gillesdeshays Posted August 3, 2003 Report Posted August 3, 2003 I have the same problem with a "like JDM'" commercial programmer ......I always succed burning 877 .... but never 452 !Running on W98SE, with 8.2 zener , i also try to get out the 2 leds to save some current .....because i miss some voltage As i cannot find any 8.7v zener ... i dunno what to do ......My step C midibox SID is ready to receive my pic .... What is your COM port config ?I think that' s because of a lack of voltage on my com port .....Can you precise me what voltage you have on the JDM plugged into the com port ?thanks a lot !! i can wait tweaking knobs on my step C SID !!!!!PLEASE HELP !!!! ???
gillesdeshays Posted August 4, 2003 Report Posted August 4, 2003 I've tryed at my office ..... same problems .....I gonna build a real "breadboard" JDM ... and see @ home and @ office ....... on monday ... but i cannot find a 8.7 V Zener ... But I also read TK on ucapps.de JDM page saying (Note: if you cannot find a 8,7V zener, just take the 8,2V, it will work in most cases).???But as i don't like to loose against Silicium ... ;) ...Can some one can precise me what voltage between the chatode of the Zener 8.7 and the ground :Pin 5 on the COM subd 9, with JDM connected with PIC onboard and no Programmer software .......?Thanks a lot !Gilles
gillesdeshays Posted August 4, 2003 Report Posted August 4, 2003 i've found a 8.7v zener .... but in CMS ......i'll check it tomorrow .....
gillesdeshays Posted August 4, 2003 Report Posted August 4, 2003 hey Pilo ! you want to win the Post number race or what ??? ;DTriple post !BTW i thought CMS was right in english ...?? no ??
pilo Posted August 4, 2003 Report Posted August 4, 2003 me? what? tripple messages? ;D you must be drunk hihihiihiiihihi I wish I get less problem with this reply.well.. I though CMS was for "Composant à Montage en Surface", and SMD "Surface Mounting Device"... but it was just because I want to post something today to win the post number race ;DAnd so? it works?
gillesdeshays Posted August 4, 2003 Report Posted August 4, 2003 hey !!!! you erased your posts !!!!!! ;D ;D ;D LOL !!!!Ok for CMS .... -> SMD ! right !The one to beat is TK with more than 1300 post ....-> mmmm it's gonna be hard ! ;)For my problem . mo' info tomerrow .... i'll have the 8.7 zener ...
gillesdeshays Posted August 28, 2003 Report Posted August 28, 2003 I still have the problem......I resume :- Commercial Programmer "as JDM" (same circuit but a 8.2V instead of 8.7v zener)- W98SE- IC Prog 1.0.5.0- Default COM PORT configurationI did burn some 877 ...... but never a 18F452 ! :"Programming failed at Code address 0000h"I double checked EVERYTHING in the softs (W98 and IC prog config) and try many different configs.... I miss some volts on the JDM !I try to unsolder the 2 leds... which make me save some volts .....But still not enough ....(i don''t have the values recommanded by Thorsten on his "ucapps IcProg tutorial")I also change the 8.2V zener to a 8.7V ..... same problem !l I really think that's because of the COM PORT which can't deliver enough volts !!!!!What do you think about that ?
TK. Posted August 28, 2003 Report Posted August 28, 2003 Did you read the new troubleshooting section in the MBHP_JDM page?The new mods are valid for every burner which are connected to the COM port...Best Regards, Thorsten.
gillesdeshays Posted August 28, 2003 Report Posted August 28, 2003 didn't see it yet ....... just coming back from holydays 8)i try this this afternoon ! ;D
