robin303 Posted May 3, 2003 Report Posted May 3, 2003 A quick question: Has anyone of you ever used these buttons:I think they are really cool! They are the Reichelt DIT and DTL types: "Digi-taster". Euro 1,75 each.What I was wondering, how can these be fitted to a front panel? Or should a circuit board be used to mount them? ???
Guest opiumx Posted May 3, 2003 Report Posted May 3, 2003 I swear I think i remember seeing these back in the day, must have been 99-00 when there was the midibox with 8 knobs. And it looks like yes you would have to mount them on a circuit board.
pay_c Posted May 3, 2003 Report Posted May 3, 2003 Im using them, too. Theyre very cool. The click-feeling is very pregnant and nice. You can mount them next to each other on a circuit board. The measures are (about) 17,5mm to 12,5 mm. So for 16 pots in a row (MB64SEQ ;D ) exactly 200mm. The leds are fitting in there perfectly.I think theyre a very good (also a little more expensive) solution.
gillesdeshays Posted May 4, 2003 Report Posted May 4, 2003 and with a nice and not too loud "click" ;)Gilles
robin303 Posted May 4, 2003 Author Report Posted May 4, 2003 Cool! I'm thinking about "matrix" circuit board, the size of my whole frontpanel. You know, the boards with premade holes. Then I can nicely fit all pots and buttons on it, instead of a whole mass of wiring :)
robin303 Posted May 4, 2003 Author Report Posted May 4, 2003 And sure looking great! :-*While we're on the knobs subject: Any tips for the pots?
pay_c Posted May 4, 2003 Report Posted May 4, 2003 For the pots:I think the ones at Reichelt with 4mm diameter are better than the 6mm ones (theyre also lighter to move) . They dont use up to much room, so you can built the whole thing a little more compact.The Aluknobs at Reichelt (for 4mm diameter) are very fine!*Gotta make some pictures*
robin303 Posted May 4, 2003 Author Report Posted May 4, 2003 Really? I thought the 6mm would be better as they seem stronger? Never thought of "turning-lightness".. So the 4mm are lighter to turn than the 6mm ones uh?I was looking at the KNOPF 14-6:14 mm diameter is nice and compact, as I'm trying to fit the whole MIDIbox in a A4 panel 297x210 mm.
d2k Posted May 4, 2003 Report Posted May 4, 2003 make sure you leave enough room between the pots - you don't want to affect knobs beside the one actually turning cos ur fingers get in the way ;p also make sure you get the right one for ur type of pot - either d-shaped or spindle style...Best..Dan
robin303 Posted May 4, 2003 Author Report Posted May 4, 2003 Good idea.. I have a mixing console here that has that problem.. A spacious design is much better to prevent accidental turning of knobs.What do you mean with d-shaped or spindle style knobs?
d2k Posted May 4, 2003 Report Posted May 4, 2003 What do you mean with d-shaped or spindle style knobs? Make sense?Best, Dan.
pay_c Posted May 5, 2003 Report Posted May 5, 2003 d2k is right with that. I built my pots in there with a space of 25x25mm.The 4mm pots of Reichelt are nearly as robust as the 6mm ones.All knobs at Reichelt are fitting on the pots at Reichelt. No shaped ones there.
robin303 Posted May 7, 2003 Author Report Posted May 7, 2003 Good advise, and utilising it in my design! I'm almost done now, but.. does anyone have the specs (size in mm) for the Reichelt DIT / DTL Buttons?And.. maybe more photos (Thorsten?) of the various Digitaster buttons to show of the colors? I'm still dubbing about which colours to order :)
pay_c Posted May 7, 2003 Report Posted May 7, 2003 I posted the specs earlier, but here again:about (meaning a *little* less - so you can really mount each to next ) 17,5 mm x 12,5 mmThe photos in the Reichelt catalogue show the colors kinda good. (If you dont have it already - ORDER IT!!!). I´m using black and blue ones - both are very fine. I think the red ones are good to.btw: If youre not sure about some pieces just make sample orders of them (meaning just ordering one).  You will have to order the stuff for your MB more than once. So just take all switches & pots, which you could-would-want to use into your first order and just look at them. I think nearly anybody does it like that.Hope I helped you.
robin303 Posted May 7, 2003 Author Report Posted May 7, 2003 Thanks for re-posting! Ordering samples is not an option, as I'm not German but Dutch. International orders have a minimum of 50 euros unfortunately..
Nat Posted July 9, 2003 Report Posted July 9, 2003 Anyone knows where to find those buttons in the US ?
