marioguzzi Posted December 29, 2007 Posted December 29, 2007 Hi all,after solving the DIN problem I started building the second SID module for my synth.1 Core r4d1 Sid r3d (with 8580chip) and 2200uF electrolytic capoptimized c64 psu Due to some soldering paste left on the board when I connected the board to test voltages I got some smoke and sparkles between the voltage regulator and c10(330nF). I cleaned the board and replaced them.Voltages on SID module are 8,9V at the voltage regulator output and 5,15V from Core moduleNow, I'm getting a lot of noise, with or without the 8580.Probably something got fried during the first test, but I don't know which components to check, any help appreciated ???Here's a snapshot of scope and spectrum taken WITHOUT the 8580 chip EDIT: oh, don't look for stereo snapshot, as only the problematic SID module is connected to the oscilloscope
rutgerv Posted December 29, 2007 Posted December 29, 2007 Wow, that's a nice spectrum of something between white and pink noise!A question that comes to mind is: how loud is the noise? If there's a broken connection in the audio-path and you crank up the volume you can always generate noise of this type, but if this noise is really loud (the same loudness of a SID output) then something else is actively producing this noise. A couple of things come to mind:- Check if the problem isn't coming from a dirty power rail. If something got damaged due to the sparks and smoke you should be able to see this with your scope. An unstable power supply could cause this noise.- Transistor T1 could be damaged due to voltage peaks when the sparks and smoke were going on- Transistor T1 could be pin swappedGreetings,Rutger
nebula Posted December 29, 2007 Posted December 29, 2007 <obvious>Since you have another SID module that's fine, did you try swapping the chips to see if the noise follows?</obvious> ;D
ytsestef Posted December 29, 2007 Posted December 29, 2007 <obvious>Since you have another SID module that's fine, did you try swapping the chips to see if the noise follows?</obvious> ;DNow, I'm getting a lot of noise, with or without the 8580....Here's a snapshot of scope and spectrum taken WITHOUT the 8580 chip :P
marioguzzi Posted December 29, 2007 Author Posted December 29, 2007 thanks for the replies!swapping the chips has no positive effects, and anyway the noise is present even without the chip (and really loud) so I can exclude that the problem is related to the chip.I'd exclude also problems related to power supply, in fact with the other SID module the noise I get is much lower, i.e. volume not comparable to SID output.I'll let you know once I replace T1
SLP Posted December 30, 2007 Posted December 30, 2007 hmm... does it sound similar to my "Core-Noise"?http://www.midibox.org/forum/index.php?topic=9268.0
marioguzzi Posted December 30, 2007 Author Posted December 30, 2007 hmm... does it sound similar to my "Core-Noise"?no, mine is definitely "noise", not a "tone".Anyone knows if c547c is it equivalent to the bc547?
seppoman Posted January 1, 2008 Posted January 1, 2008 Anyone knows if c547c is it equivalent to the bc547?yes, that's the same. the B is sometimes omitted on the parts print.S
marioguzzi Posted January 2, 2008 Author Posted January 2, 2008 replacing the transistor solved the problem ;)thanks for the support
