Hi all,
I am following Duggle's power supply, as seen here, using a 12 V AC powerpack / wallwart. The problem is that the wallwart was supplied with bare cables and no markings what could be ground, so I can't work out what to connect to the ground of my breadboard of Duggle's circuit!
I haven't done any AC stuff before so bear with me here: with a DC PSU I would measure across + and - and look at the polarity shown on my multimeter. I have an AC setting on the multimeter and I have used this to measure across both outputs on the wallwart, but connected either way the multimeter shows no polarity. Any suggestions?
I presume it does matter which is negative and positive with such a wallwart?
Thanks in advance for any help
Dave mK
I had a feeling that would be the case, just wanted to be sure before frying anything :)
so I will connect up the cables this evening with a bit more confidence, thanks.
D
