Twin-X
Administrators
    1,081
Everything posted by Twin-X
  1. When i advance in my work i will add close ups (than you can see that i did not succeed 100%. I do not think there is a way to print white. So you have to spraycan your panel with good paint and then apply lazertran ;) Yes this is a 2U it fits (very tightly and i made an ubermistake! The lcd does not fit in the case cause of the print attached AAAARGGHHH but i am gonna be creative ;) This is a transparrent sheet attached to paper. You must print on it in reverse. (you can compare it to the stuff you get when building plastic hoby kits you know the decal. Those are the images you have to put in water and then slide of and attach to the plastic kit) go to www.lazertran.com and locate the nearest location. Find the email adres and mail your order i ordered a pack of a4 and a pack (4 sheets) of a3 for my 19" He will ask your creditcard and i got the pack after a week. I had 3 copies of the panel on 1 A3 for a try out i suceeded after the second one (meaning i have a spare one.) If it scrateches i will sandpaper the panel and paint the panel and reapply the sheet. So make your image and make a test print. This can be on more a4 papers if you have a large panel. Just cut it right. Look if the image fits the holes (in case it's predrilled like mine) When you are happy try to get as many copies on 1 sheet. Look for a laserprinter that prints below 200 degrees! Very important or else your paper will kill the printer since it will burn itself on the rolls! Usually expensive ones or printshops have these printers or photocopiers (select sheetpaper to decrease fuser temprature) Cut out the image and put it into cold water for 1 or 2 minutes. The deal is now loose from the paper. Make your panel wet. Slide the decal onto the panel gently. When you have placed it gently get all air bubles out with a sponge by rubbing it (this will clean the the decal aswell) When you are statisfied let it drie for 2 hours Then put it into a oven for 1 hour on lowest temprature. After that hour increase temprature every 10 minutes until you reach 200 degrees celcius. Stop th eprocess is the sheet looks very shiny. You must be gentle i can better take long instead of short. Let it cool off. Your done. Fill all small bubbles that still existed with paint or marker to make it a bit nicer. You are done. Do not expect powder coating but it is still firm and quite scratch proof. I will awnser more questions if you like.
  2. well its my first try and i quite succeeded. I don't think alot of people will like it tough. I got the holes done by schaeffer i send in my own panel. After that i applied some lazertran paper. To do this i printed the schaeffer panel with pdfwriter. Then i imported it in photoshop and applied the images and colors etc. I copied this on lazertranpaper (i am lucky to have access to a 100K color printer wich suits perfect for this paper) and then i put it in oven to get it burned on the panel. It looks quite nice but i could have done better. But hey not bad for a first try ;)
  3. to me (i am from holland) all prices compared to shops in holland are very cheap except lcd screens. Buy them from hallucinogen. Message him. He asks 7,5 euro a piece.
  4. Can i or can i not use it for a frontpanel?
  5. Thanks for the info. Regards, Jeffry
  6. I read this over and over and over :D Do i stuff all cores at once. Power the unit. Use the link cable of JDM to prepare the master and finish it all. After testing sid 1 i connect this cable to slaves 1 by 1? And repeat the procedure (according to the steps in the step by step guide) Sorry if i sound confusing p.s. the cores j10 only have 4 wires connected right?
  7. If i have completed my quad sid how can i or must i : A: update the mios or sid software? Do they go all at once? Or must i flash them seperatly (stuff unstuff). B: change midi chanel for each sid (or do i have only 1 midichannel?) trough control surface. Thx in advance
  8. Is the pin out the same as the 2*40 ones listed on the manufacturers website? The one you sold me is not listed. But i assume it's the same.
  9. Thanks Thorsten you deserve a beer ;D
  10. I got two 2*24 displays (rare maybe? 24) I got those out of intelligent tokenring switches (i believe those things costed new 5000 bucks hahaha.
  11. Really i tought you had to replace some resistors etc for the 8580. This is great so i can just swap them when i like.
  12. Hello i have a rather dumb question. My setup looks exactly like the drawing except the location of the power board. My power board is on the right side and i start feeding power from the right side. I have attached the cap to sid 1 instead of sid 4 due to the powering (from right to left instead of drawing) Is this wrong or does it not matter where it is attached?
  13. you're not the only one here ;)
  14. If this would work tha it's in my opinion the first one with this feature.
  15. we need prices and a company that sells them to non companies
  16. www.htvision.com 15€ voor een 20*2 Ik ga er een bestellen. Ik houd jullie op de hoogte
  17. weet iemand goedkope 2HE kasten evt zonder front paneel?
  18. ;D nice box it looks child proof to me ;)
  19. ;D nice box it looks child proof to me ;)
  20. i have copied almost everything from thorsten's layout. As for the lcd and it's encoder it's a 1 on 1 copy from his layout. But you are right it's ugly this way. But hey i am not finished yet ;)
  21. i have copied almost everything from thorsten's layout. As for the lcd and it's encoder it's a 1 on 1 copy from his layout. But you are right it's ugly this way. But hey i am not finished yet ;)
  22. Well erm since i find 3HE too roomy how about this design? Is it ok or is it too tight? Do not worry about how to attach the prints to the front. I have my idea's :D http://www.twin-x.com/troep/sidpanel.fpd
  23. Well erm since i find 3HE too roomy how about this design? Is it ok or is it too tight? Do not worry about how to attach the prints to the front. I have my idea's :D http://www.twin-x.com/troep/sidpanel.fpd
  24. Thaks for this info and i know what you mean with second glue as i am from the netherlands we call it probabbly the same. I dont think it's correct LMAO. Maybe it's instant stickyness :P
  25. Very nice. So how do you manage that the acryl button sticks to the board ?
