aurel33
22 -
Everything posted by aurel33
Speed up scanrate of NG by kicking out other scanroutines?
aurel33 replied to FantomXR's topic in MIDIbox NG
I don't use a MAP with 24 values, i'm using the interpolation MAP as described in my setup : #using an interpolation map to define the velocity curve MAP1/BYTEI 0:0 40:24 71:52 100:85 127:12 -
I don't limit anything, i've just reported 24 different velocity values in midiboxng with my settings. -
Hello, a quick suggestion for midibox KB, i guess it would be relevant to include the MAP feature in the midiboxkb, as it's really useful for adjusting keyboard velocity. Cheers!
If it can helps, I'm using midibox ng and i'm getting 24 different values on fatar tp 40m, but i'm using the map feature. I also used MidboxKb for a long time and i was sometimes getting some stuck notes. Then i switched to midibox ng when the MAP feature was added, everything is now working great, i really can't explain the problem i had with with midiboxkb. # reduce number of SRs for faster scan # with 2 SRs the scan takes ca. 500 uS instead of 2.5 mS SRIO num_sr=2 # keyboard configuration KEYBOARD n=1 rows=12 dout_sr1=1 dout_sr2=2 din_sr1=1 din_sr2=2 \ din_inverted=0 break_inverted=0 din_key_offset=40 \ scan_velocity=1 scan_optimized=1 note_offset=21 \ delay_fastest=60 delay_fastest_black_keys=0 delay_slowest=300 \ make_debounced=0 # using an interpolation map to define the velocity curve MAP1/BYTEI 0:0 40:24 71:52 100:85 127:127 # send MIDI event with mapped velocity value EVENT_KB id=1 type=NoteOn chn=1 key=any use_key_number=1 range=0:127 kb_velocity_map=map1 kb_transpose=0 1 4 7 17 19 22 25 29 33 37 41 45 53 57 63 67 73 89 95 102 109 116 122 127 -
Debugging my core STM32f4 + diomatrix + fatar keybed
aurel33 replied to aurel33's topic in Testing/Troubleshooting
Next step, i'm trying to make my AINSER8 module work, i followed the schematic of the midibox kb thread,and connected my sustain pedal but i'm only constantly getting this message in midi in: [13027.175] b0 40 13 Chn# 1 CC# 64 = 19 [13027.185] b0 40 12 Chn# 1 CC# 64 = 18 [13027.190] b0 40 13 Chn# 1 CC# 64 = 19 [13027.200] b0 40 13 Chn# 1 CC# 64 = 19 -Red led is on. -Jumper J4 is on 1. -Connected the sustain pedal to J6.A0 i've used the following command: set kb 1 ain_sustain 1 [13004.399] Keyboard #1: Sustain Pedal assigned to J5.A0! The weird thing is that on the schematic and PCB, there's no J5 but only J6. Here's a quick pic of my setup: Thanks, -
As for velocity curves, is there a way to tweak them in midiboxkb ? A bit like in Pianoteq, where you can specify velocity range ie "Velocity = [0, 1, 14, 27, 43, 54, 66, 91, 125, 127; 0, 0, 7, 28, 64, 87, 102, 120, 127, 127]" [input:output]format. https://www.pianoteq.com/velocity_curves Thanks!
