15,247 -
Yes, you definitely want to add a resistor to the base to limit the I_BE current. I_CE doesn't really matter in this case. You can possibly connect 20 or more transistors to every pin Best Regards, Thorsten.
Please don't forget to take a look into the schematic http://www.ucapps.de/mbhp/mbhp_core.pdf which contains the pin numbers, too Best Regards, Thorsten.
Hi, yes, for 25 motorfaders 4 Core/MF modules are required. The number of IO ports depends on the host application. If you are using MIDIbox MF (will be released soon) and conjunction with a generic controller mode supported by the MIDI host application (Cubase, Logic, Sonar, etc.) you can simply chain the modules like descriped under Concepts->MIDIbox Link. If you are planning to use the Logic/Mackie Control emulation, you have to use 4 seperate IOs --- unfortunately the Mackie protocol is not prepared for a single IO port. Best Regards, Thorsten.
Hi *, MIOS release V1.4 is now available for download, it provides following features: the IIC functions are now open for public, they can be used to access any IIC compatible device via port J4 in parallel to the BankSticks. Example: see the lcd7_iic driver there are two new hooks available which allow to monitor the incoming and outgoing MIDI traffic with zero latency: USER_MIDI_NotifyRx and USER_MIDI_NotifyTx. The motorfader driver now works much better with panasonic faders. New recommented calibration values: Alps: 0x0e@8V, Panasonic: 0x0c@8V automatic debouncing has been added to the SRIO driver which compensates temporal spikes caused by low-cost buttons. See also the detailed description of the MIOS_SRIO_DebounceSet function. Just add this function at the beginning of your application (below USER_Init) if required. a new display type #6 has been added which redirects single characters and strings to the MIDI interface. The used protocol is documented in the http://www.ucapps.de/mios/mios_sysex_implementation.txt a LCD message receiver has been added to the MIDI processor. Incoming characters will be print for 2 seconds on screen. Btw.: the same protocol will be supported by MBHP_TV in the next days it's now possible to write directly into a BankStick via MIDI. This opens the possibility to embed the BankStick content into the application by locating the data to address range 0x400000-0x407fff (24LC256; 32k) resp. 0x400000-0x40ffff (24LC512; 64k). Also the upload to multiple BankSticks is supported with the BankStick select function it's now possible to read directly from internal Flash/EEPROM and external BankStick via MIDI. This is a nice debugging help, but opens also the possibility to create backups and to copy (clone) the content of a BankStick New/Updated applications - in principle all applications are upward-compatible, some of them have been enriched by new functions: bs_xfer_v1_4 contains a step-by-step guide how to write, read and edit the BankStick content. Contains also a syx2asm.pl script lcd7_t6963c_h and lcd7_t6963c_v GLCD type #1 has been isolated from the official MIOS release and are now available as seperate modules lcd7_iic example for accessing an IIC device, also an example how to realize a custom display driver midibox_lc_v1_4 now provides software implemented MIDI Rx/Tx LEDs, LED meters and three different touch sensor modes midibox_sid_v1_5c_18f_stepC now also provides software implemented MIDI Rx/Tx LEDs. The Play mode bug in the CFG menu has been fixed, and the MIDI clock is now processed by USER_MIDI_NotifyRx with zero latency Have fun! :) Best Regards, Thorsten.
Hallo Basti, 1) der PIC18F452 wird mit einem 10 MHz Quarz getaktet, bei 20 MHz spielt die PLL nicht mehr mit. Jeder PIC benoetigt seinen eigenen Quarz, wenn Du sie mit einem einzigen Bauelement versorgen moechtest, benoetigst Du einen externen Oszillator, das kommt jedoch meistens teurer. 2) funktioniert, Du kannst den SID-Takt jedoch auch vom Core-Modul abnehmen, siehe MBHP_SID doku, und somit alle 4 Oszillatoren einsparen. 3) ja, der 10k Pull-Up an Pin RD1 sowie der 1k-Pull-Up an RA4 sind jedoch zwingend notwendig, weil es Inputs sind, die nicht floaten duerfen. Gruss, Thorsten.
