MTE
Frequent Writer-
1,187 -
Everything posted by MTE
I love this song, great work !
wrong, thats called doggystyle :D
Traktorizer - a Midibox to control Traktor-DJ-Studio -
MTE replied to MTE's topic in MIDIbox User Projects
?? Use my Firmware ?? The LCD-Function is completely removed but if you need all infos look here -> http://ucapps.de/mbhp_lcd.html scroll down to -> PCD8544 based graphical LCD Regards MTE -
A copy of Traktorizer - Traktor DJ controller .
MTE replied to DarKM4N's topic in MIDIbox User Projects
The LCD-Function was just a try for a gimmick, but the programming was too hard for me....Im not a programming genius :drool: Best Regards -
Hi here a quote from my homepage (latest Page updates) -> http://mte.bplaced.net/LatestPageUpdates.htm # 24.07.2008 Traktorizer goes to Version V4.01(Beta)...LCD-Function completely removed... Regards and sorry for the long delay MTE -
Hi quote from my homepage... sorry, no time and no money for forthcoming development :( Regards MTE -
Hi you get this function wrong, its a "box-internal"-function of the jogwheels who scale the waiting-time between the control change and note off ;) Description of Jogwheel (Scratchmode) : When you start turning the Jog for Scratch, Traktorizer will send at 1st a Note-On. While you turning the Jog it will send permanently Control Change and when you stop turning it sends a Note-Off. Regards MTE -
Hi sorry, do you mean an "traktorfile"-> .tks ?? so, no theres no file available, you need to program Traktor by yourself. regards MTE -
Im alive :D -
The LC must be connected with the host (cubase/nuendo/logic...) to work ;) The LM317 drops the voltage down when all faders moving because of the current (max.1.5 A)... get a big heatsink for the LM or build separate adjustable power supplys for each fader ;)
Hi Wir löten im Geschäft ausschließlich mit 400 Grad und haben zum Teil Lötstellen mit 0,2mm Abstand, manchmal auch kleiner, siehe SMD-Widerstandsnetzwerke, meine Lieblinge :D Dafür nehme ich immer eine Lötspitze mit schätze mal 0,4mm Das meiste hat Amiga schon schön beschrieben, bei Chips immer zuerst die diagonalen Ecken, ein guter Tipp dazu : Immer ein Lötpad für das jeweile Bauteil minimal vorzinnen, dann den Chip oder Widerstand/Kondensator/Whatever mit einer Pinzette ranhalten....heizen....Sitzt ! Danach kann eigenlich meist nix mehr verrutschen und man kann nacheinander alle Pins Ruckzuck verlöten. Lasst euch von den 400 Grad nicht erschrecken, ich habe es auch schon mit weniger Temperatur gemacht, aber 400 Grad scheint mir um effizient und zügig arbeiten zu können am besten, und wir hatten bisher noch keinen Ausfall eines Bauteils das auch mal mehr wie 3 Sekunden unter dieser Temperatur geheizt wurde. Grüße
Danke mal für die Tipps, die Ingenieure in der Firma in der ich arbeite (alles digitale Oberfreaks) meinten auch einfach ausprobieren....zum Test nehm ich die Karten einfach mal mit ins Geschäft und sehe was das Oszi dann ausspuckt....bin mal sehr gespannt.Aber falls das klappen sollte wäre das ne super Lösung für ne RME-Breakoutbox :) Leider ist das nicht das Hauptproblem meines Vorhabens, schliesslich muss ich alle anderen Leitungen vom Rechner verlängern...und dazu gehören 4 DVI-D Kabels mit dazu....ne Suche nach ner anständigen und erschwinglichen KVM-Lösung hat bisher nix ergeben.
Mein Geldscheisser hat leider zur Zeit Verstopfung :D
Guten Morgen, ich habe ne Frage an alle digitalen Freaks :) Da ich derzeit meinen Regieraum umbaue möchte ich nun meinen Rechner komplett daraus verbannen und (vermutlich) in den Keller legen. Meine Rennsemmel beherbergt die RME-Hammerfall9652 und das AEB-8/O analog Expansionsboard, die AEB-8/I bestelle ich nexte Woche :) Beide Karten werden ja quasi intern (also im Rechner) an die Masterkarte angeschlossen siehe Attachment : digitales Signal (grün markiert) +12V und GND (rot markiert)) ...ich spiele nun mit dem Gedanken, diese Karten in ein Externes Gehäuse zu packen und anstatt den 8 Ein- und Ausgangskabels die internen Verbundkabel zu verlängern (10m oder mehr...) und vorallem das Ganze in 1 Kabel zu packen. Könnte das mit dieser Länge Probleme geben ? Möglichst dicke Kabel verwenden ?
That is a great idea! Im in :) :) It will be photographed and documented when its finished.Im very busy in study/experimenting room treatment in the last weeks, but I need more to learn (perfect calibrating for measuring-mic etcetc)...its very hard for me math-noob :) ATM I have the feeling my control-room looses gain, but panorama, clearness etc sounds awesome....but lets discuss this in a new topic :) Edit : oops, btw my monitors are Syrincs M3-220
...weil ich bis dato keine hatte :-[
Only Quad rulez :P ...mann was für ne Arbeit mit dem Gehäuse, ich erinner mich ganz stark an die Stunden meiner LC mit Feile & Schleifpapier an den Faderschlitzen...nie wieder :)
Haha nice :) this reminds me on very old industrial/noise-livegigs ive seen in the 90s....freaky :D
Unter Steuergeräte müsste das Mackie Control Universal zu finden sein, genau das, was die LC quasi emuliert ;)
Nice idea, Ill check that :) >:( grrr :) no problem, I wanted to "Buyitnow" Ive seen in his feedbacks that he saled a same bunch before for 75$, maybe he have more of this faders.When I figured out the touch-sensors Ill contact him.
:( Thank you for this info, its really bad cause of this nice price....whatever....so letz wait of the reincarnation of Doug :)
Hmm this is a very cheap auction, Im thinking about to buy them but after studying the manual of this Tascam-machine I didnt found anything if the faders are touch sensitive :( Has anyone experiences with this mixer ? Regards
