Pearl
    53
Everything posted by Pearl
  1. Hallo ... Für so große Mengen habe ich ein Angebot: Für meine kleine Sammelbestellung ALPS-Motorfader habe ich ungefähr folgendes Angebot bekommen: Distributor: DST-GmbH http://www.dst-gmbh.de.htm Motorfader ca. 22,- EUR/Stck. zzgl. MwSt (im 100er < 20,-EUR/Stck.) Encoder ca. 1,95/Stck. zzgl. MwSt ca. 175,-/100 Stck. zzgl. MwSt zzgl. Versandkosten ------------------------------------------------------------------- Beide verkaufen eigentlich nicht an Endverbraucher und in kleinen Mengen, aber bei DST war man sehr nett und gegen eine neue Sammelbestellung werden die wohl nichts haben. (und ist auf jeden Fall billiger als mein Direktangebot von Fa. Alps!!!) Ich hoffe ich hab damit dem ein oder anderen geholfen :D Pearl
  2. Cool ;D Thanx
  3. Is it possible to mount the motorfader with the motors at the bottom instead of the top like shown in the pdf-sheets? Do I have to change only "vss" and "vdd" and/or the "motor-pins" ? Thanx
  4. Pearl
    record?
    ... 5 Guests, 9 Users Pearl, Thorsten Klose, Da5id, d2k, drDRM, LO, js, Wancho, psydata ;D
  5. Hi ... I thought about switching Houston <-> LC but that doesn't work, because Cubase only supports one Houston in its setup and I want to use 16 MF. But, where is the difference between IFSET MIOS_PARAMETER1, 6, iorlw 0x08 ; set 12th (center) LED if bit 6 of received CC value is set and IFSET MIOS_PARAMETER1, 6, iorlw 0x80 ; set 16th (center) LED if bit 6 of received CC value is set  I thought after ";" are only remarks ?? Bye Pearl
  6. Thanx ... Ok, at the beginning I'll take a small one. If it is too small at the end - no problem to change. Wich kind of fuses are recommended? - quick or slow (in german "flink oder träge") Bye Pearl
  7. Is it possible to use the LED-Rings with 15+1 instead of the normal 11+1 solution? I think, I have to modify the maps in lc_ledrings.inc but I dont't know exactly how or where to modify the "link" to the last LED. Code in lc_ledrings.inc ??: ... ;; move table entry (TABLAT) to [iNDF0], don't increment here movf TABLAT, W IFSET MIOS_PARAMETER1, 6, iorlw 0x08 ; set 12th (center) LED if bit 6 of received CC value is set movwf INDF1 ... Thanx Pearl
  8. Hi there ... I got some questions about power supply of midiboxes. I want to build a complex Midibox like shown at picture. For this I want to use a central power supply. Is ist possible to do something like this? If it is OK, how much has the current of the transformator to be for this? ( At pdf's I found that every Core-Module needs ~ 500mA and the MF-Module needs 1A, but in summery, I think it's too much) I would calculate, that max. 70% of LEDs and MFs are used at the same time. Could it be that the current is too much for one MidiBox,because I want to build and test moduls one by one? (Some years ago I destroyed a pcb while using a bigger transformator than the original.) Thanx for any information Bye Pearl
  9. Thanx Ilmenator! I find a way ! I have webspace with my online account but never used this. After some small trouble i got my picture there. See http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1046743910;start=30#30 Bye Pearl
  10. Thanx Ilmenator! I find a way ! I have webspace with my online account but never used this. After some small trouble i got my picture there. See http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1046743910;start=30#30 Bye Pearl
  11. Hi there ... This is my first alpha version of a midirouter-board It's 80x100 mm with 4 ports, so it's very easy to get 8 Midi-In-Out on a pcb 160x100 mm. I can't do this by myself because of limitations of the freeware version to 80x100mm. Notes: > 2-layer-pcb > I don't know if soldering is easy (dil-sockets?) > mounting holes > not verified Feel free for advices ;) If somebody needs the .brd - file ... no problem :) Bye Pearl
  12. How can i post a jpeg? Do I need webspace everywhere and then create a link with the image-button or is there a chance to get a picture in a message without webspace?
  13. How can i post a jpeg? Do I need webspace everywhere and then create a link with the image-button or is there a chance to get a picture in a message without webspace?
