ptitjes Posted December 14, 2007 Posted December 14, 2007 Updated :Starting some documentation : http://www.midibox.org/dokuwiki/howto:dev:autotools-skeletonNew release: 1.9f-r1Merry Christmas!Cheers, Didier.To Do :Cut libcmios in one object file per functionChangelog :1.9f-r1 (2007-12-21)Made mios-pic16-toolchain, libcmios and the skeleton itself to follow the same version scheme (MIOS version - release number)mios-pic16-toolchain Fixed installation of tool symbolic links Fixed management of installation prefix[*]libcmios: Removed now unused mios_tables.inc1.9f[*]Initial releaseHi all,Time maybe has come for me to publish a bit of my homework during the past months.In my quest to simplify the C skeleton, i wanted to achieved the following goals:1) Not having identical files in different applications2) Having a makefile system that is easily extensible (don't want to have to make rules for simple things and want to make simple rules for complex things), enables directory hierarchies, that encompass by default all my wanted targets (all, clean, install, dist, dist-check...)- Goal 1) required the mios wrapper itself to be put elsewhere than in the skeleton. Why not having a libcmios library ? Hopefully gplib can make shared libraries and gplink can grap object files from them and link them statically inside the application. Cool!- The mios-specific linker scripts also had to be put in a shared location. I decided to follow the usual rules of sharing for cross-compilation... having a directory that is specific for a host platform that contains headers and libraries. (${prefix}/host/)- The mios-specific asm fix script was a problem. But thinking about Goal 2) makes my try the autotools and I quickly understood how they were fullfiling Goal 2) completely. So I decided to make a wrapper script around sdcc, gpasm, gplib and gplink, that would take care of transparently fixing the asm, and that would use the GCC command line style: C compiler to compile for target processor-vendor-os is processor-vendor-os-gcc Asm compiler to compile for target processor-vendor-os is processor-vendor-os-as Librarian tool to make libraries for target processor-vendor-os is processor-vendor-os-ar Linker for target processor-vendor-os is processor-vendor-os-ldSo here is the result. You can find an attachement in this post that contains libcmios-1.9f.tar.gz mios-pic16-toolchain-0.1.tar.gz mios-c-skeleton/Possible targets/hosts are:pic18f452-microchip-mios, pic18f4520-microchip-mios, pic18f4620-microchip-mios, pic18f4685-microchip-miosNote that pic18f452-mios, pic18f4520-mios, pic18f4620-mios and pic18f4685-mios are automatically expanded.I will document this better in the Wiki in some days.Install the toolchain wrapper, libcmios and its linker scripts...: $ cd mios-pic16-toolchain $ ./configure --target=pic18f4685-mios --prefix=/usr $ sudo make install $ cd ../libcmios $ ./configure --host=pic18f4685-mios $ sudo make install As for the skeleton itself... Modify the configure.in, Makefile.am, src/Makefile.am and main.c... and then configure and make the application : $ autoreconf --install $ ./configure --host=pic18f4685-mios $ make mios-autotools-skeleton-1.9f-r1.zipmios-autotools-skeleton-1.9f-r1.zip
ptitjes Posted December 14, 2007 Author Posted December 14, 2007 Also support for pic18f4685 comes with sdcc-svn (has a package on Gentoo) and gputils-0.13.5!
audiocommander Posted December 15, 2007 Posted December 15, 2007 wow, that sounds great!!! :DI hope I find some time in the days past christmas to give it a try; got some 4620's lounging around in drawers that just waited for a service like this ;DThanks and Cheers!Michael
TK. Posted December 15, 2007 Posted December 15, 2007 I find this approach nice. I considered to use autoconf as well at the beginning, but found it complicated and not flexible enough for different operation systems. E.g., under Windows a Cygwin installation is required, but I fear that a normal MIDIbox user is already overloaded enough by installing perl/SDCC and GPASM :-/Therefore I started the simple "perl makefile generator" approach.However, this shouldn't prevent you to start with a more proper setup of the SDCC skeleton! Feel free to enhance it in future, but please also understand that I will continue to maintain the "simple solution".Best Regards, Thorsten.P.S.: converting the wrapper to a shared library is an elegant idea, on the other hand: is the linker able to ignore (not link in) the code which isn't used by the project? Here I see the only benefit of a library
ptitjes Posted December 16, 2007 Author Posted December 16, 2007 However, this shouldn't prevent you to start with a more proper setup of the SDCC skeleton! Feel free to enhance it in future, but please also understand that I will continue to maintain the "simple solution".Yé! I understand that! I was thinking about that keeping the "simple solution" along to it however when i wrapped the mios wrapper in a library i lost the ability to use the perl script... However i still wish to reintegrate it in a latter time!P.S.: converting the wrapper to a shared library is an elegant idea, on the other hand: is the linker able to ignore (not link in) the code which isn't used by the project? Here I see the only benefit of a libraryIn fact, this is one bonus of the library approach! http://gputils.sourceforge.net/reloc_howto.html says :gplink will only extract those archive members that are required to resolve external references. So the application won't necessarily contain the code of all the archive members.(archive members are individual relocatable object files aka ".o")So, this means that the mios wrapper must be split in multiple asm files to make multiple objects. So that the linker extract only the ones needed by the application. So i think, there should be one core object file for the user callback vector definition, and one for each big features : DIN, DOUT,...But this scratches my head constantly that in fact that should be MIOS itself that should be cut in libraries. A core MIOS with just the bootloader (and MIDI-stuff used for the bootloader) and a series of libraries for each big features. I could help in splitting it if you would choose that for a latter major version of MIOS. If you want i can experiment on that so that we can see if it feasible of not!PS: Another bonus of the library approach is that i was forced to find a C macro way for defining the MIOS_ENC_TABLE and this is cool :)
TK. Posted December 16, 2007 Posted December 16, 2007 Yes, it would be possible to split the MIOS functions over different .o files instead of using a single kernel, but it's a different approach and leads to disadvantages. I already evaluated the micro-kernel approach ca. 2 years ago, there are so many dependencies between the modules, that a seperation leads to a higher memory consumption that we currently have if all MIOS functions are included in a static kernel (e.g. you have to isolate internal variables, e.g. by using a stack, and you have to use the 4-byte instructions "goto" and "call" more often than the 2-byte instructions "rgoto" and "rcall"). It's also more difficult to provide MIOS updates to users who are less experienced with programming like you (don't know, how many users really know how to recompile an application, especially when they have to use so many different tools).However, if I would design MIOS today, I would consider this from the beginning, especially because it would free some extra memory for applications which don't use a graphical display or motorfaders (functions which are only used by a small number of applications). I would also define the function interface SDCC like so that an assembly file conversion, which changes the FSR pointers, wouldn't be required anymore.But I don't plan to do this for MIOS V1, accordingly you don't need to try this out again - it would be wasted effort...Splitting the wrapper functions over different files makes sense, I would split them all.Best Regards, Thorsten.
