sis.tm
  • Content count
    68
Everything posted by sis.tm
  1. MIDIbox SEQ V4 Release + Feedback
    Hi Lukas412, these are exactly my symptoms as well . I didn't try the galvanic usb isolator because i workaround the problem by powering the seq by an external power adapter and use a separate midi cable from my computer to the seq for the communications. This works quite good for me at the moment but i am very curious about the galvaniser. Maybe i will order one next month to try if this fixes it.
  2. midiphy Eurorack Expander Modules
    What kind if db25 cable do you use? I see super shielded expensive ones and very cheap ones. The one i have right now  is around 1.5m and i like to get a shorter one.   Cheers, Niels
  3. midiphy Eurorack Expander Modules
    Wow Peter, Thanks for the helpfull article. To be honest that when i read the Graham article i only understand 10% of it and what i understand from others is that it is a hard to understand or fixed subject. When looking how other People build their studio and big eurorack systems i probably started differently then the stuff i have bought right now but getting into eurorack is costly and selling and buying new stuff to avoid humm is not in my 2020 todo list ;-) for now fixing it by a workaround is good enough for me and saves money on buying new cables and psu's and new cases. I find it a really interesting topic like all things with electronic engineering and can only have deep respect for People knowing this stuff. Too bad in my life i probably never get this skill at a good level because of time ;-) i really like to solve this ground thing from the core so i can understand it but i am throwing the towel with a workaround because for now i like to create music with a nice sequencer. Thanks again for trying to let me understand these kind of things.   Cheers, Niels
  4. midiphy Eurorack Expander Modules
    Just an update. I went to a local store and bought myself a Roland UM-One mk2 . The cable cost me 39 euro and when connecting it like described above i get no noise. A very good midi clock to the midiphy from Ableton and Bitwig . Updating with Mios Studio works. Bad thing is that it requires drivers but hey for now a driver is better then noise :) Probably and midi interface would have done what i now describe but just for the info :) Cheers Guys, i am happy again. Goodbye to ground noise and hello to white noise :)
  5. midiphy Eurorack Expander Modules
    Thanks for the detailed answers! i did some testing with some other computers i have lying around and they all produce the same noise like my mac mini does. The noise gets louder when i play some notes on the midibox seq and when i stop playing it gets less. In my case the only thing i need to get the midiphy connected to my computer is for midi clock. Since my UAD interface does not have midi out i am trying to do this via the usb of the midiphy but maybe i step off this plan. Andy and Peter where so kind to provide me with a Multi midi thru pcb gift and maybe this is exactly what i have to build to tackle this noise problem. Since you already are saying Andy. Ground noise is a hard to find problem and since i am not really a technician in finding these kind of problems i think i am going for the midi interface road and provide usb power to the midiphy by an usb power supply and not via a computer. Also what i forgot to mention earlier is that i connect everything via an usb hub that is externally powered but this has no impact when i remove it and connect it directly to the mac mini. Also the mac mini has no ground power connection. let me build a midi thru interface from Midiphy and see if this works like i want to :) Thanks again for your help!
  6. MIDIbox SEQ V4 Release + Feedback
    Hi @TK. i think you are right about the waiting of a new apple update , at least that is mostly what i always do but ok i am not a programmer at all :) thanks for testing the cv modules out for me and glad it works for you ! For now i reinstalled Mojave back on my mac. Catalina gave me way to much audio problems.