Great solution, Driftz! :) Yes, although the power-saving time multiplexing there are still so much LEDs which are activated at the same time that transistors at all SR0 outputs make sense. Alternatively you could use a ULN2803 (normaly used to drive relays, see MIDIO128 page) Best Regards, Thorsten.
Thanks for the input, will be fixed in the next days (once my new computer is working properly... ;-)) Best Regards, Thorsten.
MIOS V1.4 will provide a function to read from/write into a BankStick (24LCxx and 24LCxxx) directly via MIDI. This means, that you will be able to burn the MBHP_USB firmware via a MIOS core. And btw.: it will also open the possibility to clone a MIDIsport 2x2, of course only for the people who already own this MIDI interface. Best Regards, Thorsten.
Hi Matthias, the undocumented changes are changes which have been made before firmware v1.910 to avoid questions like "why do I see this or that component in the MBHP core schematic, but not in the MIDIbox Plus schematic?"... it's just to keep it consistent... now I'm surprised that they are confusing users who already built a MIDIbox Plus --- you only need to take care for the documented changes, believe me! ;-) In fact you only need to add the RD# line to the LCD to get v1.910 running on your older MIDIbox variant. you don't need to change the optocoupler. The CNY17-II is a low-quality optocoupler, the manufacturers don't guarantee that the same pull-up resistors are working - in fact most users noticed no problems, but some were not able to get the CNY17-II running. No problems anymore with the 6N138 - so no issue 100 Ohm resistor: just a suggestion by Microchip, but not really required - with this resistor it's easier to add a reset-button - so no issue Pin 4 and 5 are not tied to Vcc/Vss since the firmware doesn't use them as voltage reference anymore (due to layout reasons). It doesn't matter if you connect these pins or not - so no issue the 1k pull-up at pin 6 is for users who want to use the MB1664 variant and don't read the README before trying out the firmware - it's not required if you don't use the MB1664 firmware, so no issue pin 7 never was connected to ground the capacitors between pin 31 and 32 can now be found at the bottom (C3/C4) the MIDIbox Plus firmware doesn't make any additional difference between PIC16F874 and PIC16F877 beside of the snapshots storage Best Regards, Thorsten.
New to ASM programming, where to start?
TK. replied to robin303's topic in MIOS programming (Assembler)
It's also a good idea not to start with a complex application, but to learn the MIOS basics step by step with the short examples, which mostly contain a lot of comments. Best Regards, Thorsten. -
Where does the encoder speed thing go ?
TK. replied to Ian_Hurlock's topic in MIOS programming (Assembler)
So long as MIOS based MIDIbox16E and MIDIboxNG not available, you either have to write a handler which allows to configure the speed like demonstrated in enc_speed_v1_3 (btw.: a nice application to find the optimal settings), or you have to add the configuration directly behind the USER_Init label. Example: ;; set speed value for all 64 encoders clrf TMP1 USER_Init_ENC_Loop movlw 3 ; speed divider 3 movwf MIOS_PARAMETER2 movlw MIOS_ENC_SPEED_FAST ; fast mode movwf MIOS_PARAMETER1 movf TMP1, W ; encoder number call MIOS_ENC_SpeedSet incf TMP1, F movlw 64-1 IFNEQ TMP1, ACCESS, rgoto USER_Init_ENC_Loop Best Regards, Thorsten. -
Just excellent!!! :D Steve, I will remind your invitation once I'm close to Australia again (but it seems that the next business trip goes to China ;-) ) Best Regards, Thorsten.
Hi John, fine that you finally found the error. :) The upload won't work without the specific MIDI-Ox settings since burning data into a flash memory takes some miliseconds - read the instructions at the Bootstrap Loader page carefully for fast success ;-) Best Regards, Thorsten.
Hi Lo, it should work, but I never tried it... Btw.: on some shops the 24LC64 is available as 24LC65 Best Regards, Thorsten.
Since the MIDI protocol used by sidplay2 to access the SIDstation is not free available: no Or do you know any SID player with an open MIDI protocol? Best Regards, Thorsten.
