stryd_one Posted June 9, 2007 Posted June 9, 2007 One core will happily drive up to 8 of these from a single LCD port :)
MTE Posted June 10, 2007 Author Posted June 10, 2007 Yehall 8 I will implement...3 per each Deck....2 for Master-section ;)1 little bug I found out...when I photograph them with flash, the lcds goes clear, after poweron the screen is back :-\
DavidBanner Posted June 10, 2007 Posted June 10, 2007 wow! I'm double impressed!I've checked out your bit on the wiki, so my next question is can I grab the C to hack into my own creation?
MTE Posted June 10, 2007 Author Posted June 10, 2007 Attached ;)app_lcd.increadme.txtapp_lcd.increadme.txt
DavidBanner Posted June 10, 2007 Posted June 10, 2007 you star! thanks very muchdefinately going on my box v2....now off to (finaly) finish v1
stryd_one Posted June 11, 2007 Posted June 11, 2007 Yeh I'm still looking for a perl programmer so I don't have to convert it manually next time... anyone? Oh BTW, if you get the Nokia 5110 screen you can get a backlight attached :)If anyone finds some 7110 screens to send to me I'll do the driver for those badboys too..
Sasha Posted June 11, 2007 Posted June 11, 2007 Man, those LCDs are so great and informative. You already great controller will evolve so much when you add those dislays. 1 little bug I found out...when I photograph them with flash, the lcds goes clear, after poweron the screen is backWhat a strange bug ??? What do you think what`s cosing it? Light or electrical discharge?I hope you want need to have shade for your controller to block the strobe light when gigging. ;D
MTE Posted June 11, 2007 Author Posted June 11, 2007 Yeh its very strange bug, i tested it some times again...its only if u put the camera-flash directly 10-15 cm in front of the display....a friend telled me maybe it works like a sensor or something....dont know.2morrow my EL-Foil will arrive :) *jumping :) cant await to testStay tuned 8)
th0mas Posted June 11, 2007 Posted June 11, 2007 Yeh I'm still looking for a perl programmer so I don't have to convert it manually next time... anyone? Oh BTW, if you get the Nokia 5110 screen you can get a backlight attached :)If anyone finds some 7110 screens to send to me I'll do the driver for those badboys too..What do you need a perl programmer for stryd? I can prolly do it.
MTE Posted June 12, 2007 Author Posted June 12, 2007 Wuuuuuooooooaaaaaaaaaaaaaaaaaahhhhhhhh :D :D :D :D :DTHNXXXXXXXXXXXXXXXXXXXXXXXXXXX Mate !!!What a great blue colour, its the same like the EL-Foil....NICE !!!Thnx and 1000 thnx again & again :)
Sasha Posted June 12, 2007 Posted June 12, 2007 I`m glad you like it, and I`m sure I`ll thank you for documentation as I want to build one myself. ;)
MTE Posted June 13, 2007 Author Posted June 13, 2007 I love this foil :)More Backlighting tests next days ;)
Sasha Posted June 16, 2007 Posted June 16, 2007 Man, I understand now why you waited for vacation to work on it.
goule Posted June 17, 2007 Posted June 17, 2007 Wow, amazing ! :oI can't wait to see it finished !Goule
MTE Posted June 24, 2007 Author Posted June 24, 2007 Im in love... :DThese Jogs are so great colour, cant await until my superbright blue leds arrive to illuminate them...Big thnx again to Sasha who lasered this babys for me 8)
MTE Posted June 27, 2007 Author Posted June 27, 2007 Stupid question but i cant test still this.....can I connect an encoder on a "dissimilar" pin ?Example :ENC_ENTRY 1, 1, MIOS_ENC_MODE_NON_DETENTED ; // Jogwheelencoder Deck A instead of ENC_ENTRY 1, 0, MIOS_ENC_MODE_NON_DETENTED ; // Jogwheelencoder Deck ASorry for asking this but I must know this before I change my pintables for the DIN-soldering
stryd_one Posted June 27, 2007 Posted June 27, 2007 Heh I've always wondered that. I don't think it'll work across two SRs. Otherwise, as far as I can see, it should work fine... but I decided that instead of asking TK, I'd just use even numbers. Is there some compelling reason why you'd rather start from odd numbers?Edit: Yeh it should work like in your picture.
MTE Posted June 27, 2007 Author Posted June 27, 2007 Is there some compelling reason why you'd rather start from odd numbers?not really, just a thought, cause I forgot I have some Din-Pins left so I shift 1 pin to the right and its ok....but this question is still interesting (for me :) )
