folly
65 -
Everything posted by folly
Hi Doggle! Today I tried a pitch bender Doepher. even with this my Varranger works well. I realized that my varranger can not handle so many midi events in such a short time. I will talk with the manufacturer of varranger of this problem so let's see what will tell. I have not had the opportunity to try a different hosts. Today I will try with one-man band. Thanks Doggle.Doggle Thanks for your availability.
to the right. I can not explain well the problems in English, and I apologize. I did the tests that the said. watch. txt file. great vaccations of events between KORG AND MIDIBOX korg event modulation.txt midibox kb event modulation.txt
hi Duggle you are my hope for this project. I would not throw it all away. because I have spent time and money to build this project. thank!
my host is Varranger www.varranger.com I tried with midi-ox, it all seems ok inputs and outputs. do not know anymore what to do. as you say and too fast for my varranger. thank you!
Hello DUGGLE! I connected MIDIBOX KB, via MIDI-OX. What should I see abnormal? thank!
is already installed on my computer midi ox. but I do not know how to use it.
I tried it and it works well. perfectly.
I made a recording, so I'm feeling problems modwheel. test modwheel.MP3
hello Duggle. I took pictures. so see the messages that sends modwheel. I noticed that when I move modwhell, the processor of the computer increases the workload of 8-10% so my varranger slows the song. I also use a Korg 01/wpro as a master keyboard, but does not give me problems. I also tried with another computer, and I laid out the problems. thank!
HI DUGGLE! I tried everything today to calibrate pitch. and mod. nothing to do. my varranger not digest pitchwhell and modwhell of MIDIBOX KB. I do not know what to do. thank
hi ! I think the correction is not a problem. MIDIBOX KB supports Ainser 64? I just need 2 pot. thank!
Thanks for the reply! I have already drawn Ainser for 20 pot. Saturday prepare the pcb, after I tell you if that's okay. still remains the problem of pitchweel and modweel. It might be possible to connect the pitchweel and modweel of ainser64? THANK!
I use MIDIBOX kb, with varranger software, since I enabled Pitchwheel and modwhwell my varranger and become crazy. when I have time, I'll make a recording. In my opinion, too many midi commands sent from midiboxkb makes them dizzy.
Hello Duggle! As I wrote above I built the circuit with lm324 and I managed to get the right volts. problem and that there too much sensitivity in software midibox kb regard to the potentiometers. This thing or noticed even in MIDIO 128 V3 with potentiometers. Do you think that the programmer can do something to improve this problem? THANK!
hello! I used LM324 and I managed to get the correct volts. there a problem with pitchbender. trying with Midistudio, I saw that modwheel never stands still at zero, it always turns. I tried using the potentiometers without your circuit and behaves the same. I think there still to be done on the software. thank!
Hi! I redid the simulation with vref 5v. works well. I used the MC33079 because I have more than 10 pcs, and I'm sure you are good at 5v. I have used correctly on a digital effect BEST REGARDS
Hello Duggle. With pdf files and excel I have never had problems with downloading, only the pictures are not unloaded. now all ok. As a simulator I use NI Multisim. tomorrow I build the PCB of your project so let's see how it works in life. thank you very much!
Hello DUGGLE! I simulated your design and works well. Now build the circuit board. thank you again!
thank you for your work. you are very kind. I can not download photos. (Sorry, you don't have permission for that!) you can send on my email info@harddiskrecovery.it ? thank !
thanks Duggle. accept any information. there are no problems with the construction of various electronic, I have built many electronic circuits. thank!
hi! I drew a diagram with all the volt. best regards Schematic - pitchwheel modwhell.pdf
hi! thanks for the reply. The joystick and new, bought as a spare Roland VA76. it self there are joysticks that are good for this project tell me what they are. I like this joystick roland, but itself is not good, I delete. best regards, Silviu
hi! impossible to calibrate the joystick. my modwell-min: 50 max: 110. there any solution flow min: thank!
http://www.ucapps.de/midibox_ng_manual_hw.html (ENCODER SECTION)
