ultra Posted March 25, 2007 Posted March 25, 2007 i have some alps encoders (ec12 series i believe) and i don't understand their behavior. when i turn it, all three leads connect, which obviously gives me bad results when changing values on my sequencer. does anybody have an idea of what's going on here?thanks,drew
lylehaze Posted March 25, 2007 Posted March 25, 2007 Sounds about right.Three leads.. A, B, and Common.Phase A will be connected to Common 50% of the timePhase B will be connected to Common 50% of the timePhases A and B are 90 degrees out of phase.So...All three terminals will be shorted together 25%of the time.You can see that pattern on page 5 of the Alps datasheet.If my description matches your encoder, then it appearsto be working well.Good Luck,LyleHaze
ultra Posted March 26, 2007 Author Posted March 26, 2007 in that case, the improper behavior (it only increments downward) must be a wiring deal. i'm using the center as the common. i'll try it another way and thanks for your response.:)drew
lylehaze Posted March 26, 2007 Posted March 26, 2007 I checked the sheet again. There are a lot of differentmodels in the EC12 series, but all of the 3 pin packages that I saw had common in the middle, and A and B on either side.Good Luck,LyleHaze
/tilted/ Posted March 26, 2007 Posted March 26, 2007 I believe the STEC16 series has the common on one side rather than in the centre.
