193 -
18
Posts posted by Noise-Generator
Guess you're at the right side of finding it. Also guess it's just a bad solder point, connection thing.
Looks like this is just a very easy problem with contrast an lumi potis?
I would look out for bad connections, also. I guess it's just a mechanical problem not complicated.
Yes, first you burn the bootloader, than put pic inside sammich, use mios studio, you will get the info that there is nothing connected because you now need to upload mios8_v1_9h and after that you should get the message that your device is connected and than you load up your sammich hex.
Hello,
The Swinsid has power, so the led is on. Swinsid only needs 5v at the 5v lane and the 9 or 12v lane is not necessary, it just don't cares.
I must ask this because you just write you have problems with the midi upload and I don't know if you just missed something.
Have you followed the flash procedure exactly?
If the pic is ok, than the thing you must do is to check the traces via multimeter-peep and sheet. Or you first resolder a little bit some points which look suspicious.
11 hours ago, jaytee said:
With all due respect…this is pretty ridiculous. *All* digital hardware is made with analog parts—it’s transistors all the way down. *All* electronic hardware, digital or analog, warms up in use—no electronic component is perfectly efficient; they’ll all have waste heat.
Yes, maybe it's not related "there". Not really "there"
But it would be interesting to know how exact the unexactness happens.
Old digital/analog combination suffered from influences like electromagnetic fields - bad or "not perfect" isolation distorting the signal path, digital to analog converting, amplifiying, indifferences...
Do all SIDs sound the same? Differences in the newer ones 8580, 6582, not much to recognize, Revisions of 6581s measurable?
As far as I know just the fpgasid
Feedback is based on SID Audio In and the SwinSID Ultimate is supporting that. It's a good point to mention this here SID Clone List so in future I will care about that.
A Noise Gate is an Effect which let you choose on which point it should pass the signal.
For example if you use an Microphone and it should just react to your speech than you tweak the treshold to the point it shall react. It's an standard effect you probably own as a Software Plugin.
23 hours ago, 6040 said:
I probably should not have mixed two issues into one thread. What is the purpose of the Sid Ch Select (L/R)? I cannot hear any difference, not even on stereo patches.
I wondered about that too but had not invest into answers but this could explain it:
http://www.ucapps.de/midibox_sid_manual_l.html
- SIDn: toggles between LR, L- and -R. Here you can specify, if OSC, FIL and MOD parameter modifications should affect only the left, the right, or both SID channels. The SID number (SID1, SID2, SID3, SID4) has to be selected with the deticated SID buttons.
Because there is also a 6581 Sustain Bug, use a Noise Gate
1 Suggestion: Dead VCA of the 6581
2: Bad solder points from PIC to SID
What happens if you put an 8580 in it's place?
It is not possible to see Midi Ports in the System, you see it just in an App like Cubasis or an App which supports Midi. Also it depends on the IOS Version, I guess. Midi is available at all IOS Versions but maybe all 4 are not shown by older ones.
I see all 4 ports by connecting a Seq4 via USB with my iPad.
I'm not completely sure but it seems that you can do everything via the Mbox NG http://www.ucapps.de/midibox_ng.html because for an individual build you need to configure the stuff to your needs and it's not very complicated with MIOS32.
Seems like an easy fix
Or it is a midi module related issue.
You could find out if itˋs an issue with the core or the midi module/s by plugging it directly via usb in a Computer.
I don't know.
The best way to find the issue is always check the connections via the multimeter-"beeper" mode and the schematic. 90% of all issues are connection errors.
Hi,
As long as you don't have a concrete plan what you want to do I would try to find tempest user at modwiggler https://www.modwiggler.com/forum/index.php
Do you have 5V or something less?
You may know that but if you have an issue, the first step is to check the traces via eyes and than with the multimeter. Check every connection.
A Capacitor in a circuit has to be the volt value with some room to the actual current. So if you work with 5V everything over that is ok.
Was denn für welche?
Core 8 + Dinx und Douts und iic?
I found this one and try it out as soon as I have the missing parts:
https://www.hgamps.com/guitar-noise-gate/
But it's for guitar and it means some Resistors need to be "reduced"? R1 higher or lower value or will the 1 M pot do the job?
Good question, I don't think so. First you need a Reseller who sell those and he must offer this service. Because of the mass of different models I think no one offers.
Killed two Pics, too but not the same time I guess. But also by overvoltage. Last week I found out that you can run a 6581 with 9V and I guess the 8580 survives 12V at the 9V pin
(This scenario happened but it took not very long until I recognized it, so no guarantee...)
MB SID classic with 4x20 LCD setup question
in MIDIbox SID
Posted
So you´ve got a 4 row Display?
if CS_MENU_DISPLAYED_ITEMS > 5
= If displayed items MORE THAN 5
