15,247 -
Hallo Kay, fuer 64 Buttons benoetigst Du 2 DINX4 Mddule, ansonsten ist alles korrekt. Gruss, Thorsten.
Thanks for the feedback, Steve! Btw.: did you already try the ALPS encoder I sent you? :) Best Regards, Thorsten.
Hi Dan, You will find an enhanced AIN handler for MIDIbox SID here: http://www.ucapps.de/tmp/sid_ain_enhanced.zip it allows you to assign up to 64 pots to any menu parameter, It would be nice, if you could write a short tutorial, how to integrate this driver into the SID application (see the file header) and how to customize the setup Best Regards, Thorsten. P.S.: hope it works... it was a quick hack based on the code of cs_menu_enc.inc ;-)
Hi Erik, most is correct, there are two different device IDs which might confuse you: the MIOS device ID, used to address OS specific SysEx commands, and the SID device ID, used to address application specific SysEx commands. There is only one error in your enumeration - Step Three: the midibox_sid_v1_5b_8580.hex is a preassembled hex file for the PIC16F based version, but you need the PIC18F version which comes together with the source code and can be downloaded from Concepts->MIOS->Download Best Regards, Thorsten. P.S.: this shows again that I have to remove the PIC16F stuff from the main pages as soon as possible, independent from nostalgic feelings... :-/ Because of the detailed step-by-step guide: FAQMARKER
Did you take the different pinning of the 2n3904 into account? Best Regards, Thorsten.
You don't need a seperate voltage regulator, the backlight output of the core module already provides a current-limiter (leads to a lower voltage level) Best Regards, Thorsten.
You mean a "radiobutton" function. Something like this can be realized by using Meta events (MIDIbox64, 64E, MF, NG) - requires programming skills. It's also already used by more specific applications like MIDIbox LC and MIDIbox SID. Best Regards, Thorsten.
I'll definitely also build such a module based on your plans. :) Best Regards, Thorsten.
Hallo, ja, mit MIOS ist das moeglich. Die MB64 Datenstruktur sieht jedoch nur 64 frei konfigurierbare Buttons vor. Eine Erweiterung ist nicht geplant, um sie mit der alten PIC16F Version kompatibel zu halten (jede Aenderung in der Datenstruktur kostet mich schweineviel Aufwand bei der Pflege der Applikation, des mk_syx Scripts und des vmidibox Editors!) Falls Du also mehr Buttons anschliessen moechtest, muesstest Du entweder auf die MIDIbox NG warten (siehe News -> MIDIbox Roadmap), oder den Button Handler in mb_din.inc erweitern. Wie Du dort siehst, verzweigt er nur dann in das MB64 Modul, wenn einer der ersten 64 Buttons gedrueckt wurde. Ansonsten macht er weiter - und hier koenntest Du bspw. einen selbstgebastelten Handler einbinden, der auf die restlichen Buttons reagiert. Gruss, Thorsten.
Hallo Kay, wie soll Deine Box denn spaeter mal aussehen? Ein LCD benoetigst Du bspw. nur dann, wenn Du die Box standalone - ohne PC - programmieren moechtest, oder wenn die Poti- und Buttonwerte angezeigt werden sollen. Falls Du also Geld sparen moechtest, dann verzichte einfach auf das Display (andererseits ist das Display auch eine wertvolle Debugginghilfe). 1a) jep - das Core Modul muss mit einem PIC18F452 und einem 10 MHz Quarz bestueckt werden 1b) siehe oben 1c) an ein AIN modul kannst Du jeweils 32 potis anschliessen, Du benoetigst also 2 AIN module 1d) an ein DIN modul kannst Du jeweils 32 Taster anschliessen, Du benoetigst also 3 DIN Module 1e) Du moechtest keine LEDs einbauen, also benoetigst Du kein DOUT modul 1f) einen BankStick benoetigst Du nur dann, wenn Dir die interne Bank nicht ausreicht. Pro BankStick stehen Dir bei der MB64 16 weitere Baenke zur Verfuegung 2) klaro, siehe auch die Concepts->MIOS->Bootstrap Loader 3) nicht unbedingt, Du kannst Dir den Bootstrap Loader bspw. auch von jemanden in den PIC brennen lassen, der bereits einen JDM besitzt (einfach Mail an mich, kostet Dich lediglich das Rueckporto). MIOS und die Applikation kannst Du dann spaeter selbst via MIDI einladen und updaten Gruss, Thorsten.