Now working perfectly !! It was the cable from the adapter to the keybed that was reversed... I guess all my cables were reversed, i'm so stupid... I'll post a picture of the whole rig when done, i guess it will help other newbies like me. Tk, FantomXR, thank you so much. Now, time to tweak velocity curves, fantomxr do you have some recommendations? Cheers, -
So, i've tested my setup with a fatar tp20 and fatar tp40, the result is exactly the same, so the keyboard is not involved. Tk, i have one question, I want to be sure my outputs are working and i wasn't able to use your output testing method, could you confirm it's the right way to test it: I0 ----- (anode)DIODE ------ O6/O7 ? Thanks! -
Hmm i don't think so, as i said i connected it to a sl880 motherboard and it worked perfectly. -
i'm using a fatar tp40m from a nord keyboard. ps: i've tried it on a sl880 board and it worked. -
Thanks TK! making progress! Tk > i wanted to test the outputs with your method, i've used a diode 1N4148 between I0 and O6, then I0 to O7 and didn't receive any signal(anode on I0 and cathod on Ox). As for the midibox kb setup, I've activated the keyboard debug on and it's really helpfu! What is really intriguing is the fact that the midi output is alternating between six low notes(in green) and two high notes(in red), and that i don't get any input from the lowest octave on the keyboard, and highest octave part of the keyboard. Here's one octave run starting from C1(the second lowest C on the keyboard) C1: [10053.956] KB1: DOUT#1.D6 / DIN#1.D5: depressed --> key= 5, break contact, note=D-0 (26) C#1 [10066.147] KB1: DOUT#1.D4 / DIN#2.D6: depressed --> key=54, break contact, note=D#4 (75) D1 [10078.940] KB1: DOUT#1.D4 / DIN#2.D7: depressed --> key=55, break contact, note=E-4 (76) D#1 [10099.686] KB1: DOUT#1.D4 / DIN#1.D0: depressed --> key= 8, break contact, note=F-0 (29) E1 [10131.708] KB1: DOUT#1.D4 / DIN#1.D1: depressed --> key= 9, break contact, note=F#0 (30) F1 [10147.171] KB1: DOUT#1.D4 / DIN#1.D2: depressed --> key=10, break contact, note=G-0 (31) F#1 [10632.243] KB1: DOUT#1.D4 / DIN#1.D3: depressed --> key=11, break contact, note=G#0 (32) G1 [10665.443] KB1: DOUT#1.D4 / DIN#1.D4: depressed --> key=12, break contact, note=A-0 (33) G#1 [10704.495] KB1: DOUT#1.D4 / DIN#1.D5: depressed --> key=13, break contact, note=A#0 (34) A1 [10725.780] KB1: DOUT#1.D2 / DIN#2.D6: depressed --> key=62, break contact, note=B-4 (83) A#1 [10906.585] KB1: DOUT#1.D2 / DIN#2.D7: depressed --> key=63, break contact, note=C-5 (84) B1 [10765.479] KB1: DOUT#1.D2 / DIN#1.D0: depressed --> key=16, break contact, note=C#1 (37) C2 [10777.883] KB1: DOUT#1.D2 / DIN#1.D1: depressed --> key=17, break contact, note=D-1 (38) C#2 [10949.601] KB1: DOUT#1.D2 / DIN#1.D2: depressed --> key=18, break contact, note=D#1 (39) D2 [10964.364] KB1: DOUT#1.D2 / DIN#1.D3: depressed --> key=19, break contact, note=E-1 (40) D#2 [10982.418] KB1: DOUT#1.D2 / DIN#1.D4: depressed --> key=20, break contact, note=F-1 (41) E2 [11000.697] KB1: DOUT#1.D2 / DIN#1.D5: depressed --> key=21, break contact, note=F#1 (42) F2 [11017.863] KB1: DOUT#1.D0 / DIN#2.D6: depressed --> key=70, break contact, note=G-5 (91) f#2 [11095.561] KB1: DOUT#1.D0 / DIN#2.D7: depressed --> key=71, break contact, note=G#5 (92) -
Good news diomatrix input is now working! The keyboard is working too ! By the way, my cables for the dio to adapter were working(they were 1:1) However, still have some problem : my keyboard is only active on 61 keys and outputs one step higher, but it may come from the midikb setup. Edit: Ok i did some more tests with the exact same midiboxkb setup, i must have screwed again on the cables or adapter(mk-10 03 + bk10-04 soldered) All along the keyboard, i get a sequence of right notes for 6 keys and then two keys are screwed and so on for 61 keys. For example, on my keyboard : Lowest F outputs G3 midi Lowest G outputs A1 -
Thanks for your patience and support guys! I don't know why i wanted pin1 to be always pin1, i had all the cable wrong... So one twisted cable from core to dio, and two straight cable from dio to adapter, well still not working but at least i guess i have the cables right now. I think i'll replace the ICs, i may have killed one with my wrong wiring... So did another -
Yes, the socket orientation is reversed on chris pcb, i guess he did it to have a straight cable. Anyway i did a twisted cable and connected it, tried Vss to I0, still no input in mios, i'll check all my solders tomorrow, i also may have damaged some components if i connected the cable the wrong way :( -
Well i don't understand, i used this picture from diomatrix page to make my cable : The cable at the right on my picture is the same to me, i don't see the difference :( -
Thanks fantomxr ! Yes i’ve checked your answer but the problem is i can’t figure out what is a twisted cable and how to do it, here’s a picture of two cables i’ve made, are they different ? Is the one on the right twisted ? I’ve tested both and it’s exactly the same behaviour, not working LI'm a bit lost, i thought there was only one kind of wiring used(red cable on pin1), if i "twist" the cable, it would mean red cable would be on pin9 on one side and pin1 on the other ? Thanks for your support! -
I installed mios128 and it's still the same, no sign of life from the inputs... i guess i'll have to double check my solders... :( -
Thanks Tk, that's a perfect test. I did it with the input(connected J2 Vss to J3.I0), and i didn't get anything, i guess i must have screwed somewhere on my diomatrix... None of the input works :( It seems the tension is ok on the board, i'm getting 4.1V on both HC595 and HC165 -
Thanks for the answer! I've turned off optimization off, but still not getting anything in my midi input window, is there something to setup with the router command? I managed to make the virtual keyboard work with " router 1 USB1 all USB1 all" Also, it seems there's a "twisted cable" needed on the core> dio connection, i don't really get it, does it means pin 1 = pin 9? it's weird because on the schematics it's really 1:1, and you can see on my installation, pin 1 is going to pin1. Thanks! -
Thanks for sharing fantomxr, one question regarding the fatar adapter, what are the BK10-03 and BK10-04 jumpers used for as it's not written on the pcb ? For a 88 keys keyboard, do we need to solder bk10-03 + mk10-03 ?