ptitjes Posted December 16, 2007 Author Posted December 16, 2007 I see your point for the necessary user skill-level for such an approach... Configuring and compiling my linux kernel seems natural to me now but this has not always been the case.However, if I would design MIOS today, I would consider this from the beginning, especially because it would free some extra memory for applications which don't use a graphical display or motorfaders (functions which are only used by a small number of applications). I would also define the function interface SDCC like so that an assembly file conversion, which changes the FSR pointers, wouldn't be required anymore.And maybe eliminating the need for a C wrapper completely but providing helper functions like PrintCString()!But I don't plan to do this for MIOS V1, accordingly you don't need to try this out again - it would be wasted effort...OK! I asked because i have so many other things on fire... However, i understand that you suggest that could be a decision for a redesign/rewrite for a V2 (surely also if it must support not only PIC but another processor family). So when the time will come, I volunteer to help you setting up the tool-chains and splitting MIOS!Splitting the wrapper functions over different files makes sense, I would split them all.Heu... not sure to understand! Are you saying you will do it or are you saying that if you were me, you would split each and every function in it own file ?? (Wooow!! :o ::)) In fact, i can see this is the approach they have choosen for the sdcc libs...I'll have to make a script to automate this... else I'm too lazy!
TK. Posted December 16, 2007 Posted December 16, 2007 Heu... not sure to understand! Are you saying you will do it or are you saying that if you were me, you would split each and every function in it own file ?? (Wooow!! :o ::))Yes, thats the way how I normaly create libraries - it's the most effective way.In fact, i can see this is the approach they have choosen for the sdcc libs...I'll have to make a script to automate this... else I'm too lazy!You can do this if you have the time, but please do it in a way which allows to rebuild the library on a simple way without the need for installing a massive tool chain. So, rebuilding a .lib file should even work under Windows without installing Cygwin (or another unix environment)I would use a perl based makefile generator for this, which creates a .bat file (for windows) and a Makefile (for unix) based on an ordered list of all sources.Once the functions have been extracted, there is no need to re-do this process. So, first check if it is faster to do the extraction by hand (I would estimate an effort of about 15 minutes), or writing a script which you will probably only use one time, and never again ;-)All you need is a powerful text editor (IMHO)Best Regards, Thorsten.
ptitjes Posted December 17, 2007 Author Posted December 17, 2007 So, rebuilding a .lib file should even work under Windows without installing Cygwin (or another unix environment)I'm really not sure that you need Cygwin to run autotools on Windows:http://gnuwin32.sourceforge.net/packages/autotools.htmBut i can't test that as I don't have any Windows at hand! And i surely never won't anymore...Anyway I don't know what dev. you can do without any decent make utility.
TK. Posted December 17, 2007 Posted December 17, 2007 The problem is, that you need to specifiy DOS style pathes (with backslash) in the configuration files. For "make" there is the same requirement, and in addition all DOS make implementations I know ignore the PATH variable, so that tools need to be specified with absolute pathes. Accordingly, the Makefile* looks very different.At least these were the issues which prevented me from setting up the common Makefile approach for the SDCC wrapper, and why I decided to create a simple makefile generator which allows to create a batch file.I'm not really a DOS/Windows fan (in fact I work under Solaris/Linux @ Work, and mostly under MacOS @ Home), but I find it important to provide an universal solution, so that everybody is able to contribute, and not only a small group of people who have the right OS installed.We already have this issue with MPASM (which runs only under Windows), please don't do the same error like me with a new approach.Best Regards, Thorsten.
ptitjes Posted December 17, 2007 Author Posted December 17, 2007 According to http://gnuwin32.sourceforge.net/install.html :The MS-Windows command interpreters, command.com and cmd.exe, understand both the backward slash '\' (which is the default) and the forward slash '/' (such as on Unix) in filenames. In general, it is best to use forward slashes, since some programs internally use the filename, e.g. to derive a directory name, and in doing this rely on the forward slash as path separator.As for the PATH variable i think this has been corrected. And the interest of autotools is that it can generate makefile differently for the platform it runs on. There are also extensive discussion in the autotools' manuals about support of Win-specific filenames... so this should be tested by one that has Windows. If someone can test autotools on Windows, i likely want to make the autotools skeleton more portable. And again i think there is not too much work.Else, Cygwin is, IIRC, really easy to install. Something like a two click setup program. Generally, people that begins with programing on Windows never practiced cmd.exe before. So, really, we should immediately recommend them to install Cygwin. Learning DOS shell or learning POSIX shells is the same from a learning curve point of view, except that there are POSIX shells available for all platforms and no other plateform than Windows with a DOS shell.I completely agree that to reduce work, there should be the minimum of officially supported programming ways. But here is how I see it : MPASM is not a common case as it only runs under Windows. gputils and sdcc runs on all your supported platforms. So why not drop official support of MPASM and let people on their own if they want to experiment with using MPASM.By the way, it make a while now that I'm really wondering what Midibox's users are using as development platform... Would you mind if i make a poll on the forum ?Best regards, Didier.
TK. Posted December 17, 2007 Posted December 17, 2007 As for the PATH variable i think this has been corrected. And the interest of autotools is that it can generate makefile differently for the platform it runs on. There are also extensive discussion in the autotools' manuals about support of Win-specific filenames... so this should be tested by one that has Windows. If someone can test autotools on Windows, i likely want to make the autotools skeleton more portable. And again i think there is not too much work.Ok, I will check it this evening and give you feedback. I haven't expected that the development still continues, I did the evaluations ca. 2 years ago, and only found unix ports with flaws... completely agree that to reduce work, there should be the minimum of officially supported programming ways. But here is how I see it : MPASM is not a common case as it only runs under Windows. gputils and sdcc runs on all your supported platforms. So why not drop official support of MPASM and let people on their own if they want to experiment with using MPASM.Problem is, that most of my own assembly programs can only be assembled with MPASM due to the more powerful macro pre-processor. Some time ago I wanted to switch all my programs to a GPASM friendly format without these macros (could be automated easily) but I felt handicaped while programming without my beloved IFSET and IFCLR macros. And there are more complex macros, e.g. in the MBSID firmware, which cannot be replaced on an automated way, and where the code looks really ugly if you try to transform them into multiple lines...A solution would be to extend the GPASM macro processor, but after I looked into the source code I noticed that this won't be an easy task (at least for me)However, the SDCC wrapper on the other hand cannot be used with MPASM. All C based, and some of my newer small applications (like the MBHP_IIC_* and MBHP_USB_PIC firmwares) are completely GPASM compatible.For people who are not writing so much in assembler, or who are not used to work with complex macros, don't have any disadvantages here though...You can start a poll, but I think the result is clear: there will only be one person who prefers to work with MPASM, and thats me ;-)Best Regards, Thorsten.