No, this requires a special programmer and special software --- and the LVP allocates pin RB3 so that it cannot be used by the firmware. Best Regards, Thorsten.
Please wait until the application has been released... ;-) Best Regards, Thorsten.
This information is embedded in the .hex file, so that the programmer should regognize it automatically. However, here a snapshot with the config settings which are valid for every PIC16F based MIDIbox project: Best Regards, Thorsten.
Btw.: with the MIOS based MIDIbox64 this can be realized by swapping the Min and Max value. This means: when you set the min value to 127 and the max value to 0, the fader value will change in the reverse direction. This feature is not provided by the PIC16F based version. Best Regards, Thorsten.
A very nice presentation and impressing sounds of your upcoming baby! :) I remember AXS very well, this was one of the first virtual synths I tried in the 90s. Due to lack of multitasking capabilities under DOS I sampled the sounds and loaded them into Fasttracker II - an intricate workflow, but it worked. In the meantime I prefer the full integration of a virtual synth into the sequencer (for a simplified automation), or - like you - a synth with it's own control surface for best ergonomic use (-> MIDIbox SID of course :-)). Best Regards, Thorsten. P.S.: Disc space isn't an issue on the midibox.org server, so just send the files to Ian. The realization and the sources of such a project is a great inspiration source.
Hallo, ja, in Deinem Fall sind es dann 256 Events. Mit dem Jogwheel kann man eigentlich ganz fix durch die Liste scrollen, Buttons zur direkten Anwahl einer Seite werden derzeit nicht unterstuetzt, werde ich aber evtl. bei der naechsten Release beruecksichtigen. Gruss, Thorsten.
Sehr gut :) Hier noch ein weiterer Punkt fuer das FAQ (der Dich aber nicht betrifft): wenn das MBHP_USB modul verwendet wird, sollte die MIDI-Verbindung nicht ueber den MIDIbox-Link Port erfolgen, sondern ueber die normalen MIDI-Ports via Optokoppler. Auf keinen Fall die USB-Masse mit der Audio-Masse verbinden, ansonsten entsteht eine Masseschleife. Gruss, Thorsten.
Super! :) Immer her mit den Bildern, schicke sie einfach an tk@midibox.org Gruss, Thorsten.
So long as the programmer reads only '1's, the PIC won't work --- hm, no idea... Best Regards, Thorsten.
Alright - I've written all the required informations into a text file (which goes faster than writing it here in the forum): http://www.ucapps.de/tmp/mios_enc_integration.txt Hope that it works (I haven't tested the code, this is your job... ;-)) Best Regards, Thorsten.
Im GPC Modus kannst Du bis zu 128 Events auf verschiedenen Kanaelen versenden und empfangen - und er laeuft parallel zur MC, das heisst: er kann jederzeit empfangen, und zum senden kann er auf Knopfdruck (per Shift, Toggle oder Switch Funktion, ganz wie Du willst) ein- und wieder geschaltet werden. Den 128 Events kannst Du Namen zuordnen, mit dem Jogwheel kannst Du die Events anwaehlen (ein Fenster: 8 aus 128 ), mit den 8 V-Pots senden. Die motorfader werden im GPC Modus (noch) nicht unterstuetzt, und fuer die Buttons gibt es einen alternativen Layer. Gruss, Thorsten.
Hallo, auch Dir kann geholfen werden. Ich vermute mal, dass die vier freien analogen Eingaenge am PIC nicht auf Masse gelegt sind, deshalb sendet der Core zufaellige MIDI-Events. Zum Button Problem: entferne mal das Kabel zum DIN Modul und verbinde den Anschluss CORE:J9:SI (bzw. den Pin RD1 des PICs) kurzzeitig mit Masse. Das sollte 64 MIDI-Events ausloesen. Kabel wieder wegnehmen - es sollten abermals 64 Events gesendet werden. Wenn dieser Test funktioniert, weisst Du schonmal, dass es nicht am Core Modul liegt. Gruss, Thorsten.
Sure ;-) Have you already programmed an AIN handler which sends any MIDI event when the joystick is moved? This would be a good starting point Best Regards, Thorsten.
Hi Nacho, if verify fails with both programmers, possibly the10k pull-down resistor is not connected to pin RB3? Best Regards, Thorsten.
I've the soundblaster reference book (since more than 10 years now ;-)) which contains all the details, but thanks anyhow :) Best Regards, Thorsten. P.S.: no, I haven't started with the hard/software yet...
