Hi
i am trying to recompile the mbsid v2 for a minimal control surface (i do it while waiting the panel and the tact switches ... so long, i love this bassline) and i did as i used to do with sidv1.7. But unsuccessful, MPLAB gives a lot of "Address exceeds maximum range for this processor."
i am editing mb8580.asm and "quickbuild option". If i don't edit the .asm and just try to quickbuild, i got the problem too !
What's the problem ?
thanks in advance
You are using an older MPLAB release where PIC18F4685 is not supported?
Or you selected the wrong PIC?
However, I don't know what you mean with "quickbuild" - the fastest way is to use MPASMWIN directly, and here you shouldn't notice such issues.
i was using MPLAB IDE for editing the .asm
quickbuild is in a menu
using MPASWIN to assemble (and i choosed the good pic - 16f4685-) solved the problem.
thanks a lot TK !