  7. midiphy Eurorack Expander Modules
    Hi @latigid on I thought i was happy running the midibox from USB till i noticed that my productivity went down the drain like having to good midi clock for syncing to the daw etc. So i decided to dive deeper into this issue because i like to have the midibox connected to my computer via usb and have the eurorack connected as well. The power is connected by flying bus boards but i have no issues with other modules and noise. Also moving the bus cables does not make any change in noise. I also powered the euroreiver by using an usb power from a phone adapter and jumpered j5 the right way. This has no impact on the noise. Then i cut the 0v by removing the J0 jumper and that cut the noise directly and the module is still working like it should. Since i am no technician at all, what is the inpact of cutting this 0v ?  Cheers, Niels
  8. MIDIbox SEQ V4 Release + Feedback
    Hi @TK. yes i also use 10.15. Normally I never have probs with mios updating and yesterday I tried it several times and all functionality worked except it crashed while pressing play. I removed the sd card. Emptied it etc but all no luck in getting it to run. This morning I went back to 0.95 and then up to 0.96 again (same file as yesterday) and now it works. Can't put my finger on it to be honest except that I don't like Catalina with all the strange thingies. You also use cv modules right? Do you also get noise when you connect the midibox to your computer by usb and try to record stuff in the daw? When the midibox is connected by usb I get a lot of ground hum. Just wondering if you have the same issue. Cheers Niels
  9. MIDIbox SEQ V4 Release + Feedback
    Hi @TK. This morning i flashed 0.95 and it started working again and now flashing 0.96 pre9 and that one also works perfectly. Now i flashed the 0.96 again and it works . So i dont get it anymore but didn't change anything with last night test but happy that it works now :)
  10. MIDIbox SEQ V4 Release + Feedback
    i uploaded the new hex file but when i start to press play on my midiphy now i get a hard fault at pc=0x08036200 . I am trying to find a way to download 0.95 again but i don't know how *shame* :)
  11. MIDIbox SEQ V4 Release + Feedback
    very cool .. labeling of tracks is something i was looking for :)
  12. midiphy Eurorack Expander Modules
    Hi Andy, Happy New year! Must be a good year because the first thing i tried from you list was to connect the midiphy with usb not via the mac but via the power outlet and goodbye noise. It felt like the episode in breaking bad caching the fly in the meth lab Thanks again for the help and now for me time to clean up the mess i made in my room finding the issue ;-) Cheers, Niels
  13. midiphy Eurorack Expander Modules
    Hi, I removed all the unneeded power supplies and all is connected directly to the mac and via a grounded wallpower. I forgot the put one cable between the usb and expert sleepers es-9. When i remove the complete midiphy and use only eurorack i get no noise and a clear sound. Thanks for checking out! Cheers Niels
  14. midiphy Eurorack Expander Modules
    Evening all, I noticed something strange with the midiphy connecting to the Euroceiver board. When i connect the cable to the Euroceiver i introduce a ground noise on my modular. When i remove the cable it is completely silent as it was. Do you guys also have this humm grounding issue ? It is extreme noticable when using headphone on a louder volume. For now have a nice happy new year!! Cheers, Niels
  15. midiphy SEQ v4+
    Hi, on the ja board mine shows the gate of the track but i saw other movies showing track position and you say you can also show bpm. How exactly do you change the display of the ja board?  Cheers, Niels
  16. midiphy Eurorack Expander Modules
    Cool thank a lot!!!
  17. midiphy Eurorack Expander Modules
    Hi, would it be an idea to put the panels on modulargrid with power consumption etc. My rack over there is so empty without the midiphy panels. Do you have an idea of the power consumption?
  18. midiphy SEQ v4+
    i am interested, sent you a PM
  19. midiphy Eurorack Expander Modules
    Just to finalize my question about lfo. Thorsten gave the following tip that works like a charm.   assign track to CV in LFO page, set the ExtraCC# to 16..23 16 will send to CV channel #1, 17 to channel #2, etc - which means: with the CC number you can address the CV channel you would like to use as LFO output Very happy with this feature since this saves me  on buying a special lfo eurorack board ;-)
  20. MIDIbox SEQ V4 Release + Feedback
    Yeah working perfect @TK. ;-) thanks for the tip, this makes my setup even more complete. Cheers Niels
  21. MIDIbox SEQ V4 Release + Feedback
    Hi @TK. I am having a blast with the Midibox and the cv expansion eurorack boards made by Midiphy. I was trying to get lfo working on a cv channel but it seems this can't be done at the moment? @Hawkeye had a check at the code and it seems that the current lfo is note based per step and can't be used for a lfo out to a cv channel i a nice flowing way. If this is possible i would really love to have this to get more fun with lfo's and CV to my eurorack in the future. Maybe i am doing somehting wrong and it already can be done but at the moment i am scratching my head :) Cheers, Niels
  22. midiphy Eurorack Expander Modules
    Thanks Peter for checking this out. I will post a request for it :) Have a nice weekend/beer!
  23. midiphy Eurorack Expander Modules
    Evening Andy, Too bad, i thought it was something simple to fix. Yep tried notes, different CC values. It should be possible to implement because when i go to the CV calibration screen and set the calibration to wave then i get some kind of lfo and this works but not suited for my purpose ofcourse :) Cheers! Niels
  24. midiphy Eurorack Expander Modules
    Hi All, I am breaking my head to get a lfo out to a cv port. I read the forum and this question has been answered earlier but still i don't understand. I am creatng a new CC track on AOUT channel 1 , i init the track and set FX -> LFO to on . I am wondering what the next step will be because whatever i try nothing happens with the CV on channel 1. Do i have to put the CC value to something on the track? I also read the manual but i am stil stuck. Many thanks! Niels
  25. midiphy SEQ v4+
    Congrats, Looking nice with the blue scheme and smaller knobs. Maybe have to open my midiphy soon again ;-)
