====== MIDIbox User Projects ====== \\ This space is for user projects and project documentations.\\ Projects don't have to be finished, works in progress should also be linked here!\\ \\ For a complete overview of official projects see the MBHP [[Projects]] page! <box 47% left blue|**Controllers**>{{ icon:icondevice.gif}} \\ **//Completed //** \\ \\ * **[[Protodeck]]** - Ableton Live Controller * **[[pedal_box|Pedal Box / Board]]**- Expression Pedal Controller / Floorboard * **[[stuartm_stukontrol|Stukontrol]]**- MIDI Controller * **[[Modulbox | Modulbox]]**- Modular Control Surface * **[[scratchcontroller| Scratch controller]]** * **[[questionable| Questionable]]**- DJ Controller * **[[wild_weasel| Selektor]]**- DJ Controller * **[[tos_-_a_tds_controller_blog| TOS ]]**- DJ Controller * **[[http://midibox.org/forums/topic/16736-yatk/|YATK Forum Thread]]** * **[[acsensorizer|ACSensorizer]]** - Sensorizing controller * **[[arkade|Arkade]]** Joysticks, Distance sensors, Ribbons Controller * **[[MIDIboxKB - using a C64 keyboard as input|MIDIboxKB]]**- C64 keyboard as input * **[[http://midibox.org/forums/topic/8981-scan-matrix-extended-voirinov/|VOIRINOV]]**- Akai MPD24-like MIDIbox * **[[MIDIbox UC]]** - Universal Control: Extended SysEx Handler * **[[mb-lre8x2cs_pcb|MB-LRE8x2]]**- 16 Led rings encoders * * **[[msq-cc-lre|msq-cc-lre]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - based on 2x LRE8x2 - Nord Drum Edition\\ * **[[msq-cc-lre|msq-cc-lre]]**- 8Ch x 32CC Bank-Syntheditor with Motion Automatition and Velocity Offset from Triggers - with BCR2000 instead of LRE - Nord Drum Edition\\ //In Progress // * [[MB-Modulbox-NG]] Modular Controllers * [[mb_olre16|MB_OLRE16]]- 1 row of 16 encoders with oleds and 32 segments RGB led rings. * [[The Thing by Mpro-ject|The Thing DJ-Mixer]] * [[Fadercore - Fadermodule for Audio DAW]] * [[MIDIboxFX - midifiying analog gear]] * [[Korg Wavedrum MIDIfication]] * [[Velocity converter]] </box> <box 47% right red|**Synthesizers**>{{ icon:iconspeaker.gif}} \\ **//Completed //** \\ \\ * **[[Wilba_MB_6582|MB-6582]]**- MIDIbox SID Synthesizer V2 using 8xSID PCB and "step C" control surface PCB. * **[[MB-TWINsid]]**- MIDIbox SID Synthesizer V2 using 2xSID PCB and dedicated control surface PCB . * **[[mb-sidr8tr:start|SID R8TR]]**- 3U rackmount case SID * **[[midibox_fm_21|MIDIbox FM V2.1]]** - A complete multitimbral synth using two OPL3s and the STM32F4 core * **[[OPL3 module, modified]]** - 5V option * **[[midibox_vgmplayer|MIDIbox VGM Player]]** - Plays VGM files on up to four Sega Genesises' sound chips (YM2612/YM3438, SN76489/SN76494/SN76496) * **[[apparat_20_construction_blog|Apparat 20]]** - Seppoman's MBFM & vocoder phone * **[[AntixFM|Antix MBFM]]** - A MBFM Build by Antix * **[[MIDIbox SpeakJet]]** - SpeakJet speech synthesizer * **[[MIDIbox SpeakJet K64 Modul]]** - C64 Keyboard Controller for SpeakJet * **[[midibox_tia|MIDIbox TIA]]** - Atari 2600 Synthesizer * **[[MIDIbox AY (YM) V2]]** - AY-3-891x / YM2149 Synth * **[[Coresound]]** - Pic based digital synthesizer //In Progress // * [[MB-ReSynth]] - 4U FM/TIA/SID Synths * [[MB-DigiRoland]] - Roland Analog Drums driven by digital Pots * [[MIDIbox Quad Genesis]] - Up to four Sega Genesises' worth of sound chips, controlled by STM32F4 core. 4x YM2612 OPN2, 4x SN76489/94/96 PSG * [[MIDIbox SNES APU]] - Super Nintendo APU synth * [[MIDIbox POKEY]] - Atari Pokey synth * [[MIDIbox 3396]] - CEM3396 based synth * [[MIDIbox SD Card Sample Player]] - SD Card Polyphonic Sample Player </box> <box 47% left green|**Miscellaneous**>{{ icon:iconlp.gif}} \\ **//Completed//** \\ \\ * **[[MIDIboxMixer|MIDIbox Mixer ]]** based on PGA chips * **[[MB_matrix|MIDIbox Matrix]]** - MIDI I/Os Matrix * **[[:home:project:midi_mapper|MIDI Mapper]]** - MIDI Channel Mapper * **[[MidiMasterClock| MIDI Master Clock]]** * **[[MB Clock]]** - How to handle a realtime clock (RTC) with I2C * **[[ssm2044_pcb|SSM2044 VCF]]** - Low pass filter board * **[[clock2audio2clock]]** - Record/Playback Midiclock via Audio-Recording //In Progress// * [[MB Sync24]] - Midi clock to Roland sync24 converter * [[MB Visual Metronome]] - Midi Metronome * [[MidiboxDMX]] - DMX light control with Midibox * [[MBlight Mind-Machine]] - an audio/visual brain stimulator * [[mb-scope]] - 6ins+2sync Dual TFT Scope * [[midibox_audiomatrix|MIDIbox Audio Matrix]] - digitally controlled analogue audio/CV patch router * [[MIDIbox Live]] - Complete and automatic integration of MIDIbox and Ableton Live using LiveAPI. * [[ssm2164_pcb|SSM2164 VCA]] - Quad channel VCA board * [[EASY CV]] - EuroRack-sized - 8x LFO+ENV-combi with 8AOUTChannels for VCA-VCF based Setups * [[mb_2069|MIDIbox 2069]] - Based on the KORG NJM2069 Music Voicing System </box> <box 47% right orange|**Sequencers**>{{ icon:iconnote.gif}} \\ **//Completed//** \\ \\ * **[[mididocs:seq:blm16x16_x|BLM16x16+X]]** Matrix Controller * **[[tpd_pcb|TPD]]** - Track Position Display * **[[16x4blm_pcb|BLM 16x4]]** - Button LED Matrix * **[[MIDIbox Arp]]** - A MBHP Arpeggiator * **[[DSEQ32]]** - 32 step drumseq * **[[chaos_matrix|Chaos Matrix]]** Oberheim Matrix 1000 Programmer //In Progress// * [[Triggermatrix]] - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup * [[16th fixed PolySequencer]] - 16th fixed 2x4track-poly-Sequencer - the poly note/melody-source for [[Triggermatrix]] * [[AlternativeSequencer]] - Alternative ideas for sequencers * [[MB808]] - 808 Clone Sequencer * [[MB909]] - 909 Full Clone </box> \\ \\
