Mr. MIDI (MIDI recorder on SD card with LCD)
Sasha
This is one cool open source AVR project I stumbled across today while browsing AVR Freaks projects.
    FEATURES:
    * Works with most cards, max size is limited to 2GB (but please also note, cards 32MB and below could use FAT12, which is not supported)
    * Real MIDI files on FAT16 (Midi format 0 only) - recording (only root dir) and playback
    * Maximum of 255 files per folder*
    * Displays the file names - long names are supported - filename scrolling*
    * File delete is possible (it can delete any file from the root directory)
    * 256 byte input/output buffer and 8MHz clock for high performance and precise MIDI timings
    * Lyrics are displayed (when contained in MIDI file) - cool!
    * Variable speed (+/-15 steps) and transpose (+/-24) while playing a file
    * MMC/SD card bootloader - just format a card, copy generated MM.BIN onto it, insert it and switch ON!
    * MIDI channel mute for each channel
    * Menu for setting up drum channel, lyric display, repeat modes, channel mutes and track delay*
    * Settings are stored in non-volatile EEPROM on-chip
    * IR remote control (RC5 protocol), a Philips videorecorder remote for example. Or get a programmable remote and use code 257 (for a Philips VCR).
    * Several song repeat modes (song, folder, random, non-stop)
LINK: http://www.lehmayr.de/e_mrmidi.htm
and same thing as kit: http://www.sdmidicontroller.com/
I've been fiddling around with CF cards in MIOS for quite some time, but for some reason I cannot properly access them. I have tried more than one adaptor/connector, and there is quite some info including code on the net. All my work is quite undocumented, unfortunately  :-[.
You might want to look here, these are my sources:
http://archive.chipcenter.com/circuitcellar/february01/c0201ms1.htm
http://www.armanet.com/html/compactflash.html
http://www.compuphase.com/mbr_fat.htm
I did not look into FAT support, I was only going to use the card as plain memory.
Best regards, ilmenator