TK. Posted December 17, 2007 Posted December 17, 2007 Ok, I checked the GNUWIN32 status and found out, that it is very similar as some time ago - you still need Cygwin (at least bash) to use the tools like "configure", and you need to install a lot of additional packages in order to get the toolchain running.So, I think that two or three independent windows users should evaluate your approach, if it is easy enough to understand, especially when a certain tool doesn't work immediately. I won't give much more comments anymore to ensure that nobody is influenced by my own oppinion (which might be too conservative?). The result should be a clear picture, if people who have used MPASM (see http://www.ucapps.de/howto_tools_mpasm.html) for assembly based firmwares, or the current SDCC setup http://www.ucapps.de/mios_c.html) in the past, will be able to rebuild the source code of an application if it is completely handled by autotools with similar 1-2-3 instructions (install this, install that, push the button).Note that most users who have to (re-)build an application are not programmers, they maybe only want to configure their MIDIbox and create a new .hex file with hardware specific settings. Therefore it would be important that after a basic windows setup has been found out, some additional users without programming knowledge try to rebuilt a .hex by themself based on instructions.Note: if the concept works, then an "all-incusive installation package" could be created.Best Regards, Thorsten.
ptitjes Posted December 18, 2007 Author Posted December 18, 2007 I don't say your approach is too conservative! You work on this project for now more than 5 years. Project span is really big and the use cases are numerous. I think you might have seen many many recurring user questions and problems. So you are certainly at the best seat to see what could be a new issue or difficulty for your users.As for the gpasm macro preprocessor, i'll look whether/how/if i can extend it... I must delve more into the MBSID code and also look further into the MIOS code to see what those macro looks like. Also maybe a pre-preprocessor is possible... I won't have to do that before January but i put that on my task list.Anyway I like the installation package idea!I'll document my approach on the Wiki during this week. Then we'll see if some users, including Windows-based, can test it! That feedback will make me figure out how to help and document with a transition scheme for those who wants to use it.Best regards, Didier.
Narwhal Posted December 18, 2007 Posted December 18, 2007 This seems like a good time to chime in that I've been having some problems following your installation instructions on OS X. I don't have my mac with me at the moment, but I can try to post the specifics later. I started to write a detailed post yesterday, but Safari crashed when I pressed the post button grrr.Anyway, I'm having trouble getting the configure steps for both libcmios and you other package libcan to complete. It's not locating the pic18fregs.h file. For more detail I'll have to try to post again when I get home. The mios-pic16-toolchain configured and installed fine for me.$ cd ../libcmios $ ./configure --host=pic18f4685-mios ... <errors here> both gputils and sdcc are installed in /usr/local/bin with libraries and headers and such located in /usr/local/share, /usr/local/share/sdcc. The file its trying to locate is in /usr/local/share/sdcc/include/pic16/Kurt
ptitjes Posted December 18, 2007 Author Posted December 18, 2007 Kurt,There is a DEBUG=0 at the beginning of the mios-pic16-tool-wrapper script.(It is located in /usr/bin or /usr/local/bin depending what prefix you put in the configure of mios-pic16-toolchain.)If you put DEBUG=1 instead you'll have the commands it really runs instead of gcc. Could you tell me what sdcc command it runs ? (Or maybe put all the output)I do process the -I___/sdcc/lib/pic16 option so it may come from that...Best regards, Didier.
Narwhal Posted December 19, 2007 Posted December 19, 2007 running configure always seems to print the same thing, so I've condensed it. ~/Desktop/mios-c-skeleton/libcmios-1.9f$ ./configure --host=pic18f4685-mios --prefix=/usr/local ... ... checking for pic18fregs.h... no configure: error: Can't compile without PIC header files See `config.log' for more details This is the log file: ~/Desktop/mios-c-skeleton/libcmios-1.9f$ cat config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by libcmios configure 1.9f, which was generated by GNU Autoconf 2.61. Invocation command line was $ ./configure --host=pic18f4685-mios --prefix=/usr/local ## --------- ## ## Platform. ## ## --------- ## hostname = static-003.local uname -m = Power Macintosh uname -r = 8.11.0 uname -s = Darwin uname -v = Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00 PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC /usr/bin/uname -p = powerpc /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = Mach kernel version: Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00 PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC Kernel configured for up to 2 processors. 2 processors are physically available. Processor type: ppc7450 (PowerPC 7450) Processors active: 0 1 Primary memory available: 2.00 gigabytes Default processor set: 65 tasks, 188 threads, 2 processors Load average: 0.87, Mach factor: 1.24 /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /bin PATH: /sbin PATH: /usr/bin PATH: /usr/sbin PATH: /Developer/usr/bin PATH: /usr/local/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1792: checking build system type configure:1810: result: powerpc-apple-darwin8.11.0 configure:1832: checking host system type configure:1847: result: pic18f4685-microchip-mios configure:1977: checking for a BSD-compatible install configure:2033: result: /usr/bin/install -c configure:2044: checking whether build environment is sane configure:2087: result: yes configure:2115: checking for a thread-safe mkdir -p configure:2154: result: ./install-sh -c -d configure:2167: checking for gawk configure:2197: result: no configure:2167: checking for mawk configure:2197: result: no configure:2167: checking for nawk configure:2197: result: no configure:2167: checking for awk configure:2183: found /usr/bin/awk configure:2194: result: awk configure:2205: checking whether make sets $(MAKE) configure:2226: result: yes configure:2306: checking for pic18f4685-microchip-mios-strip configure:2336: result: no configure:2346: checking for strip configure:2362: found /usr/bin/strip configure:2373: result: strip configure:2442: checking for gpasm configure:2458: found /usr/local/bin/gpasm configure:2470: result: gpasm configure:2490: checking for style of include used by make configure:2518: result: GNU