moxi
Frequent Writer
    993
Everything posted by moxi
  1. now, with the underscores before asm and endasm: ??
  2. oups! it's me that forgot it!
  3. thanks i've solved this first errors. now i get this one: here is a quote of the 4 last line of my file:
  4. i've tried to integrate the code you give me, now i just get this two errors: what is wrong?
  5. thanks, i will spend the night on this :P
  6. i've re-do all the work from scratch, and the only error i get now are: any suggestion?
  7. ok, it's a good hint, now i've to find a powerfull pump...
  8. hi, could someone explain me why when compiling my app i get this error in many file: "processor type not defined"
  9. i never try to warm the resin, but more hot is the ambiant temperature more quickly act the activator, and in the normal case, you just have about 30mn until the resin go solid, it's not enough to make the pressure cooker getting enough hot... after some search, it's appear that plastic modell builder use a plastic bag instead of a box...that could be cheaper by this way...i will try in the upcoming month to build such a tool...
  10. i've used "code::block" to compile and now i can see the errors. i will take the time to learn more about c to understand now what they mean..
  11. now, i've solved a lot of error, but there is still some, here is a way to get a file that report of the error, like in mplab?
  12. moxi
    sid + Aout-LC
    thanks...my translation was probably not enough clear!!! :P
  13. it's seem that some define are missing...i understand strickly nothing to C... where i have to put the needed define? in which file? or here is a way to convert back to assembler the C files? i think i will ghet more chance to success by this way...
  14. it's the compilation that don't work, it stop before the end, there is an error message but the script windows is closed before i can read anything....:(
  15. hi, i've tried to integrated the asm code from the file Aout_lc of the midiboxCV app into the analog tool box app, then run the "make bat" script. after that, i've uploaded the application, the cv react right at incoming midi event but when nothing is send to the box, the voltages at my cv out goes up and down in a range of ca. 1v where i've done something wrong, it's the first time i try to compile C app, have i missed something, or change have to be done in other files of the C app?
  16. yes, i know this hint, but for that you have to buil a really-really hermetic box, it's not as easy as it seems to be...
  17. moxi
    sid + Aout-LC
    more test: it's appear that the cutoff modulate my CVs 1 and 3, and the rezo modulate CVs 2 and four! ???
  18. moxi
    sid + Aout-LC
    ok, after some test, i've seen that my first cv drive the cutoff and the second drive the rezo, it's perfect.. but now , are the second aout-lc supported by the apps? if yes , wich parameter are routed to the cv? what i want :to get the lfo to modulate my third cv , and the env to modulate my fourth cv...
  19. moxi
    sid + Aout-LC
    hi, i've read that for the first implementation of the driver for aout-lc module in the sid app, only the resonance can be outputed to aout, i'm right? does that mean that only one aout-LC module is supported by this app?
  20. yes , that's work now... thanks..
  21. :D solved, iv'e just forgot to link to the -12V my second aout-lc!! sorry for this obvious topic!
  22. hi, i've build my first Aout-LC module and it works perfectly, but i've build a second one and there is no way to get voltage below 6.5V on any of the cv out :( any suggestion?
  23. to get the shunt, simply ask MAXIM for a free sample...
  24. it's the product called "durcal" that make the resin louder, so the bubble goes awaymore easy, secondly i take care when i do the "mix" to go as slowmler as i can. before inserting the activator , i let the mix about 30 minutes so the bubbles have the times to go away. if you want a resin "pure" whitout any bubble, you have to use a machine called in french "pompe à vide", a tool that put the resin under a high presure until the bubble get out of them, but such a machine is expensive (about 300 Euros!) you can use your washing machine in "dry" mode to tremble the mix a bit more, it's the way i use for the while....
  25. hi, the bench of the day: the caps now are blue when not lighted, and still orange when the led is on... in fact , i think i can do any color... my next box will look funky ;)
