moxi Posted March 26, 2007 Posted March 26, 2007 Hi,my first VSTi is finished now...a pic of the synth:the VST instrument file:http://soundandbreakfast.org/diy/vst_pluggin.htmlPm me if you want the source project. Synth Edit is free.thanks.
Jaicen Posted March 26, 2007 Posted March 26, 2007 Ok, i've got some quick Acid style patches knocked up, not sure how to save them so they're in Cubase Instrument format. How do I upload them ?
moxi Posted March 26, 2007 Author Posted March 26, 2007 hi,save your patch as "fxb" file in cubase (b mean bank) or "fxp" for individual preset. Maybe a bank is better, so I give to the bank your name/nickname..you can mail the patch at:soundandbreakfast_at_yahoo.frgreat thanks :)
Rowan Posted March 26, 2007 Posted March 26, 2007 Sorry this is OT but I have to mention it here; I first discovered the MIDIbox because of synthedit. In 2002-2003 I was well into building plug-ins with synth edit and I needed a controller for them. After some searching the synthedit fourms I found ucapps......and here I am after all these years, and I haven't made a VST plug since ???If my music PC was working at the moment I'd test your Plug, but the PSU is dead >:(
moxi Posted March 31, 2007 Author Posted March 31, 2007 Hi,I've updated the beta.Removed the multimode filter (will be re-added soon)LFO work better with an add. S&H function that sound great.added a "link" function to allow to setup the two left/right EG by a simple knob move.Use the LEFT eg when link on.http://www.soundandbreakfast.org/divers/UltimAtomX_0_5.dll
moxi Posted April 1, 2007 Author Posted April 1, 2007 the final release is here, see the first post.the synth:http://soundandbreakfast.org/divers/UltimAtomX.dllno more bug, all work fine!
Jaicen Posted April 1, 2007 Posted April 1, 2007 Can you add PWM? Those are the sounds I love the most from the SID, and I think this has some of that character, so it'd be nice to add.
dj3nk Posted April 1, 2007 Posted April 1, 2007 spelling error in the upper right corner : ......"soundandReakfast"....
moxi Posted April 1, 2007 Author Posted April 1, 2007 Can you add PWMit's what do the knob "pulse" in the osc section, no?. you just have to select the pulse waveform before.It's something I do not know well so let me know if this function don't work as on other synth (?)..I will check how that work on TK SID and make some research about that to see if it's possible to do it better..
moxi Posted April 2, 2007 Author Posted April 2, 2007 updated: now UltimAtom-X get nice wood side, so let say it sound more Analog ;D ;D ;D ;Dit's a joke, but the V1.2 will come with a nice feature: a VCO drift : I will add a realy slow LFO with its rate slowly modulated by another LFO, which will modulate in a really fine amount the "fine pitch" of the 3 oscs separatly...so Ultimatum-X VCOs will drift as know from true analog one !And I will add a switch to bypass the realy bad sounding filter, so you can use better one in serie after the synth...Filter are too important...
moxi Posted April 5, 2007 Author Posted April 5, 2007 hi,after playing with it, i've noticed that the Fm doesn't work as expected, so I've made some change and added two EG for the FM...it's now possible to do FM travelling pads that sound nice...the vco drift function make it too processor consuming, so I forget it..I've added some preset, I will post a full bank as soon as possible...sorry for the crappy first version...as I use, I can't afford to do too fast !For the PWM, synth edit does support it, but I will try in two week to find a way to do it with other atoms..
Lall Posted April 5, 2007 Posted April 5, 2007 Hi Moxi,Quite some time ago, I found the following about drifting parameters: http://www.musicdsp.org/archive.php?classid=1#183.I always wanted to try it on some audio effects but never did in the end :(It does not look too complex except for the random function but I believe a pseudo-random can be realized in a more or less efficient way if needed. Anyway, as the guy says that drifting code is being executed on a long term cycle so in the end the CPU consumption should be pretty low I suppose.Best regards,Lall
moxi Posted April 6, 2007 Author Posted April 6, 2007 great link! I will try to see how to transform all this stuff in SynthEdit module...