Hi DriftZ, Just read the comment above the function: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS before the shift register are loaded And shift registers are loaded with the frequency specified by MIOS_SRIO_UpdateFrqSet (you should find this function call in your *_init.inc file - normaly every mS The problem with your code is, that ShowLower is called regardless of LEDDIGITS_PATTERN_CTR, 0 BTFSC LEDDIGITS_PATTERN_CTR , 0 call ShowUpper ;; (upper half of digit) call ShowLower ;; (lower half of digit) incf LEDDIGITS_PATTERN_CTR "btfsc" means: skip next instruction if clear - this means that ShowUpper will be skipped on every second cycle, but ShowLower will be called every time. Improved version: btfsc LEDDIGITS_PATTERN_CTR, 0 call ShowUpper ;; (upper half of digit) btfss LEDDIGITS_PATTERN_CTR, 0 call ShowLower ;; (lower half of digit) incf LEDDIGITS_PATTERN_CTR, F or better readable and understandable: IFSET LEDDIGITS_PATTERN_CTR, 0, call ShowUpper IFCLR LEDDIGITS_PATTERN_CTR, 0, call ShowLower incf LEDDIGITS_PATTERN_CTR, F (IFSET and IFCLR are some macros defined by myself (TK style, see macros.inc), they are using btfsc and btfss) Best Regards, Thorsten.
Hi John, two ports were necessary for the old PIC16F based MIDIbox16E application, which will vanish from my website in some months just to avoid *such* confusion. With MIOS all DINX4 modules have to be connected to J9. in mios_tables.inc, MIOS_ENC_PIN_TABLE you have to assign the rotary encoders to the appr. DIN pins. Best Regards, Thorsten.
Of course! Just assign one or two of the following IDs to the buttons of Layer A or B #define ID_MBLC_SWITCH_LC 0x94 ; switch to Logic/Mackie Control Emulation (like radiobutton) #define ID_MBLC_SWITCH_GPC 0x95 ; switch to General Purpose Controller mode (like radiobutton) #define ID_MBLC_TOGGLE_GPC 0x96 ; like a "caps lock" key #define ID_MBLC_HOLD_GPC 0x97 ; like a common "shift" key Best Regards, Thorsten.
Bankstick switching is already supported by the MIOS based MIDIbox64 (beta) and it will be supported by upcoming derivatives (MB64SEQ/16E/MF/NG), and by the next MIDIbox SID version of course. Just for information... ;-) Best Regards, Thorsten.
Hi Dan, the events which are used in GPC mode can be configured in mios_tables.inc, the strings in lc_gpc_lables.inc Ok, and the new release of MIDIbox LC allows to send a MIDI event when entering/leaving this mode: http://www.ucapps.de/tmp/mios_v1_3b4.syx.zip http://www.ucapps.de/mios/midibox_lc_v1_3b.zip This version provides also LED meters and a software controlled MIDI Tx/Rx LED. LED digits are not supported yet, since I have to add some hardware to my box in order to test this feature (can take a while) Best Regards, Thorsten.
