DriftZ
161 -
Everything posted by DriftZ
You mean PIC16F877 ? Mios does not run on that one, the apps for the 877 are still available, but you cannot modify them. It is much better to use the PIC18F452 for mios applications(PIC18F452), yes I think you should read up a bit on the ucapps site: http://www.ucapps.de/ In particular: http://www.ucapps.de/mios.html One core module, stuffed with a PIC18F452, can handle with: up to 128 digital inputs up to 128 digital outputs up to 64 analog inputs .... analog conversion of up to 64 pots, faders or other analog sources with a 10-bit resolution motor handling for up to 8 motorfaders with a 10-bit resolution handling of up to 64 detented/non-detented rotary encoders handling of up to 128 buttons, touchsensors or similar digital input devices handling of up to 128 LEDs, relays, Digital-Analog-Converters or similar output devices. In multiplex mode a nearly unlimited number of LEDs, LED rings and LED digits can be driven goodluck
In the pdf's you can find the default Din/Dout connections. However, they can be changed programmatically to fit your needs, look in the sourcecodes/mios reference for this. The whole idea behind Mios is to let ppl build stuff the way they want it. Mios allows you to have 64 pots per core module (using 2 AINX4), their function is customisable too, ofcourse. Encoders are similar to pots in terms of operation, the difference is that they are endless & use a digital signal. You can find default ledrings connections in the pdf's, but again, they are fully customisable.
quadsid: je hebt nodig: 4x sidboard 4x core (1 wordt de master waar de DIN's/DOUT's & LCD worden op aangesloten) enkele DIN's voor encoders & switches & DOUT's voor LED's, afhankelijk welke interface je wil bouwen (kan kiezen voor minimaal tot heel uitgebreid) success, DriftZ
I've got some more questions on this topic, 1) Does every slave-CORE send out this 1MHz clock or only the master ? IOW can each SID have the clock from its own CORE or does it have to come from only the master ? 2) On the slave PIC's, is it OK/better to connect all unused pins to gnd or can/must they be left unconnected ? tnx
I mentioned "newprice without components" as a reference to what a bare, naked pcb would cost. (I used the prices fromMikes shop for this) The things I'm selling have stuff on it (see pictures) best, DriftZ
yes I have, look at the page I set up (url in my signature) Best, DriftZ
It's more embarrasing to give wrong answers (like I sometimes do 8) ) DOUT module = DIGITAL out (output signals are either '+5V' or '0'; ONEs or ZEROs) AOUT module = ANALOG out (output signal is within a certain voltage range, like anything between 0V & xV) For an analog VU-meter, you require an analog signal(variable voltage signal, if you like) You can't connect multiple digital output signals together to get higher voltages to display. You'd need a DAC (Digital to Analog Convertor), but this is wat the AOUT is about actually. A DAC works somewhat like this: (each digit of the input represents one input pin; output is on 1 pin) input > output digital > analog 0000 > 0,0V 0001 > 0,1V 0010 > 0,2V 0011 > 0,3V 0100 > 0,4V etc... For a LED bargraph, you need DOUT module(s) While 1 DOUTX4 (4 SR's) has 32 (4x8 ) outputs, you can control more than 32 LEDs if you connect them in a 'matrix' (e.g. 16x16) just like the LEDrings example TK mentioned. Like this not all LEDs are lit simultaneously, but sequencially at a rate so fast that your eyes see them as continuously lit. Converting MIDI CC's to LED bargraphs is not too hard to do. MIOS takes care of all the MIDI handling etc. All you need to do is modify the code so with each incoming CC value the correct digital outputs are addressed, again see the LEDrings example.(look into the mios code, & mios reference files) Converting MIDI CC's to an analog VU is the same principle I guess, but then you need to address the AOUTs. But I never played with that. Maybe a bit too much explanation then required, but I hope you get the idea (& that it's correct what I said :) ) Goodluck, DriftZ
Moet je een hele C64 hebben (voor de behuizing) ? Of alleen SID chips ? & welke dan ? mos6581 of mos8580 ? mvg
ah, I did not understand what you meant with 'continuity'. Maybe the caps between Vs & Vd are responsible for that. My multimeter 'beeps' when i look for shortcuts, doesn't do that on my core between Vs & Vd, shows some numbers, but I got no idea wat they mean (i'm no electronics guru) -note: PIC not plugged in. but anyway, if you do connect power to it (before the rectifier) do you measure 5V between Vs & Vd ? I think if you have a shortcut, you won't have 5V. & If you have a steady 5V, I think it's all OK. goodluck.