configure:2548: checking for pic18f4685-microchip-mios-gcc configure:2578: result: no configure:2588: checking for gcc configure:2604: found /usr/bin/gcc configure:2615: result: gcc configure:2853: checking for C compiler version configure:2860: gcc --version >&5 powerpc-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build 5370) Copyright (C) 2005 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:2863: $? = 0 configure:2870: gcc -v >&5 Using built-in specs. Target: powerpc-apple-darwin8 Configured with: /var/tmp/gcc/gcc-5370~2/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=powerpc-apple-darwin8 --host=powerpc-apple-darwin8 --target=powerpc-apple-darwin8 Thread model: posix gcc version 4.0.1 (Apple Computer, Inc. build 5370) configure:2873: $? = 0 configure:2880: gcc -V >&5 gcc: argument to `-V' is missing configure:2883: $? = 1 configure:2906: checking for C compiler default output file name configure:2933: gcc conftest.c >&5 configure:2936: $? = 0 configure:2974: result: a.out configure:2991: checking whether the C compiler works configure:3001: ./a.out configure:3004: $? = 0 configure:3021: result: yes configure:3028: checking whether we are cross compiling configure:3030: result: no configure:3033: checking for suffix of executables configure:3040: gcc -o conftest conftest.c >&5 configure:3043: $? = 0 configure:3067: result: configure:3073: checking for suffix of object files configure:3099: gcc -c conftest.c >&5 configure:3102: $? = 0 configure:3125: result: o configure:3129: checking whether we are using the GNU C compiler configure:3158: gcc -c conftest.c >&5 configure:3164: $? = 0 configure:3181: result: yes configure:3186: checking whether gcc accepts -g configure:3216: gcc -c -g conftest.c >&5 configure:3222: $? = 0 configure:3321: result: yes configure:3338: checking for gcc option to accept ISO C89 configure:3412: gcc -c -g -O2 conftest.c >&5 configure:3418: $? = 0 configure:3441: result: none needed configure:3461: checking dependency style of gcc configure:3552: result: gcc3 configure:3568: checking whether gcc and cc understand -c and -o together configure:3603: gcc -c conftest.c -o conftest2.o >&5 configure:3606: $? = 0 configure:3612: gcc -c conftest.c -o conftest2.o >&5 configure:3615: $? = 0 configure:3626: cc -c conftest.c >&5 configure:3629: $? = 0 configure:3637: cc -c conftest.c -o conftest2.o >&5 configure:3640: $? = 0 configure:3646: cc -c conftest.c -o conftest2.o >&5 configure:3649: $? = 0 configure:3667: result: yes configure:3683: checking for pic18f4685-microchip-mios-gcc configure:3710: result: gcc configure:3794: checking for pic18f4685-microchip-mios-as configure:3821: result: gpasm configure:3896: checking dependency style of gcc configure:3987: result: gcc3 configure:4006: checking for pic18f4685-microchip-mios-ar configure:4036: result: no configure:4046: checking for ar configure:4062: found /usr/bin/ar configure:4073: result: ar configure:4102: checking for pic18f4685-microchip-mios-ld configure:4132: result: no configure:4142: checking for ld configure:4158: found /usr/bin/ld configure:4169: result: ld configure:4198: checking for pic18f4685-microchip-mios-ranlib configure:4228: result: no configure:4238: checking for ranlib configure:4254: found /usr/bin/ranlib configure:4265: result: ranlib configure:4292: checking for a thread-safe mkdir -p configure:4331: result: ./install-sh -c -d configure:4344: checking how to run the C preprocessor configure:4384: gcc -E conftest.c configure:4390: $? = 0 configure:4421: gcc -E conftest.c conftest.c:14:28: error: ac_nonexistent.h: No such file or directory configure:4427: $? = 1 configure: failed program was: | /* confdefs.h. */ | #define PACKAGE_NAME "libcmios" | #define PACKAGE_TARNAME "libcmios" | #define PACKAGE_VERSION "1.9f" | #define PACKAGE_STRING "libcmios 1.9f" | #define PACKAGE_BUGREPORT "http://www.midibox/forum" | #define __pic18f4685__ 1 | #define __microchip__ 1 | #define __mios__ 1 | #define PACKAGE "libcmios" | #define VERSION "1.9f" | #define PIC_DERIVATIVE_TYPE 4 | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:4460: result: gcc -E configure:4489: gcc -E conftest.c configure:4495: $? = 0 configure:4526: gcc -E conftest.c conftest.c:14:28: error: ac_nonexistent.h: No such file or directory configure:4532: $? = 1 configure: failed program was: | /* confdefs.h. */ | #define PACKAGE_NAME "libcmios" | #define PACKAGE_TARNAME "libcmios" | #define PACKAGE_VERSION "1.9f" | #define PACKAGE_STRING "libcmios 1.9f" | #define PACKAGE_BUGREPORT "http://www.midibox/forum" | #define __pic18f4685__ 1 | #define __microchip__ 1 | #define __mios__ 1 | #define PACKAGE "libcmios" | #define VERSION "1.9f" | #define PIC_DERIVATIVE_TYPE 4 | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:4570: checking for grep that handles long lines and -e configure:4644: result: /usr/bin/grep configure:4649: checking for egrep configure:4727: result: /usr/bin/grep -E configure:4732: checking for ANSI C header files configure:4762: gcc -c -g -O2 conftest.c >&5 configure:4768: $? = 0 configure:4864: gcc -o conftest -g -O2 conftest.c >&5 configure:4867: $? = 0 configure:4873: ./conftest configure:4876: $? = 0 configure:4893: result: yes configure:4917: checking for sys/types.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for sys/stat.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for stdlib.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for string.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for memory.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for strings.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for inttypes.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for stdint.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4917: checking for unistd.h configure:4938: gcc -c -g -O2 conftest.c >&5 configure:4944: $? = 0 configure:4960: result: yes configure:4987: checking pic18fregs.h usability configure:5004: gcc -c -g -O2 conftest.c >&5 conftest.c:57:24: error: pic18fregs.h: No such file or directory configure:5010: $? = 1 configure: failed program was: | /* confdefs.h. */ | #define PACKAGE_NAME "libcmios" | #define PACKAGE_TARNAME "libcmios" | #define PACKAGE_VERSION "1.9f" | #define PACKAGE_STRING "libcmios 1.9f" | #define PACKAGE_BUGREPORT "http://www.midibox/forum" | #define __pic18f4685__ 1 | #define __microchip__ 1 | #define __mios__ 1 | #define PACKAGE "libcmios" | #define VERSION "1.9f" | #define PIC_DERIVATIVE_TYPE 4 | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <pic18fregs.h> configure:5024: result: no configure:5028: checking pic18fregs.h presence configure:5043: gcc -E conftest.c conftest.c:24:24: error: pic18fregs.h: No such file or directory configure:5049: $? = 1 configure: failed program was: | /* confdefs.h. */ | #define PACKAGE_NAME "libcmios" | #define PACKAGE_TARNAME "libcmios" | #define PACKAGE_VERSION "1.9f" | #define PACKAGE_STRING "libcmios 1.9f" | #define PACKAGE_BUGREPORT "http://www.midibox/forum" | #define __pic18f4685__ 1 | #define __microchip__ 1 | #define __mios__ 1 | #define PACKAGE "libcmios" | #define VERSION "1.9f" | #define PIC_DERIVATIVE_TYPE 4 | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | /* end confdefs.h. */ | #include <pic18fregs.h> configure:5063: result: no configure:5096: checking for pic18fregs.h configure:5104: result: no configure:5116: error: Can't compile without PIC header files See `config.log' for more details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=powerpc-apple-darwin8.11.0 ac_cv_c_compiler_gnu=yes ac_cv_env_CCASFLAGS_set= ac_cv_env_CCASFLAGS_value= ac_cv_env_CCAS_set= ac_cv_env_CCAS_value= ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_LIBS_set= ac_cv_env_LIBS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set=set ac_cv_env_host_alias_value=pic18f4685-mios ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_header_inttypes_h=yes ac_cv_header_memory_h=yes ac_cv_header_pic18fregs_h=no ac_cv_header_stdc=yes ac_cv_header_stdint_h=yes ac_cv_header_stdlib_h=yes ac_cv_header_string_h=yes ac_cv_header_strings_h=yes ac_cv_header_sys_stat_h=yes ac_cv_header_sys_types_h=yes ac_cv_header_unistd_h=yes ac_cv_host=pic18f4685-microchip-mios ac_cv_objext=o ac_cv_path_EGREP='/usr/bin/grep -E' ac_cv_path_GREP=/usr/bin/grep ac_cv_path_install='/usr/bin/install -c' ac_cv_prog_AS=gpasm ac_cv_prog_AWK=awk ac_cv_prog_CC=gcc ac_cv_prog_CPP='gcc -E' ac_cv_prog_ac_ct_AR=ar ac_cv_prog_ac_ct_CC=gcc ac_cv_prog_ac_ct_LD=ld ac_cv_prog_ac_ct_RANLIB=ranlib ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_cc_c89= ac_cv_prog_cc_g=yes ac_cv_prog_cc_gcc_c_o=yes ac_cv_prog_make_make_set=yes am_cv_CCAS_dependencies_compiler_type=gcc3 am_cv_CC_dependencies_compiler_type=gcc3 ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run aclocal-1.10' AMDEPBACKSLASH='\' AMDEP_FALSE='#' AMDEP_TRUE='' AMTAR='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run tar' AR='ar' AS='gpasm' AUTOCONF='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run autoconf' AUTOHEADER='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run autoheader' AUTOMAKE='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run automake-1.10' AWK='awk' CC='gcc' CCAS='gcc' CCASDEPMODE='depmode=gcc3' CCASFLAGS='-g -O2' CCDEPMODE='depmode=gcc3' CFLAGS='-g -O2' CPP='gcc -E' CPPFLAGS='' CYGPATH_W='echo' DEFS='' DEPDIR='.deps' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='/usr/bin/grep -E' EXEEXT='' GREP='/usr/bin/grep' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='$(install_sh) -c -s' LD='ld' LDFLAGS='' LIBOBJS='' LIBS='' LTLIBOBJS='' MAKEINFO='${SHELL} /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/missing --run makeinfo' OBJEXT='o' PACKAGE='libcmios' PACKAGE_BUGREPORT='http://www.midibox/forum' PACKAGE_NAME='libcmios' PACKAGE_STRING='libcmios 1.9f' PACKAGE_TARNAME='libcmios' PACKAGE_VERSION='1.9f' PATH_SEPARATOR=':' RANLIB='ranlib' SET_MAKE='' SHELL='/bin/sh' STRIP='strip' VERSION='1.9f' ac_ct_CC='gcc' ac_default_prefix='/usr/pic18f4685-microchip-mios' ac_tool_prefix='pic18f4685-microchip-mios-' am__fastdepCCAS_FALSE='#' am__fastdepCCAS_TRUE='' am__fastdepCC_FALSE='#' am__fastdepCC_TRUE='' am__include='include' am__isrc='' am__leading_dot='.' am__quote='' am__tar='${AMTAR} chof - "$$tardir"' am__untar='${AMTAR} xf -' bindir='${exec_prefix}/bin' build='powerpc-apple-darwin8.11.0' build_alias='' build_cpu='powerpc' build_os='darwin8.11.0' build_vendor='apple' datadir='${datarootdir}' datarootdir='${prefix}/share' docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' dvidir='${docdir}' exec_prefix='NONE' host='pic18f4685-microchip-mios' host_alias='pic18f4685-mios' host_cpu='pic18f4685' host_linker_script='pic18f4685.lkr' host_os='mios' host_vendor='microchip' htmldir='${docdir}' includedir='${prefix}/include' infodir='${datarootdir}/info' install_sh='$(SHELL) /Users/kurtarnlund/Desktop/mios-c-skeleton/libcmios-1.9f/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='${datarootdir}/locale' localstatedir='${prefix}/var' mandir='${datarootdir}/man' mkdir_p='$(top_builddir)/./install-sh -c -d' oldincludedir='/usr/include' pdfdir='${docdir}' prefix='/usr/local' program_transform_name='s,x,x,' psdir='${docdir}' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define PACKAGE_NAME "libcmios" #define PACKAGE_TARNAME "libcmios" #define PACKAGE_VERSION "1.9f" #define PACKAGE_STRING "libcmios 1.9f" #define PACKAGE_BUGREPORT "http://www.midibox/forum" #define __pic18f4685__ 1 #define __microchip__ 1 #define __mios__ 1 #define PACKAGE "libcmios" #define VERSION "1.9f" #define PIC_DERIVATIVE_TYPE 4 #define STDC_HEADERS 1 #define HAVE_SYS_TYPES_H 1 #define HAVE_SYS_STAT_H 1 #define HAVE_STDLIB_H 1 #define HAVE_STRING_H 1 #define HAVE_MEMORY_H 1 #define HAVE_STRINGS_H 1 #define HAVE_INTTYPES_H 1 #define HAVE_STDINT_H 1 #define HAVE_UNISTD_H 1 configure: exit 1I hope it's just that I'm doing something stupid.Kurt
ptitjes Posted December 20, 2007 Author Posted December 20, 2007 Sorry Narwhal,I overlooked your post and didn't see that you did not pass the configure step. It seems that mios-pic16-toolchain did not install so well.Explanation: Your config.log says it does not find pic18f4685-microchip-mios-gcc: configure:2548: checking for pic18f4685-microchip-mios-gcc configure:2578: result: no configure:2588: checking for gcc configure:2604: found /usr/bin/gcc configure:2615: result: gcc configure:2853: checking for C compiler version configure:2860: gcc --version >&5 powerpc-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build 5370) Explanation continued: sdcc adds automatically its own include directory (containing amongst others pic18fregs.h), which standard gcc (here powerpc-apple-darwin8-gcc) hopefully does not. So could you please tell me what exact configure parameters you gave to mios-pic16-toolchain. What is the prefix you gave ? Did you put '/usr' or '/usr/local' ? And also what were the output ?? ~/Desktop/mios-c-skeleton/mios-pic16-toolchain/$ ./configure --target=pic18f4685-mios --prefix=/usr ~/Desktop/mios-c-skeleton/mios-pic16-toolchain/$ sudo make install I would like to understand where it installed the toolchain. Could you verify if ${prefix}/bin/pic18f4685-microchip-mios-gcc exists ? $ echo $PATH $ which pic18f4685-microchip-mios-gcc $ ls -l /usr/local/bin/pic18f4685-microchip-mios-gcc $ ls -l /usr/bin/pic18f4685-microchip-mios-gcc Thank you.Best regards,Didier.
ptitjes Posted December 20, 2007 Author Posted December 20, 2007 Starting some documentation : http://www.midibox.org/dokuwiki/howto:dev:autotools-skeletonCheers, Didier.
