to clarify:
protos were $25 each (which is still less than sparkfun, since one of these == 2 of theirs) talking to SmashTV, it sounds like we can get a small run done for under $15 per brd (about half sparkfun price) with ENIG so contacts should be fine without extra effort required.
so for example, to make an 8x8 monome like thing (i think i'll call mine "the thing" since that's what SmashTV has been calling it and he's my guru *whack*), you would need two of these brds and 4 button pads from sparkfun.  it might be a good idea to combine a bulk order of button pads with the brds.
note that this is not a project for beginners, but it was my first SMD work and wasn't too hard.  and way easier than it would have been to wire all the dins and douts on other brds.  the second brd went quite quickly since i already had the hang of it.  people with steadier hands than mine should have no trouble at all.  since you must solder chips directly to brd without sockets, an ESD safe soldering iron is highly recommended.
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
who s told you that ?
perhaps you misunderstood that sentence, since it is a little off topic.  we were talking about other ways to get silicon buttons than the sparkfun ones.  quality tact buttons don't need to be debounced.
if you are questioning the "more durable" part, it is i guess SmashTV's opinion that the sparkfun buttons may wear out sooner.  (Not that the guru has nameized me to speak for him *whack*) i think it is a reasonable opinion, since quality tact buttons are rated for millions of pushes...
.. you ve never been pushed by me then !  ;)
  well i only wanted to underline that i had to debounce so called good quality switches.. yes yes it is you Mr RJS switches i am talking about! but that was my fault to think that expensive=good
just don t assume you won t have to debounce any tactile switch..
simone
  • 2 months later...
As TK made BLM example I wonder what is happening with this project?
i will try the new example this weekend.  the only new features are the debounce
(woohoo!) and direct midi control of the leds.
i still need to try cool-amp on an unpopulated pcb and/or fix the one i tried to
cool-amp after it was populated, but if any more pcbs are made, they should
have ENIG which will be much better than cool-amp.  but there didn't seem to
be so much interest in a run of pcbs...
hey
J (and whoever) i ve miserably failed my first PCB for the sparkfun buttons, i have to say i didn t tried it out yet but it looks like a piece of ship (a wrecked one) or like a piece of sheep (a dead one), terrible vias, shortcut pads, badly cut dimensions, a disaster.If that s going to work anyway .. i ll call it a miracle and make myself priest
i need to redraw the layout on eagle, move the vias which are on the pads out of there so they won t interfere with the buttons pressure zone.
I tried the cool amp thingy (tx smash and jimp) it goes without effort on an unetched board.
i ll give it another go, if it doesn t work this way i ll have to ask mr olimex to do the dirty job for me, with a real unpleasant feeling of failure by my side, that s life.
updates soon
hey
J (and whoever) i ve miserably failed my first PCB for the sparkfun buttons,...
that's a shame.
hope it works out in the end.
hey
I feel sorry for you but it is funny how you describe the PCB.  ;D ;D ;D
I didn`t understand you quite right, but did you fail with your PCB`s or sparkfun`s. Didn`t looked like much difficult to me. What was the problem about it?
hi
i don t (and can t) use sparkfun s pcbs cause i have a 2x8 and 2x5 (you should know that ;) matrices so i etch the damn thing by myself.
ahem, so on the subject at hand....
new code from tk fully tested.  (see this thread http://www.midibox.org/forum/index.php/topic,10476.0.html)
cool-amp residue mess cleaned from test subject.  (don't try to cool-amp a populated pcb - the residue is conductive and winds up stuck everywhere)
with debounce and no hasl in the way, these buttons behave reliably.
only time will tell how often they need cleaning, mtbf, etc...
next up: mounting method and panel cutting.
sparkfun sells a acrylic baffle for this, but it's expensive and i don't like it, so i'm thinking.
of cutting my own or just using strips between the buttons to hold the silicon part down.
probably will make a frontpanelexpress panel for a "duome", but need to decide if i also want lcd and encoders...
it might be a while before i get there, what with all the other stuff i'm into.
to be continued....
hi
i don t (and can t) use sparkfun s pcbs cause i have a 2x8 and 2x5 (you should know that Wink matrices so i etch the damn thing by myself.
Sure I know your placement on panel but I thought you will cut the sparkfun`s PCBs. I would do that. Sure, you wan`t have all the connecting pads, but could be improvised.
Self made PCB contacts oxidate if you don`t coat it somehow. I would never try to make anything like that myself and think it one of those things that really needs to be industrial grade not DIY. Or maybe I`m wrong.
i hope to demonstrate that you are wrong, soon.  ::)
and i ve never thought to do the PCB cutting, it s just a damn good idea.
pay attention class... this is what the cool-amp does...
also note: the pcbs i'm using are manufactured, but HASL is actually worse than bare copper for contacts.
i think we can agree the best thing for this purpose is pro pcbs with ENIG
but the cool-amp coated contacts are working great.
now if only my buttons weren't "depressed" hehe...
we talked about this in the chat, lo those many moons ago...
remember, the sparkfun pcbs don't have isolation diodes so they don't work
properly in a matrix, in your case you would want to cut all the matrix
traces and use them as individual buttons.
still might be easier than etching your own...
:o ;D ;D ;D
it just works !
it works perfectly, i haven t noticed any "lost hit" or "double hit"
uh oh :-X
it just works !
excellent! you didn't enable debounce??
try pressing softly and slowly...
uh oh
the guru priest!
That is nice to hear. I need to start writhing down my "to be build" list. I starting to lose myself in all those projects I`m working on, the ones I need to start soon and the ones I didn`t started yet but MUST be built like this BLM trigger. Need to "lock" building order and priorities If I want to finish something soon.  :P
hi
since i have to do home brew vias, soldering  a small cable from top layer to bottom layer i decided to move the vias out of the button pads, here s a preview:
1951_16buttons_jpg52caefe8584be4235598b0
sorry but atm only phone camera
you see the vias have been moved out of the buttons pads so they won t interfere, all holes (via, pads,etc) are 0.6mm to help routing the drill bits.The holes for those little pins of the Sparfuns are 3mm (i ve cut off a full line of them, where the pads for the DIL sockets are), holes for the mounting screws are 2.5 mm.Boards etched with PnP Blue (i use a couple of paper sheets under and above the pcbs when ironing to "spread" the pressure evenly, sand with 600 and treat with isopropil), 50% muriatic acid and 50% peroxide 30vol, it etches in about 30 seconds.Finally the board was treated with cool-amp.
simone
1977_SP_A0514_jpg40a4b80c7f54ff5080e57fb
  • 1 month later...
Do you guys use the rgb sparkfun leds?
And what is the status of this project?
I am looking to use this in the matrix board for sequencer.
hi
no i use bicolor leds from ledtuning.nl but beware that they are common anode.
I would wait a bit if you don t want to experiment yourself.Afaik both me and Bugfight are doing other stuff atm so i can t offer a finished idea/development for those buttons.
Anyway i can confirm that they are fully usable for MBs
simone
Thanks Simone,
It is because i just bought a monome 40h kit and finished it.
However it is not worth the price.
On my planning is still a 4x16 grid button monome clone with midi and the 4x8 + 4x1 grid for mbseq 3.
So i was just wondering how far you guys are.
