I read some posts on the external analog filter (Moog or CEM) that could be connected to the SID (V2) and the FM MidiBoxes...The sounds I heard were very cool, but I was wondering if someone knows if the CV that is sent to this filter is stored with each patch! Can I completely recall settings that include this external filter from both SID and FM MIdiBoxes? And can the each patch store a steady CV (to keep the filter partly closed for instance) as well as a modulation routings to this external filter?
Greetings,
Rutger
this has been prepared in the patch structure of MBSID V2:
SID_Ix_CUSTOM_SW        EQU    0x014  ; custom switch flags #1-8
SID_Ix_CUSTOM_PAR1_L    EQU    0x040  ; custom parameter #1 (e.g. for AOUT)
SID_Ix_CUSTOM_PAR1_H    EQU    0x041
SID_Ix_CUSTOM_PAR2_L    EQU    0x042  ; custom parameter #2
SID_Ix_CUSTOM_PAR2_H    EQU    0x043
SID_Ix_CUSTOM_PAR3_L    EQU    0x044  ; custom parameter #3
SID_Ix_CUSTOM_PAR3_H    EQU    0x045
SID_Ix_CUSTOM_PAR4_L    EQU    0x046  ; custom parameter #4
SID_Ix_CUSTOM_PAR4_H    EQU    0x047
SID_Ix_CUSTOM_PAR5_L    EQU    0x048  ; custom parameter #5
SID_Ix_CUSTOM_PAR5_H    EQU    0x049
SID_Ix_CUSTOM_PAR6_L    EQU    0x04a  ; custom parameter #6
SID_Ix_CUSTOM_PAR6_H    EQU    0x04b
SID_Ix_CUSTOM_PAR7_L    EQU    0x04c  ; custom parameter #7
SID_Ix_CUSTOM_PAR7_H    EQU    0x04d
SID_Ix_CUSTOM_PAR8_L    EQU    0x04e  ; custom parameter #8
SID_Ix_CUSTOM_PAR8_H    EQU    0x04f
[/code]
In addition, up to 8 AOUTs will be available as modulation matrix targets
Thank you Thorsten, for sharing so much of the new design info. That allows me to start working on the filter right away!
I'm working on a redesign of the filter of Rick Jansen, that supports cv controlled resonance and cutoff, to be able to store all settings of this external filter in a MBSID patch. Initially I'm making a stereo version that is controlled by only 1 resonance cv and 1 frequency cv, but perhaps with the new MBSID V2 it would be interesting to make actually 4 or maybe 8 filters to work with 4 or 8 sids at true polyphony. With four SID's it should be possible to create a 4-voice synth with 3-osc per voice. With 8 SID's the same should be possible with 8 voices but this requires 8 additional AOUT outputs (and support in the patch structure). If 8 sid's are used for stereo doubling a 4-voice polyphonic synth the AOUT outputs could be routed to both left and right channel versions of the filter... This would result in a true stereo 4-voice 3-osc poly synth..... nice ;).
Another thing I was thinking about (but maybe Thorsten already covered that) is some sort of mixing system controlled by the patch structure, that would allow panning settings of the 4 or 8 independant SID's through only left and right outputs. But again, this requires many AOUT outputs.
Greetings,
Rutger
The "ensemble" (which contains MIDI channel, Splits, Transpose, Patch/Bank, etc... informations) will have some additional custom parameters free for such static settings. It's on you to program a driver which controls additional AOUT modules. I cannot support such special variants from my side, as it would increase my own support effort significantly. But the basics have been considered.
thanks! I understand. I'm willing to try and program additional AOUT or DOUT (I assume that you need this for the 8 custom switch flags to output) support if I got the basics working with this filter. I just finished the drawing of the Moog schematic by Rick Jansen in Eagle and modified the Resonance feedbackpath allow CV control over the resonance. I also changed the choice of op-amps to ones that are easier to find (i.e. Reichelt). All op-amps are TL074 or TL072 now. In the resonance cv control circuit I used half of an LM13700 OTA. My intention is to make at least two circuits of this filter on one board (i.e. stereo) and see if everything works alright.