  14. UNBELIEVIBLE ;D :o ;D Bye Pearl
  15. Last year, I ask for the possibility of mapping buttons by pressing another one at the same time like shift+Button or strg+button ...). I want to use it for the following issue: 8 select-buttons for the channels 1 button for mapping these 8 buttons to "mute"-function 1 button for ... "solo"-function 1 button for ... "rec"-function So, you push the "mute"-button and at the same time the select-button of that channel, you want to mute. [select1] [select2] [select3] ... [select8] [mute] [solo] [rec ] . . . . . . . . . Fader1 Fader2 Fader3 . . . Fader8 Another issue could be set/get locators: [Loc1] [Loc2] [Loc3] ... [Loc9] [set locator] If you push only the [Loc]-button you will get the position saved to these button and if you push [set-locator]+[Loc] you set these locator to the actual position. Hope, the problem is clear now. Is it possible to do that with the new mios (LC or Houston simulation) or do I we have to program a plugin or how can we handle this? Thanx for your great work :) TK Bye Pearl
  16. Hallo Leute ... also ich will am nächsten Sonntag (23.2.) eine Bestellung für Motorfader + Faderknöpfe bei Fa. Alps aufgeben. Preis lt. Angebot: RSAON11M9 10KB(linear)/100mm/T-Lever/mit touch sense Preis: EUR 24,75/St. netto (28,71 inkl. Mwst.) Faderknöpfe/soft/schwarz/gerippt/touchsensitiv Preis: EUR 1,73/St. netto (2,01 inkl. Mwst.) Versand-/Lieferkosten von Fa. Alps weiß ich noch nicht! Wer Bedarf hat einfach bei mir melden... Da die Dinger verflucht teuer sind werd ich wohl eine Anzahlung nehmen müssen (bin leider keine Bank ;-)) aber das hängt davon ab, wie groß die Bestellmenge jetz wirklich wird. Wenn es soweit ist, dann sag ich euch Bescheid. Ansonsten kommen für jeden nur seine Versandkosten dazu. Pearl
  17. Hi Marek ... Ich will in den nächsten 14 Tagen Motorfader bestellen bei Alps. siehe auch: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=german;action=display;num=1039798353 Ich poste noch mal bei Bestellannahme ;-) bis dann Pearl
  18. Pearl
    Motorfader Fragen?
    Ich muß aufgrund des Preises noch ein bischen sparen ;) (evtl. mach ich mein Projekt auch ohne MF) Wenn ich im nächsten Jahr bei Fa. Alps eine Bestellung aufgebe, dann poste ich vorher nochmal, ob irgendwer noch was braucht. Bye Pearl
  19. Pearl
    Motorfader Fragen?
  20. Pearl
    Motorfader Fragen?
    Hi Jack... Ich hab gerade mal eine Anfrage an Fa. Alps direkt gerichtet und bekam folgendes Angebot. Bye Pearl ---------------------------------------------------------- ALPS-Motorfader 32 x RSAON11M9 10KB(linear)/100mm/T-Lever/mit touch sense Preis: EUR 24,75/St. netto (28,71 inkl. Mwst.) 32 x Faderknöpfe/soft/schwarz/gerippt/touchsensitiv Preis: EUR 1,73/St. netto (2,01 inkl. Mwst.) ALPS-Drehencoder Den Typ EC16B363 gibt es nicht mehr - abgekündigt! Alternativ STEC16B03 24 Pulse/vertikal/ohne detent/flat shaft 6mm/L=25mm bei 52 Stück: EUR 2,75/St. netto (3,19 inkl. Mwst.) STEC16B01 24 Pulse/horizontal/ohne detent/flat shaft 6mm/L=25mm bei 52 Stück: EUR 2,75/St. netto (3,19 inkl. Mwst.) 60 x Drehknöpfe DK13-164/13mm Durchmesser/ohne Markierung/soft/schwarz Preis: EUR 1,55 netto (1,80 inkl. Mwst.) Mit freundlichem Gruß Balthasar Schmidt --------------------- albs-Alltronic Max-Eyth-Str. 1 D-75443 Ötisheim Tel +49(0)7041-9616-0 Fax +49(0)7041-961616 info@albs.de www.albs.de
  21. Pearl
    Motorfader Fragen?
  22. Ist es mit der aktuellen Firmware der Midibox (16E) möglich "Tastenkombinationen von Buttons" Midi-Events zuzuordnen. Ein oder mehrere Buttons sollen praktisch wie eine Shift-Taste funktionieren.
