you can show me how I can modify by my self the conversion table of these curve.( I think 4 or 5 curve will be more than enought). In this way I can edit and correct the values any time I need without disturb you...are you agree??Do you think that it is possible to see on LCD which curve I am using??and if the unit is working of no?Thank you again for your time!!!!This is my curve 1.const char curve1[127] = { //out // in 0, // 0 2, // 1 3, // 2 5, // 3 7, // 4 8, // 5 10, // 6 12, // 7 14, // 8 15, // 9 17, // 10 19, // 11 20, // 12 22, // 13 24, // 14 25, // 15 27, // 16 29, // 17 30, // 18 32, // 19 34, // 20 36, // 21 37, // 22 39, // 23 41, // 24 42, // 25 44, // 26 45, // 27 46, // 28 48, // 29 49, // 30 50, // 31 51, // 32 52, // 33 53, // 34 55, // 35 56, // 36 57, // 37 58, // 38 59, // 39 61, // 40 63, // 42 64, // 43 65, // 44 67, // 45 68, // 46 70, // 48 72, // 49 73, // 50 74, // 51 75, // 52 77, // 53 78, // 54 79, // 55 80, // 56 81, // 57 82, // 58 83, // 59 84, // 60 85, // 61 86, // 62 86, // 63 87, // 64 88, // 65 89, // 66 90, // 67 91, // 68 92, // 69 93, // 70 94, // 71 95, // 72 96, // 73 96, // 74 97, // 75 98, // 76 99, // 77 100, // 78 101, // 79 101, // 80 102, // 81 103, // 82 104, // 83 105, // 84 106, // 85 106, // 86 107, // 87 108, // 88 109, // 89 110, // 90 110, // 91 111, // 92 112, // 93 113, // 94 114, // 95 114, // 96 115, // 97 116, // 98 117, // 99 117, // 100 118, // 101 118, // 102 119, // 103 120, // 105 121, // 106 121, // 107 122, // 108 122, // 109 123, // 110 123, // 111 124, // 112 124, // 113 124, // 114 125, // 115 125, // 116 125, // 117 125, // 118 125, // 119 126 // 120 126, // 121 126, // 122 126, // 123 126, // 124 127, // 125 127, // 126 127, // 127};
bill Posted February 23, 2007 Posted February 23, 2007 The Version 0.2 :They are 16 Preset curves. Moving the pot From min-max select the desired velocity curve.Curves must be tuned to your needs. (No editor yet)Curves are separated into distinct files for user comfort : curve1.c, curve2.c, ..., curve16.chttp://jambonbill.free.fr/Velocity_converter/velocity_converter_v0.2.zip
andrea Posted February 26, 2007 Author Posted February 26, 2007 Thank yu Bill,I am going to test it and I will let you know!!I am sure that it will be great.Andrea
dj3nk Posted March 2, 2007 Posted March 2, 2007 http://www.stoffelshome.de/mvc.htmlhope this will help you.
