Fairly new to PCB assembly.  I've seen the legs which effectively bolt to a surface and then the PCB screws into these.  Is there an equiavlent where the leg can be glued/stuck to a surface?  Ideally I would want plastic ones so the PCB can clip onto the leg?
Many thanks,
James
Yes, you could see that kind of spacers or as you call it legs on the computer motherboards. I`m not sure where to get it, but it shouldn`t be hard. Ask the guys from computer repair service.