I haven't still figured out how many filters I would like to make eventually. Just a stereo filter on the output is very nice, but it would also be great to have more filters (i.e. one for each SID). That would make a more polyphonic synth, but it would also require that each SID+CORE sends it's specific envelope generator voltage to the AOUT.
Can you give a little insight on to which CORE the AOUT has to be connected to support the 8 custom parameters you spoke about? Is it only the Master CORE? Or can each CORE have it's own AOUT module with these 8 custom parameters?
In other words. Are those 8 custom parameters meant for an ensemble or for each patch within an ensemble?
Greetings,
Rutger
ps. Getting more and more excited about this! And of course I will share schematics and boards as soon as I got something working. If the Moog filter work good and Rick Jansen agrees, perhaps it would be interesting to make it available as a kit for expanding the SID synth. But it's a little soon for that I guess ;).
wow i really like these analogue filtering possibilities
i might have to build something with an fm
ive allways liked the oberheim filters anybody got schematics for them
kris
Building Oberheim filters might be more difficult, since most famous oberheims used Curtis chips that contained the entire filter. The CEM filter is not produced anymore, but if you're lucky, you could find some on the internet. Or ask Thorsten...I believe he had a bunch of them ;).
Greetings,
Rutger
thanks for the info
  it was the cem 3372 and 3044 in the oberheims
ill keep my eye out you never know
but for now the moogs are very interesting
its really good that there are a few people on this plot
kris
If you ever find a bunch of CEM's for a reasonable price i'd be very interested. The reason I wanted to start building the MidiBox is because I want to learn about programming PIC's. I'm a student in artificial intelligence (so experienced in programming) and familiar with analog electronics, but i have never programmed a PIC. I was hoping to gather experience with this project to be able to construct a PIC controlled poly analog synth somewhere in the future....
For now I'm focussing on the Rick Jansen implementation of the Moog filter. I noticed some differences between the Moog filter schematic and the PCB that Thorsten used to create the demo on www.ucapps.de. On the picture of the PCB I noticed less IC's and more transistors. I assume that the LM3046 NPN-array is left out in this design and that manually matched transistor pairs are used. With a good matching procedure this can even lead to better results of the expo converter and the filter, besides, buying a bunch of transistors may be cheaper. I will be using a simple transistor matching circuit by Jim Patchell to select transistors.
I changed the NPN transistors in the ladder from BC109 to BC549 (easily available and cheap at Reichelt.de). Oakley uses the same transistors in the Moog Super Ladder filter module. I also intend to use a LM13700 (also available through reichelt) for the CV control over the resonance. Only half of the LM13700 is used, so I think that I will make a stereo filter on a single PCB to use the other half of the LM13700.
I changed op-amps to TL074 and TL072.
The best news: the electronic components of the new design should be less than 10 euro's for a mono version of the filter (this is without pots, connectors and PCB).
I was thinking about adding a CV parameter (or just a switch) to control the amount of gain on the input op-amps, just like Thorsten did manually, or maybe a seperate drive circuit that drives a nice sounding transistor.
Greetings,
Rutger
I have a few more practical questions regarding the new SID V2 hardware setup, that perhaps Thorsten (or Wilba!) can help out with:
1.  How are the two SID modules connected to a single Core? I assume that the regular SID connection is still used, but to which pins of the PIC is the second SID connected?
2.  How is the AOUT supported? Is the idea that each core (master or slave) has two SID's and it's own AOUT module for modulating external effects? Or is only the Master Core the one that supports the AOUT?
3.  Do the custom switch settings in the V2 SID require a DOUT module? Or is it possible to use the AOUT gate outputs for switching?
3.  If I'm correct the Core for SID V2 requires a PIC18F4685, but can the MidiBox FM also use this PIC for it's Core?
Greetings,
Rutger
The second SID module is connected to the same pins like the first one, just only the CS# line is connected to J14 of the core module to allow individual accesses
All core modules (master/slave) support a AOUT or AOUT_LC module
I will implement several options on request. The AOUT gates will be supported of course
Currently not, as the PIC18F4685 is not completely software compatible, the RAM area from 0x60-0x7f is not directly accessible. But with some small changes in the code, the MBFM application will run. This is on my TODO list, but currently other things have a higher priority