? I think you should measure a steady 5 Volts between any Vs (ground) & any Vd (+5V) pins. Vs & Vd on those pins (J4,6,7,9) are the powersupply for the modules. best, DriftZ
Theoretically, yes. Mios provides you with digital (DOUTX) & analogue (AOUTX) outputs that you can use to control your (audio) circuitry. (You'll have to design/build that circuit yourself though) http://www.ucapps.de/midibox_lc.htmlThis application uses meters, not sure if this is what you have in mind. the reason is probably the price you can find a complete partslist for each module at http://www.ucapps.de/ Concerning the interface components (pots,encoders, buttons, leds....) it's up to you, depending on what you want to build. further, best advise I can give: read that site thoroughly If you wanna talk, there's a midibox chatroom (IRC) (see also my signature) best, DriftZ
Aren't you exceeding the max number of inputs ? (64 encoders (nr 0 to nr 63) require 128 digital inputs) http://www.ucapps.de/mios.html for more, I think you'll have to use more (linked) cores Goodluck, DriftZ
http://users.pandora.be/DriftZ/2ndH/g-dinx4.jpghttp://www.ucapps.de/mbhp_din.html
1. DINX1 (1SR) = 8inputs DINX3 = 24 inputs, so 20 buttons, yes. DINX4 = 32 inputs, you need 2 per encoder, so 16 encoders, yes. DOUTX1 = 8 outputs, so DOUTX2 for 16 leds, yes however, you could do this with DOUTX1 I think (4x4 matrix), will need some coding. 2. Which firmware do you intend to use ? (you will probably need to do some changes in the settings, for encoder type, max number of DINs, DOUTs, but this isn't really writing code) goodluck
Ey freaky, ik zag ook je posts op synthforum. In principe kun je elk lcd scherm gebruiken, maar omdat er maar enkele drivers voor enkele types beschikbaar zijn, zul je die waarschijnlijk zelf moeten schrijven voor je gsm scherm. Welk scherm het beste is voor mios hangt af van de applicatie, zoals je misschien al gezien hebt, gebruikt TK 2 40x2 schermen voor de seq & 1 20x2 voor de sid applicatie & 20x4 voor de midimon. hier kan je trouwens zien hoe de sid eruit ziet op verschillende displays: http://www.ucapps.de/midibox_sid_cs.html Als je meer vragen hebt, je weet me wel te vinden. mvg DriftZ (ook Belg & ook aan een paar midibox projectjes aan het werken) PS: beterschap :)
Drool... Drool.... Drool..... Drool...... Drowning... *help* awesome thing TK ! :D
Great, tnx for the answers  ;) oh btw If my explanation makes any sense: Does it matter whether you use 4 rows of 16 leds (=4 resistors) or 16 columns of 4 leds (=16 resistors) ?
Aah OK, understood, thanks :) But I got a few other questions or things that I would like to have confirmed before I start to build something impossible: I was thinking of doing a mios sequencer with 4x '16button&led-rows', 1 for each track. This would be well possible in the miosseq application, right ? Further, is there any code-space left for e.g. a 3x7segment BPM or PATTERN display ? best wishes, DriftZ
eeep! so my nondetented stec16's are not gonna work with the mios sequencer ? ???
Time to go study some RF stuff then ;) Seems more ppl like your idea: http://xmidi.com/bluetooth.html Also, M-audio (midiman) once has been busy with a bluetooth wireless midi-interface. http://namm.harmony-central.com/SNAMM01/Content/Midiman/PR/Bluetooth-MIDI.html I don't think they ever put it into production (why not ??) best, Driftz
something like this ? http://www.kentonuk.com/products/midistream.shtml
I don't think you can connect switches to AIN modules. 1 DINX4 lets you connect 32 switches.
Yes you can, on the switchbody fit all different kinds of caps, if you choose for a transparent cap, you can fit in a 3mm LED of your choice (color/brightness), the switchbody has openings where the legs of the LED go through. You solder the legs of the LEDs on the PCB. The switch itself connects to the DIN(X4) module, the LED connects to the DOUT(X4) module. hope that explains, best, DriftZ
