Trouble Uploading MIOS
aminoplacid
I am currently working on getting the MIOS setup on my CORE and am having some trouble.  I am using one of SmashTV's boards. I got it a couple years ago. The PIC is 18F452.  Here was my procedure.
Upload the upgrade .hex.  Worked fine.
Display on the LCD was just the single line of blocks.  Could not get the READY text to show.
Upload the LCD Test application. Worked fine. Tested ok.  Still could not get the READY text to show or any of the LCD Test Application readouts.
Thinking that perhaps it was the MIOS somehow, I tried to upload the MIOS without previous version .hex
Got errors:
Starting upload of update_without_installed_mios.hex
Hex file contains code in MIOS range, forcing reboot!
Received error code 01: Less bytes than expected have been received
This was an expected error - please ignore!
Received Upload Request
Sending block 00000000-000000FF
Received error code 05: Write access failed (invalid address range) - used by 1st level bsl
Sending block 00000400-000004FF
Received Checksum: 46 - OK
Sending block 00000500-000005FF
Received Checksum: 0F - OK
Sending block 00000600-000006FF
Received Checksum: 48 - OK
Sending block 00000700-000007FF
Received Checksum: 53 - OK
Sending block 00000800-000008FF
Received Checksum: 08 - OK
Sending block 00000900-000009FF
Received Checksum: 59 - OK
Sending block 00000A00-00000AFF
Received Checksum: 60 - OK
Sending block 00000B00-00000BFF
Received Checksum: 7B - OK
Sending block 00000C00-00000CFF
Sending block 00000D00-00000DFF
Received Checksum: 50 - OK
Sending block 00000E00-00000EFF
Received Checksum: 47 - OK
Sending block 00000F00-00000FFF
Received Checksum: 2C - OK
Sending block 00001000-000010FF
Received Checksum: 4E - OK
Sending block 00001100-000011FF
Received Checksum: 28 - OK
Sending block 00001200-000012FF
Received Checksum: 17 - OK
Sending block 00001300-000013FF
Received Checksum: 1B - OK
Sending block 00001400-000014FF
Received Checksum: 0B - OK
Sending block 00001500-000015FF
Received Checksum: 78 - OK
Sending block 00001600-000016FF
Sending block 00001700-000017FF
Received Checksum: 06 - OK
Sending block 00001800-000018FF
Received Checksum: 77 - OK
Sending block 00001900-000019FF
Received Checksum: 79 - OK
Sending block 00001A00-00001AFF
Received Checksum: 64 - OK
Sending block 00001B00-00001BFF
Received Checksum: 72 - OK
Sending block 00001C00-00001CFF
Sending block 00001D00-00001DFF
Received Checksum: 40 - OK
Sending block 00001E00-00001EFF
Received Checksum: 74 - OK
Sending block 00001F00-00001FFF
Received Checksum: 3C - OK
Sending block 00002000-000020FF
Received Checksum: 4F - OK
Sending block 00002100-000021FF
Received Checksum: 5F - OK
Sending block 00002200-000022FF
Sending block 00002300-000023FF
Received Checksum: 7E - OK
Sending block 00002400-000024FF
Received Checksum: 68 - OK
Sending block 00002500-000025FF
Received Checksum: 4A - OK
Sending block 00002600-000026FF
Received Checksum: 3E - OK
Sending block 00002700-000027FF
Received Checksum: 62 - OK
Sending block 00002800-000028FF
Sending block 00002900-000029FF
Sending block 00002A00-00002AFF
Sending block 00002B00-00002BFF
Sending block 00002C00-00002CFF
Received Checksum: 23 - OK
Sending block 00002D00-00002DFF
Sending block 00002E00-00002EFF
Received Checksum: 33 - OK
Sending block 00002F00-00002FFF
Sending block 00003000-000030FF
Received Checksum: 70 - OK
Sending block 00003100-000031FF
Sending block 00003200-000032FF
Sending block 00003300-000033FF
Received Checksum: 29 - OK
Sending block 00003400-000034FF
Sending block 00003500-000035FF
Sending block 00003600-000036FF
Received Checksum: 0C - OK
Sending block 00004000-000040FF
Sending block 00004100-000041FF
Received Checksum: 15 - OK
Sending block 00004200-000042FF
Received Checksum: 56 - OK
Sending block 00004300-000043FF
Received Checksum: 3F - OK
Upload process complete
Not sure about this error but it seems significant.  Also, cannot figure out the LCD.  The LCD seems like it is in fine shape as it gets power and the measurements are ok.  My first priority is getting the latest MIOS installed correctly. Any ideas?
Thanks.
Are you saying that v1.9 (latest available MIOS) is not supported for the PIC18F452?  If so, is there a place where old versions of MIOS are kept where I can get the latest version that supports the PIC18F452?  I understand that the PIC18F452 is not supported anymore though but I would like to get something working before I go out and buy more PIC's, ya know.
Thanks!!! :)
Hi!  Thanks for the replies.  We  I got MIOS uploaded just fine today.  However I am not getting the READY screen when I power up.  All I get is the single line of blocks on the LCD.  I have it wired properly (AFAIK).  Link to the datasheet: http://www.shopeio.com/inventory/pdf/AMC2002C.pdf
Any other thoughts?  I'll retry the LCD tests over the weekend, probably Sunday and return with any results.
Thanks again for the noobie assistance.
no data on your LCD?
that's pretty odd. especially if the LCD test was already fine.
how do you have it connected? Is the ribbon cable soldered directly to the pins? If so, make sure a single wire didn't fray and is shorting to another pin someplace. I seem to remember something like this happening to me.
try shutting it off, start the upload in "smart mode", and then turn it on to re upload the file.
I think I remember having to do this several times to get mine to work when I thought I fried it at first.
Thanks t_xen,
I also wanted to thank you for a previous post of yours that was the final piece of advise I needed to get some sound out of my chip!  It was about the interconnections between the SID and CORE for Smash's boards.  The labeling threw me off but your thread (and especially the replies) totally rocked!
