Midnite Posted August 15, 2007 Report Share Posted August 15, 2007 My core and sid pcbs and 2x40 lcd are working fine. Now it's time to add some control. I build a dinx1 with all the appropriate parts. I tested the voltages across the ic holder and got 5v. I plugged in the ic and turned on the unit and I get nothing that tells me the cs is working. I attatched the step a cs to the board and rebooted, still nothing. Am I missing the bus? I've search all over this forum and found noone with the same problem that had a explaination on how to fix it. I'm using smashes boards and BSL 1.2b MIOS 1.9e.Help--D Quote Link to comment Share on other sites More sharing options...
midiboxxer Posted August 15, 2007 Report Share Posted August 15, 2007 Can you post a picture of your board?Perhaps you have connected it to J8 instead of J9?Which application do you use (Midibox 64, LC...)?GreetingsMarkus Quote Link to comment Share on other sites More sharing options...
Midnite Posted August 15, 2007 Author Report Share Posted August 15, 2007 It's on j9. What do you mean by application? It's a sid. Quote Link to comment Share on other sites More sharing options...
DavidBanner Posted August 16, 2007 Report Share Posted August 16, 2007 1st question - have you uploaded the SID application on top of MIOS (sorry gotta check this 1st, even though I'm pretty sure you have if the LCD works)?if so it might be time to try one of the test applications which show all DIN, DOUT, AIN stuff going on in real time Quote Link to comment Share on other sites More sharing options...
TK. Posted August 16, 2007 Report Share Posted August 16, 2007 There are some simple tests which allow you to check, if the problem is related to the DIN module connections. Details are described here: http://www.midibox.org/dokuwiki/doku.php?id=din_moduleBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