Here some beta stuff: http://www.ucapps.de/tmp/mios_v1_3b4.syx.zip - a beta release of MIOS which works much better with Panasonic faders (thanks again to Steve who sent me 3 faders for testing!). I've reduced the speed dynamic range so that the motors are driven slower, but much more precisely. The modification works also with Alps, therefore it isn't require to set a "Panasonic" flag. Required setup: Panasonic faders: 8V, CaliUp/Down: 0x0c Alps faders: 8V, CaliUp/Down: 0x0e I've also fixed the problem described by Steve in an earlier posting, that the faders sometimes don't reach the zero position. Zero position is now reached when the fader value is less than the AIN deadband value http://www.ucapps.de/mios/midibox_lc_v1_3b.zip provides now three different touch sensor modes: ;; following setting configures the touch sensor behaviour. The touch sensors of the motorfaders ;; have to be assigned to the DIN pins in lc_io_tables.inc - the appr. IDs are: ;; ID_FADER_TOUCH_CHN1, ID_FADER_TOUCH_CHN2, ... ID_FADER_TOUCH_CHN8 (8 sensors) ;; If the master fader option is used, the ID is ID_FADER_TOUCH_MASTER ;; ;; TOUCH_SENSOR_MODE EQU 0: touch sensor events (pressed/depressed) be forwarded to the host program ;; like specified in the Logic/Mackie Control specification ;; TOUCH_SENSOR_MODE EQU 1: like mode 0, but additionaly the sensors will be suspended via MIOS, so ;; that they are not moved so long as the touch sensor is pressed ;; TOUCH_SENSOR_MODE EQU 2: like mode 0+1, additionally no fader move (PitchBender event) will be ;; sent when the touch sensor is not pressed. ;; ;; The mode "1" by default to avoid circular troubleshooting requests in the MIDIbox forum from people ;; who don't read this information before starting the application. ;; Mode "2" should be the prefered setting if your touch sensors are working properly TOUCH_SENSOR_MODE EQU 1 Hope that this solves all problems. Best Regards, Thorsten.
The solution is to alternate the patterns on every call of USER_SR_Service_Prepare, so that on the first cycle the upper half, and on the second cycle the lower half will be displayed. It's the same method which is used to multiplex the digits (thats the purpose of the counter...), your eyes won't regognize the fast changes. You could use a register named LEDDIGITS_PATTERN_CTR, increment this counter on every cycle (don't take care for overruns) - when bit #0 is set, write the first pattern to the SR, when bit #0 is cleared, write the second pattern. Best Regards, Thorsten.
I'm wondering why you are asking such questions before experimenting with MIOS in order to realize that this is no issue... ;-) It depends on the used synthesizer if you will hear every single step or not, it's related to the type of parameter, the resolution, the sound engine implementation, the interpolation algorithm, etc... I don't remember the exact behaviour of the DB50XG, but I guess that most parameters can be smoothly changed without clicks. At least the CC controllable parameters, but also some SysEx parameters (I never controlled all of them) Of course, you have to save the current value of a parameter in RAM. The USER_ENC_NotifyChange function will be triggered on every encoder event (increments, decrements) and gives you an incrementer which has to be added to the value (7, 8, 16, ... bit doesn't matter). Mostly the incrementer is +1 or -1, but the value can also be greater when: you are using a different speed mode one of your function allocates the CPU for some time, so that the encoder handler received some increments which haven't been notified via USER_ENC_NotifyChange yet Even if the incrementer is > 1, let's say 4 or 6, and you are sweeping from the min to the max value very fast, you won't hear a clicking sound, unless the synth engine implementation is too poor (like Quasimidi stuff for example). Regarding the execution times: with MIOS absoltely no issue since this is an interrupt & event driven system, optimized especially for such applications. When you send a SysEx stream of (lets say...) 10 bytes by using the MIOS_MIDI_TxBufferPut function, your program will continue immediately and the string will be sent in background. Every MIDI byte takes 320 uS, 10 bytes are taking 3.2mS - enough time to do a lot of other things in parallel - printing out a 16-character message and a value on LCD takes maybe 200-300 uS, reading the characters from a bankstick will increase the time, but it will be still less than the transmission of a MIDI event, so that you can ignore it! MIDIbox SID is a nice demonstrator how smoothly parameters can be changed via SysEx - the control surface sends SysEx messages to the slaves and they are processing the incoming data in realtime. Best Regards, Thorsten.
Hi Tub, you definitely want to go for MIOS: the old PIC16F firmware will vanish from my website sooner or later (to avoid unnecassary confusion) and the MIOS based version will provide some new, useful features like a remote control via MIDI, up to 128 banks, on-screen MIDI event & labels editing, jumpless pot group morphing... in addition to the known functions of course... :) Btw.: if there are any beta testers who already own a MIDIbox64 and want to test the MIOS based version (which has grown up in the last months but isn't 100% compatible yet and comes with 0% documentation) just contact me. Best Regards, Thorsten.