Narwhal Posted December 20, 2007 Posted December 20, 2007 Hi Didier,Yeah the it seems my problem crept in when I decided that I want the gpasm, sdcc, and mios tool chain files in my /usr/local/bin. In my learning how to do that I think I screwed things up. I'm not yet sure why or how, but all of links that are created (to pic18f4685-microchip-mios-gcc, etc) were sitting in my /src directory and were never moved to /usr/local/bin. In fact, it seems that make uninstall does not remove these files. I tried "$sudo make uninstall" and that didn't work. I think I forgot the sudo command once and ran the make install without the permissions. Then it made all the files, but could not copy them to the destination. So I was stuck in limbo, with it unable to back up and try again, because nothing would clean up the /src directory if it couldn't find the files in the destination (/usr/local/bin).So I moved/created the links pic18f4685-microchip-mios-gcc, -ar, -as, -ld, -ranlib in /usr/local/bin and the tool chain looks like it's set up correctly now. /usr/local/bin$ls ... gpasm and sdcc files here ... ... -rwxr-xr-x 1 root wheel 2624 Dec 20 09:55 mios-fixasm.pl -rwxr-xr-x 1 root wheel 5226 Dec 20 09:58 mios-pic16-tool-wrapper ... lrwxr-xr-x 1 root wheel 23 Dec 20 10:03 pic18f4685-microchip-mios-ar -> mios-pic16-tool-wrapper lrwxr-xr-x 1 root wheel 23 Dec 20 10:04 pic18f4685-microchip-mios-as -> mios-pic16-tool-wrapper lrwxr-xr-x 1 root wheel 23 Dec 20 10:04 pic18f4685-microchip-mios-gcc -> mios-pic16-tool-wrapper lrwxr-xr-x 1 root wheel 23 Dec 20 10:04 pic18f4685-microchip-mios-ld -> mios-pic16-tool-wrapper lrwxr-xr-x 1 root wheel 23 Dec 20 10:04 pic18f4685-microchip-mios-ranlib -> mios-pic16-tool-wrapper is this the correct setup? before I attempt to configure libcmios? Still getting errors configuring libcmios, but it's definitely seems to be working better (ie: using the correct compiler now) ~/Desktop/mios-autotools-skeleton/libcmios-1.9f$ ./configure --host=pic18f4685-mios --prefix=/usr/local configure: WARNING: If you wanted to set the --build type, don't use --host. If a cross compiler is detected then cross compile mode will be used. checking build system type... powerpc-apple-darwin8.11.0 checking host system type... pic18f4685-microchip-mios checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... ./install-sh -c -d checking for gawk... no checking for mawk... no checking for nawk... no checking for awk... awk checking whether make sets $(MAKE)... yes checking for pic18f4685-microchip-mios-strip... no checking for strip... strip checking for gpasm... gpasm checking for style of include used by make... GNU checking for pic18f4685-microchip-mios-gcc... pic18f4685-microchip-mios-gcc checking for C compiler default output file name... configure: error: C compiler cannot create executables See `config.log' for more details. Thanks for all the help,Kurt
ptitjes Posted December 21, 2007 Author Posted December 21, 2007 There was a bug in the install-hook target of the Makefile of mios-pic16-toolchain... sorry but you are my first bug reporter :)Made a new release with a fix for this. See in the first post.So indeed your links are correct anyway.Could you provide me the content of config.log please ?
Narwhal Posted December 21, 2007 Posted December 21, 2007 Hey it's cool on the bugs. I figured I was the guinea-pig on trying this so quickly.I'll upload the config.log as soon as I get home. You want the log from when I configured libcmios right?Kurt
ptitjes Posted December 21, 2007 Author Posted December 21, 2007 Hey it's cool on the bugs. I figured I was the guinea-pig on trying this so quickly.You are the first beta-tester... (after me of course ;)) so this is quite normal that you get the bad things. But please do not dismiss! I need you! :)I'll upload the config.log as soon as I get home. You want the log from when I configured libcmios right?Exactly.BTW i uploaded a release correcting your previous problem and some minor other stuff. If you want to try to "sudo make uninstall" mios-pic16-toolchain and re "sudo make install" it to check if it now works correctly as on my computer.
Narwhal Posted December 21, 2007 Posted December 21, 2007 ok, so from config.log the main error seems to be a pathing error:configure:2906: checking for C compiler default output file name configure:2933: pic18f4685-microchip-mios-gcc conftest.c >&5 /usr/pic18f4685-microchip-mios/scripts/default.lkr: No such file or directory configure:2936: $? = 0 configure:2974: result: configure: failed program was: | /* confdefs.h. */ Because I definitely do not have a /usr/pic18f4685-microchip-mios directory. I'm rebuilding my locate database right now to see if I have it at all. Here is the complete config.log ~/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1$ cat config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by libcmios configure 1.9f-r1, which was generated by GNU Autoconf 2.61. Invocation command line was $ ./configure --host=pic18f4685-mios ## --------- ## ## Platform. ## ## --------- ## hostname = static-003.local uname -m = Power Macintosh uname -r = 8.11.0 uname -s = Darwin uname -v = Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00 PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC /usr/bin/uname -p = powerpc /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = Mach kernel version: Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00 PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC Kernel configured for up to 2 processors. 2 processors are physically available. Processor type: ppc7450 (PowerPC 7450) Processors active: 0 1 Primary memory available: 2.00 gigabytes Default processor set: 67 tasks, 201 threads, 2 processors Load average: 1.61, Mach factor: 1.04 /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /bin PATH: /sbin PATH: /usr/bin PATH: /usr/sbin PATH: /Developer/usr/bin PATH: /usr/local/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1792: checking build system type configure:1810: result: powerpc-apple-darwin8.11.0 configure:1832: checking host system type configure:1847: result: pic18f4685-microchip-mios configure:1977: checking for a BSD-compatible install configure:2033: result: /usr/bin/install -c configure:2044: checking whether build environment is sane configure:2087: result: yes configure:2115: checking for a thread-safe mkdir -p configure:2154: result: ./install-sh -c -d configure:2167: checking for gawk configure:2197: result: no configure:2167: checking for mawk configure:2197: result: no configure:2167: checking for nawk configure:2197: result: no configure:2167: checking for awk configure:2183: found /usr/bin/awk configure:2194: result: awk configure:2205: checking whether make sets $(MAKE) configure:2226: result: yes configure:2306: checking for pic18f4685-microchip-mios-strip configure:2336: result: no configure:2346: checking for strip configure:2362: found /usr/bin/strip configure:2373: result: strip configure:2442: checking for gpasm configure:2458: found /usr/local/bin/gpasm configure:2470: result: gpasm configure:2490: checking for style of include used by make configure:2518: result: GNU configure:2548: checking for pic18f4685-microchip-mios-gcc configure:2564: found /usr/local/bin/pic18f4685-microchip-mios-gcc configure:2575: result: pic18f4685-microchip-mios-gcc