I had this idea when I realised that the Panasonic motorfaders are useless in the LC emulation(not touch sensitive). So i though that instead of the motorfaders to have another 8 encoders that means 17 in total. My querry is firstly are there 8 available spare connectors for the encoders and last does that need changes in the code? Thanx
Hello every1 I connected the buttons as seen in the pdf (eg: default) and I get something very strange. That is the first button was supposed to be REC READY but instead is SELECT Any clues what I am doing wrong?
Hi everybody I ll be quick: Can I use 1N5819 instead of 1N5818 for the 32 diodes on the MF module? This is the only schottky's I come across here in Greece. :-/ Thx
Hi everyone its been a long time since my last post... To the point: I have to solve the following I have a USB to Serial cable but the serial is DB25 Does anyone know what is the cabling to make that DB9 Best regards PS We await all of you in Greece for the Olympics :D
Today I came across a Hitachi LM258 XNB 240*64 GLCD. The chips that were installed was LC7940 from Sanyo. My querry is if this display is KS0108 compatible? Thanx Dimitris PS You can find all the controller infos at: http://www.pacificdisplay.com/lcd_ics.htm
Hello everyboby I ve been away for few of months but now I think I should finnish tha LC Emu. The only problem is that I can't find any G-LCD in Greece so I have to order from EC or USA. I tried reichelt as T suggest but couldnt find the 240x64 KS0107-8 display from displaytech. So any suggestions will be really helpfull. If I use 128x64 I will be able to see everithing? Thanx PS Its to [glow=red,2,300]HOT[/glow] down here 8) 8) 8)
After some research on Panasonic faders i come up with: http://www.panasonic.com/industrial/components/potentiometers.htm Check the Slide Potentiometers/EVA(B)NL/EVA(B)NC which offer: Compact and 3-track version available — servo, touch sensor and audio. The only thing is that I cant find them anywhere in Europe so if anyone knows a Panasonic dealer who can do less than 10 pieces I would like to make an order :) Regards Dimitris PS. STOP WAR make music :-/