Hello all, I've build my core stm32F4(fantomxr pcb) + diomatrix + fatar adapter to connect my 88 keyboard. I installed midibox kb and connected everything, but i can't output any midi, so i guess i did something wrong :) I tried the virtual keyboard and i didn't receive any midi input in my daw, so i was wondering if my setup was correct, it seems midibox kb is loaded correctly(cf picture). Here's the setup of my midibox kb: [13020.190] kb 1 debug on [13020.190] kb 1 midi_ports 0x0001 [13020.190] kb 1 midi_chn 1 [13020.190] kb 1 note_offset 21 [13020.190] kb 1 rows 12 [13020.191] kb 1 velocity on [13020.191] kb 1 release_velocity off [13020.191] kb 1 optimized on [13020.191] kb 1 dout_sr1 1 [13020.191] kb 1 dout_sr2 2 [13020.192] kb 1 din_sr1 1 [13020.192] kb 1 din_sr2 2 [13020.192] kb 1 din_key_offset 40 [13020.192] kb 1 din_inverted off [13020.193] kb 1 break_inverted off [13020.193] kb 1 make_debounced off [13020.193] kb 1 break_is_make off [13020.193] kb 1 delay_fastest 50 [13020.194] kb 1 delay_fastest_black_keys 0 [13020.194] kb 1 delay_fastest_release 150 [13020.195] kb 1 delay_fastest_release_black_keys 0 [13020.195] kb 1 delay_slowest 1000 [13020.195] kb 1 delay_slowest_release 1000 [13020.196] kb 1 ain_pitchwheel off [13020.196] kb 1 ctrl_pitchwheel 128 (PitchBend) [13020.196] kb 1 ain_pitchwheel_inverted off [13020.196] kb 1 ain_modwheel off [13020.198] kb 1 ctrl_modwheel 1 (CC) [13020.198] kb 1 ain_modwheel_inverted off [13020.198] kb 1 ain_expression off [13020.198] kb 1 ctrl_expression 11 (CC) [13020.199] kb 1 ain_expression_inverted off [13020.199] kb 1 ain_sustain off [13020.199] kb 1 ctrl_sustain 64 (CC) [13020.205] kb 1 ain_sustain_inverted off [13020.205] kb 1 ain_sustain_switch off [13020.205] kb 1 ain_bandwidth_ms 0 [13020.205] AIN Calibration Mode disabled. Then i wanted to check if my diomatrix was ok so i connected I1 to O1 on J3 to check for midi input, but i did not receive anything(no data in mios input). Is there a way to troubleshoot easily diomatrix ? or some tension to check on the core stm32F4 , i've checked my soldering and connection with a multimeter and everything seems ok. Thanks!
Hello everyone ! I've just started building my midibox kb project(with a fatar tp40 keyboard), i have some question regarding the connection of a sustain pedal and aftertouch strip to the Ainser8 module. I have some trouble reading the ASCII shematics and by reading the thread it seems i need a 1k resistor, but i'm not sure where to put it. Is there some schematic available? I'm think about : the + of my sustain pedal > 1k resistor > J6.A1, and the ground to Vs. Am i right? For the aftertouch strip, i' dont have any idea, i have 2*4 strip. Thanks! Aurélien.
