Echopraxia Posted October 14, 2007 Posted October 14, 2007 I am looking at an old moog ribbon controller and was curious if these can be used in a midi setup or possibly through the AIN connections on the core. It works on Micromoog, Multimoog, Polymoog and Liberation models terminates with a 3 prong connector.
doc Posted October 14, 2007 Posted October 14, 2007 Hi,I don't know the moog ribbon controller, but with three cables .....Maybe it works like a pot?Can you measure the resistance between the outer cables.Then try to measure, if the resistance change between the first and the second pin when slide on the controller.If it works not that way (with a simple resistance change) it would be not that easy to use (maybe incuctive?).greetsDoc
Echopraxia Posted October 14, 2007 Author Posted October 14, 2007 Sorry can't test it. Some guy is selling these.
levon Posted October 19, 2007 Posted October 19, 2007 i saw a documentary on Moogs being made.. heres the info page of it herei remember something about the xypad just being a plate of metal that contacted with your finger... i cant figure out how it would work. maybe have a look round some torrent sites and you might find it.
audiocommander Posted October 19, 2007 Posted October 19, 2007 dunno if I can help:there are two common types of these sensors I know of:- capacity based (requiring no pressure like the iPod clickWheel)- resistance based (two layers touch at a certain point)pressure based is quite unlikely.the fact that this thing has three connectors might point towards the resistance type.if it's a real Moog Ribbon Controller, it should be resistance based as well, because in german the moog rc is called "Widerstandsband" (Resistance Band).If it has a good size with a good prize ;D, I'd take the risk.Best,Michael