configure:2853: checking for C compiler version configure:2860: pic18f4685-microchip-mios-gcc --version >&5 SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.7.4 #4976 (Dec 10 2007) (Mac OS X ppc) configure:2863: $? = 0 configure:2870: pic18f4685-microchip-mios-gcc -v >&5 SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.7.4 #4976 (Dec 10 2007) (Mac OS X ppc) configure:2873: $? = 0 configure:2880: pic18f4685-microchip-mios-gcc -V >&5 SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.7.4 #4976 (Dec 10 2007) (Mac OS X ppc) Usage : sdcc [options] filename Options :- General options: --help Display this help -v --version Display sdcc's version --verbose Trace calls to the preprocessor, assembler, and linker -V Execute verbosely. Show sub commands as they are run -d -D Define macro as in -Dmacro -I Add to the include (*.h) path, as in -Ipath -A -U -M Preprocessor option -W Pass through options to the pre-processor (p), assembler (a) or linker (l) -S Compile only; do not assemble or link -c --compile-only Compile and assemble, but do not link -E --preprocessonly Preprocess only, do not compile --c1mode Act in c1 mode. The standard input is preprocessed code, the output is assembly code. -o Place the output into the given path resp. file --print-search-dirs display the directories in the compiler's search path --vc messages are compatible with Micro$oft visual studio --use-stdout send errors to stdout instead of stderr --nostdlib Do not include the standard library directory in the search path --nostdinc Do not include the standard include directory in the search path --less-pedantic Disable some of the more pedantic warnings --disable-warning <nnnn> Disable specific warning --Werror Treat the warnings as errors --debug Enable debugging symbol output --cyclomatic Display complexity of compiled functions --std-c89 Use C89 standard only --std-sdcc89 Use C89 standard with SDCC extensions (default) --std-c99 Use C99 standard only (incomplete) --std-sdcc99 Use C99 standard with SDCC extensions (incomplete) --fdollars-in-identifiers Permit '$' as an identifier character --funsigned-char Make "char" unsigned by default Code generation options: -m Set the port to use e.g. -mz80. -p Select port specific processor e.g. -mpic14 -p16f84 --model-large external data space is used --model-medium external paged data space is used --model-small internal data space is used (default) --stack-auto Stack automatic variables --xstack Use external stack --int-long-reent Use reenterant calls on the int and long support functions --float-reent Use reenterant calls on the float support functions --main-return Issue a return after main() --xram-movc Use movc instead of movx to read xram (xdata) --callee-saves <func[,func,...]> Cause the called function to save registers insted of the caller --profile On supported ports, generate extra profiling information --fommit-frame-pointer Leave out the frame pointer. --all-callee-saves callee will always save registers used --stack-probe insert call to function __stack_probe at each function prologue --no-xinit-opt don't memcpy initialized xram from code --no-c-code-in-asm don't include c-code as comments in the asm file --no-peep-comments don't include peephole optimizer comments --fverbose-asm include code generator comments --short-is-8bits Make short 8 bits (for old times sake) --codeseg <name> use this name for the code segment --constseg <name> use this name for the const segment Optimization options: --nooverlay Disable overlaying leaf function auto variables --nogcse Disable the GCSE optimisation --nolabelopt Disable label optimisation --noinvariant Disable optimisation of invariants --noinduction Disable loop variable induction --nojtbound Don't generate boundary check for jump tables --noloopreverse Disable the loop reverse optimisation --no-peep Disable the peephole assembly file optimisation --no-reg-params On some ports, disable passing some parameters in registers --peep-asm Enable peephole optimization on inline assembly --peep-file <file> use this extra peephole file --opt-code-speed Optimize for code speed rather than size --opt-code-size Optimize for code size rather than speed Internal debugging options: --dumpraw Dump the internal structure after the initial parse --dumpgcse --dumploop --dumpdeadcode --dumpliverange --dumpregpack --dumpregassign --dumptree dump front-end AST before generating iCode --dumpall Dump the internal structure at all stages --i-code-in-asm include i-code as comments in the asm file Linker options: -l Include the given library in the link -L Add the next field to the library search path --lib-path <path> use this path to search for libraries --out-fmt-ihx Output in Intel hex format --out-fmt-s19 Output in S19 hex format --xram-loc <nnnn> External Ram start location --xram-size <nnnn> External Ram size --iram-size <nnnn> Internal Ram size --xstack-loc <nnnn> External Stack start location --code-loc <nnnn> Code Segment Location --code-size <nnnn> Code Segment size --stack-loc <nnnn> Stack pointer initial value --data-loc <nnnn> Direct data start location --idata-loc Special options for the mcs51 port: --stack-size Tells the linker to allocate this space for stack --parms-in-bank1 use Bank1 for parameter passing --pack-iram Tells the linker to pack variables in internal ram (default) --no-pack-iram Tells the linker not to pack variables in internal ram --acall-ajmp Use acall/ajmp instead of lcall/ljmp Special options for the gbz80 port: -bo <num> use code bank <num> -ba <num> use data bank <num> --callee-saves-bc Force a called function to always save BC --codeseg <name> use this name for the code segment --constseg <name> use this name for the const segment --no-std-crt0 For the z80/gbz80 do not link default crt0.o Special options for the z80 port: --callee-saves-bc Force a called function to always save BC --portmode= Determine PORT I/O mode (z80/z180) --asm= Define assembler name (rgbds/asxxxx/isas/z80asm) --codeseg <name> use this name for the code segment --constseg <name> use this name for the const segment --no-std-crt0 For the z80/gbz80 do not link default crt0.o Special options for the ds390 port: --model-flat24 use the flat24 model for the ds390 (default) --stack-8bit use the 8bit stack for the ds390 (not supported yet) --stack-size Tells the linker to allocate this space for stack --pack-iram Tells the linker to pack variables in internal ram (default) --no-pack-iram Tells the linker not to pack variables in internal ram --stack-10bit use the 10bit stack for ds390 (default) --use-accelerator generate code for ds390 arithmetic accelerator --protect-sp-update will disable interrupts during ESP:SP updates --parms-in-bank1 use Bank1 for parameter passing Special options for the pic16 port: --pstack-model= use stack model 'small' (default) or 'large' -y --extended enable Extended Instruction Set/Literal Offset Addressing mode --pno-banksel do not generate BANKSEL assembler directives --obanksel= set banksel optimization level (default=0 no) --denable-peeps explicit enable of peepholes --optimize-goto try to use (conditional) BRA instead of GOTO --optimize-cmp try to optimize some compares --optimize-df thoroughly analyze data flow (memory and time intensive!) --asm= Use alternative assembler --mplab-comp enable compatibility mode for MPLAB utilities (MPASM/MPLINK) --link= Use alternative linker --preplace-udata-with= Place udata variables at another section: udata_acs, udata_ovr, udata_shr --ivt-loc= Set address of interrupt vector table. --nodefaultlibs do not link default libraries when linking --use-crt= use <crt-o> run-time initialization module --no-crt do not link any default run-time initialization module --debug-xtra show more debug info in assembly output --debug-ralloc dump register allocator debug file *.d --pcode-verbose dump pcode related info --calltree dump call tree in .calltree file --gstack trace stack pointer push/pop to overflow Special options for the pic14 port: --debug-xtra show more debug info in assembly output --no-pcode-opt disable (slightly faulty) optimization on pCode --stack-size sets the size if the argument passing stack (default: 16, minimum: 4) --udata-section-name set udata section name Special options for the TININative port: --model-flat24 use the flat24 model for the ds390 (default) --stack-8bit use the 8bit stack for the ds390 (not supported yet) --stack-size Tells the linker to allocate this space for stack --pack-iram Tells the linker to pack variables in internal ram (default) --no-pack-iram Tells the linker not to pack variables in internal ram --stack-10bit use the 10bit stack for ds390 (default) --use-accelerator generate code for ds390 arithmetic accelerator --protect-sp-update will disable interrupts during ESP:SP updates --parms-in-bank1 use Bank1 for parameter passing --tini-libid <nnnn> LibraryID used in -mTININative Special options for the ds400 port: --model-flat24 use the flat24 model for the ds400 (default) --stack-8bit use the 8bit stack for the ds400 (not supported yet) --stack-size Tells the linker to allocate this space for stack --pack-iram Tells the linker to pack variables in internal ram (default) --no-pack-iram Tells the linker not to pack variables in internal ram --stack-10bit use the 10bit stack for ds400 (default) --use-accelerator generate code for ds400 arithmetic accelerator --protect-sp-update will disable interrupts during ESP:SP updates --parms-in-bank1 use Bank1 for parameter passing Special options for the hc08 port: --out-fmt-elf Output executable in ELF format configure:2883: $? = 0 configure:2906: checking for C compiler default output file name configure:2933: pic18f4685-microchip-mios-gcc conftest.c >&5 /usr/pic18f4685-microchip-mios/scripts/default.lkr: No such file or directory configure:2936: $? = 0 configure:2974: result: configure: failed program was: | /* confdefs.h. */ | #define PACKAGE_NAME "libcmios" | #define PACKAGE_TARNAME "libcmios" | #define PACKAGE_VERSION "1.9f-r1" | #define PACKAGE_STRING "libcmios 1.9f-r1" | #define PACKAGE_BUGREPORT "http://www.midibox/forum" | #define __pic18f4685__ 1 | #define __microchip__ 1 | #define __mios__ 1 | #define PACKAGE "libcmios" | #define VERSION "1.9f-r1" | #define PIC_DERIVATIVE_TYPE 4 | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:2981: error: C compiler cannot create executables See `config.log' for more details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=powerpc-apple-darwin8.11.0 ac_cv_env_CCASFLAGS_set= ac_cv_env_CCASFLAGS_value= ac_cv_env_CCAS_set= ac_cv_env_CCAS_value= ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_LIBS_set= ac_cv_env_LIBS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set=set ac_cv_env_host_alias_value=pic18f4685-mios ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_host=pic18f4685-microchip-mios ac_cv_path_install='/usr/bin/install -c' ac_cv_prog_AS=gpasm ac_cv_prog_AWK=awk ac_cv_prog_CC=pic18f4685-microchip-mios-gcc ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_make_make_set=yes ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run aclocal-1.10' AMDEPBACKSLASH='\' AMDEP_FALSE='#' AMDEP_TRUE='' AMTAR='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run tar' AR='' AS='gpasm' AUTOCONF='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run autoconf' AUTOHEADER='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run autoheader' AUTOMAKE='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run automake-1.10' AWK='awk' CC='pic18f4685-microchip-mios-gcc' CCAS='' CCASDEPMODE='' CCASFLAGS='' CCDEPMODE='' CFLAGS='' CPP='' CPPFLAGS='' CYGPATH_W='echo' DEFS='' DEPDIR='.deps' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='' EXEEXT='' GREP='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='$(install_sh) -c -s' LD='' LDFLAGS='' LIBOBJS='' LIBS='' LTLIBOBJS='' MAKEINFO='${SHELL} /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/missing --run makeinfo' OBJEXT='' PACKAGE='libcmios' PACKAGE_BUGREPORT='http://www.midibox/forum' PACKAGE_NAME='libcmios' PACKAGE_STRING='libcmios 1.9f-r1' PACKAGE_TARNAME='libcmios' PACKAGE_VERSION='1.9f-r1' PATH_SEPARATOR=':' RANLIB='' SET_MAKE='' SHELL='/bin/sh' STRIP='strip' VERSION='1.9f-r1' ac_ct_CC='' ac_default_prefix='/usr/pic18f4685-microchip-mios' ac_tool_prefix='pic18f4685-microchip-mios-' am__fastdepCCAS_FALSE='' am__fastdepCCAS_TRUE='' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='' am__include='include' am__isrc='' am__leading_dot='.' am__quote='' am__tar='${AMTAR} chof - "$$tardir"' am__untar='${AMTAR} xf -' bindir='${exec_prefix}/bin' build='powerpc-apple-darwin8.11.0' build_alias='' build_cpu='powerpc' build_os='darwin8.11.0' build_vendor='apple' datadir='${datarootdir}' datarootdir='${prefix}/share' docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' dvidir='${docdir}' exec_prefix='NONE' host='pic18f4685-microchip-mios' host_alias='pic18f4685-mios' host_cpu='pic18f4685' host_linker_script='pic18f4685.lkr' host_os='mios' host_vendor='microchip' htmldir='${docdir}' includedir='${prefix}/include' infodir='${datarootdir}/info' install_sh='$(SHELL) /Users/kurtarnlund/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='${datarootdir}/locale' localstatedir='${prefix}/var' mandir='${datarootdir}/man' mkdir_p='$(top_builddir)/./install-sh -c -d' oldincludedir='/usr/include' pdfdir='${docdir}' prefix='NONE' program_transform_name='s,x,x,' psdir='${docdir}' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define PACKAGE_NAME "libcmios" #define PACKAGE_TARNAME "libcmios" #define PACKAGE_VERSION "1.9f-r1" #define PACKAGE_STRING "libcmios 1.9f-r1" #define PACKAGE_BUGREPORT "http://www.midibox/forum" #define __pic18f4685__ 1 #define __microchip__ 1 #define __mios__ 1 #define PACKAGE "libcmios" #define VERSION "1.9f-r1" #define PIC_DERIVATIVE_TYPE 4 configure: exit 77 ~/Desktop/mios-autotools-skeleton-1.9f-r1/libcmios-1.9f-r1$
ptitjes Posted December 21, 2007 Author Posted December 21, 2007 My fault again...So i reworked that prefix things completely to make it more stable! Please read the "Making choices" section in the Wiki page.(http://www.midibox.org/dokuwiki/howto:dev:autotools-skeleton#making_choices)There I explain where installed things go depending on the prefix.Please uninstall everything, download it again, and restart the procedure!I've redone it completely at home (with prefix, without prefix... install everything/uninstall everything...) and it works very well.(Beware that version is still 1.9f-r1... as you are the only user for now and that there are certainly some other points to fix, i don't want to augment the versions too fast)Thank you very much for your help.Best regards, Didier.
