The Pedal Box and Pedal Board Thread
Durisian
Alright, I got past a few hurdles with much easier than I expected, so I've put the new version up.
The major updates:
  • Device maps are now for CC's and program changes only. And must be placed on the list in the matching parameter 1 place.
  • I can't make it fit on PIC18F452, no matter how hard I try
  • Can select the 'type' of midi message when setting buttons and expression pedals
  • Lots more error checking/correcting put into place, much more stable usage
  • MIDI Input/Merger speed now very fast
The PC Editor will try to update your master bankstick file, but it will be full of incorrect info, that if not checked and updated before uploading will cause problems when using pb, so I recommened re doing it from scratch (sorry).
Device banksticks should be fine if they;ve already been listed with CC's and Program changes in the proper folder and put in entries that match their parameter 1 value.
Otherwise you'll need to re do them as well.
2 bugs I found so far, both are 'still' and pissing me off
-Tap Tempo led doesn't work until another button is pressed.
-LCD goes a bit giberish until you make a program change.
Let me know of anything else
ENJOY!!
edit:
fonebone: I'm curious to know if the LED's update when doing a program change for your HD147.
For some bizzare reason I can't make my v-amp output the data to test it
Hi all,
I'm new here and I've been reading about this MIDIBox project for a while now and think it will fit my needs. I want to use it as a pedal board. I'm just wondering if the number of relays can be easily expanded to 16. This way I would have enough effectloops, can switch channels on an amp and even use 3 relays to switch the order of the effects.
Thanks in advance ;D.
Frank
Durisian, thanks for the swift reply.
Ok. Clear enough answer.
By "massive programming effort" do you mean on the MIOS side or just the user application?
I'm leaning towards your "pedalboard" design because it covers all of my needs, exept for the number of relays :-[
Frank
knarf: Just on the user app side of things.
Getting relays to trigger from a button, or by midi input wouldn't be to difficult at all.
It's getting them to work as part of a rig control patch that's the problem.
It would require a massive change in the order data is stored on the master bankstick.
Which then involves going through every line of code to punch the right locations in.
Having had to this 3 times during the development of pedal board - I can assure you it's a lot of pain and suffering. :(
With the FX looper concept, rig control can still trigger the relays via midi, and they can still be assigned to a button.
The only real difference is how you setup pedal board to trigger relays in the looper. The end result will be the same.
@Durisian
today i've tried  to build the last version of pedalbox/board.... but there are some errors and no hex file in the end.
regards
FoneBone
EDIT:
and why I try to upload 2.5 beta1 with MIOS Studio I get this error message:
Error: Received unexpected Upload Request
Received error code 0B: MIDI IN Overrun Error
I've attached a screenshot of compiling beta2.
And I've checked the option by uploading beta 1, but I get these errors. After these errors the upload stops and nothing happend, so I've to restart Windows before starting the next upload. STRANGE!
Starting upload of project.hex
Received Upload Request
Sending block 00003000-000030FF
Received Checksum: 69 - OK
Sending block 00003100-000031FF
Received Checksum: 60 - OK
Sending block 00003200-000032FF
Received Checksum: 40 - OK
Sending block 00003300-000033FF
Received Checksum: 07 - OK
Sending block 00003400-000034FF
Received Checksum: 5A - OK
Sending block 00003500-000035FF
Received Checksum: 67 - OK
Sending block 00003600-000036FF
Received Checksum: 73 - OK
Sending block 00003700-000037FF
Received MIOS SysEx message of unknown type '00007E4000F000007E40000E0B01F7'
Received SysEx message of less than 8 bytes
Received unexpected MIOS SysEx message = 00007E400E0B01F7  expected = 00007E4000
3780_errors_jpg525885e5d126f77647c9f2b12
Compile issue:
line 1253 should be suspend_LCD();
it was: suspend_lcd();
Beats me why mine compiled and yours didn't. Got me worried now, because mine should have spat out that error too.
updated, give it a crack
MIOS studio issue.... to be honest, beats me.
Have you updated java or something recently, anything you've changed since you last tried to use MIOS studio.
can you upload a basic app - like din buttons from the download section on ucapps?
you can also try re-uploading MIOS 1.9f. no idea if that will help
Compile issue:
I've changed lcd() to LCD() and it works. Now I have to take care of the MIOS problem. Will report later.
Thanks.
EDIT: Problem solved. I followed the link you gave me and, I don't know why, the settings of my Sysex configuration was wrong. Now everything seems to work fine. I will test the board next tuesday, maybe earlier.
Thanks again.
I've got bad news: Pedalboard didn't recieve anything from my HD147, even though I pushed the programm- and tap-button at the amp itself. I will test the amp next time with MIDIox. Maybe it will spit out anything  ;)
No MIDI at all! ???
make sure you've enabled midi input. Could also be the master bankstick merger disable feature
set pbx_config.h like this:
#define   ENABLE_MIDI_IN         1  // 1 = yes      0 = no
#define   MIDI_MERGER            1  // 0 = off   1 = on
#define   MIDI_MERGER_DISABLE_MASTER 0  // 0 = enabled   1 = disabled - If set will disable forwarding of events on the master bankstick channel
Can you post your pbx file again?
Bad News:
I think it is not possible, to recieve the information from the HD147 that I want. Yesterday I plugged the HD147 to MIDIOx and that's what I get.
Pushing one the the four preset buttons:
 TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
 00001601   1   1     C0    02    --    1  ---  PC: Elec Grand Piano
When I push the TAP-button, hold it and press one of the preset-buttons, I get this:
 0001B85B   1   1     B0    40    7F    1  ---  CC: Pedal (Sustain)
 0001BD99   1   1     F0  Buffer:   168 Bytes   System Exclusive
 SYSX: F0 00 01 0C 03 74 04 43 6C 65 61 6E 31 20 20 20 20 20
 SYSX: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
 SYSX: 20 20 20 00 00 00 00 7F 10 02 7F 7F 55 00 00 16 7F 7F
 SYSX: 7F 77 59 00 00 00 7F 7F 23 23 00 7F 00 7F 13 20 06 00
 SYSX: 40 33 02 7F 03 40 36 13 00 00 00 00 00 00 7F 00 00 7F
 SYSX: 00 50 00 00 00 40 7F 03 00 00 49 21 00 00 00 00 00 00
 SYSX: 00 02 0F 00 00 00 00 7F 00 00 00 00 00 00 00 00 5E 00
 SYSX: 7F 05 09 04 0E 3F 43 45 45 00 00 00 00 00 00 40 47 0F
 SYSX: 00 3F 7F 00 00 00 00 7F 00 00 00 00 00 00 00 00 00 00
 SYSX: 00 00 00 00 00 F7
But as you told, SYSEX isn't supported till now  :(
Greetings
FoneBone
that kinda sux
pbx file looks fine
What info does the 147 spit out when send a program change event via midi?
I'll have another look through the line6 manual
(I'm also flat out with work till the end of the year)
Did you get midi in to your pedal board working?
wait.... MIDI_MERGER needs to be off!  :-[
