tokyomatik
82 -
Everything posted by tokyomatik
....so? nobody knows a solution? i also have a new problem, suddenly my lcd doesn't show anything, but seems that the problem is about the cable or something like that, and another one is that the core doesn't want to communicate with sid, i tryed to reinstall everything from the beginning (even if i can't send the right sid application with the right setting for my 2x16 lcd!) and from mios i noticed that the core sends a midimessage that is the following note off c-1 velocity=00 note off c-1 velocity=00 note off c-1 velocity=00 note off c9 velocity=120 ..................timing clock ..................timing clock i know that i'm adisaster with this project, but : what is going on? is my sid dying?
ok, i got it the error message says error 151(cs file name) unresolvable label or too complex i did like this: i opened mplab i created a new project i copied all the files inside the directory sid 1.7-303b, dragging them on the project window i saved the project in a directory named "303" really close to the root directory (C:/303:/) i customized the asm files and then i pressed F10 should b ok but i always get that error 151!!
well, i don't have mplab on this computer now but if i'm not wrong, should be something that finish like"... the path is too complex..." in the while i tryed to move the folder of sid 1.7 303b inside the directory of my disc C and i got the error anyway(?) what's wrong?
i tryed to customize a bit the main asm because i have an 2x16 display using mplab, but when i press f10 i get this error151 i remember that time ago i solved the problem moving the directory somewhere.. after 10 months i forgot everything...i'm so fried... can somebody give me a tip? thanx
basicly, instead to connect the jack in the output, i used the input (as a mistake and not on purpose)and with a lot of surprise there was a sound just a little lower, respect to the output. i don't go to the sid with an amplifier, but from the line in of a mixer and i listen to it with headphones.... for months everything was ok, i also tryied to use the input to process external sounds and was almost nice. then suddenly i got sound from the input and i also noticed that after a while that the sid is playing there's a bit of pitch changing...
hi to everybody! i don't know why, but i have sounds from my sid input i mean, playing with my keyboard, from the output & from the input comes the same sound.... what's wrong with my sid???
i need one too how much??
ok, so just to be official with matze: SORRY for my lack of reliance peace
i already write to him2 days ago and no answer....so i was a bit afraid italy is famous for the slow post office system but he received my stuff in few days so... i will wait
there is anybody here that knows if i can trust acidcode? i was supposed to receive a sid chip from him, but after 2 weeks....nothbing!!!??
i have a "little" doubt about the digital out connection especially the modulation matrix ports i tested the connection with a led and it lits only with the short leg on the left side i mean short leg in j5-d0 and long leg j6-d1 is it normal? with the other ports the anodes cathodes are in the right position there is anybody here able to explain this?
remember that is possible to fill the engraving with ink or your fav colours even fluo or fosforeshent
they need: dwg or illustrator or freehand to pay less we have to place at least 10 pieces so for now we have 3... we need 7 more when we are ready, it takes just 2 days to have the panells i'll wait for the other orders in the while this is the company: http://www.laserservices.com/flash.html
with that price they offer the material that you wanna use,(for polycarbonate many colours are available) they make all the holes that you need and letters engraved, that is much better than silkscreen i mean is just like the frontpanell on ucapps.de but you can make your own design, or if you prefer i can do it for you(i'm a graphic designer) lcd size.... let me know
i'll try thanx
i have a problem creating the file when i try to make i get this message: Make: The target "C:\Documents and Settings\Matteo1\Desktop\mios\midibox_sid_v1_7a\main.o" is out of date. Executing: "C:\Programmi\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F452 "main.asm" /l"main.lst" /e"main.err" Error[173] C:\DOCUMENTS AND SETTINGS\MATTEO1\DESKTOP\MIOS\MIDIBOX_SID_V1_7A\MAIN.ASM 638 : Source file path exceeds 62 characters (C:\DOCUMENTS AND SETTINGS\MATTEO1\DESKTOP\MIOS\MIDIBOX_SID_V1_7A\MAIN.ASM) Error[173] C:\DOCUMENTS AND SETTINGS\MATTEO1\DESKTOP\MIOS\MIDIBOX_SID_V1_7A\MAIN.ASM 638 : Source file path exceeds 62 characters (C:\DOCUMENTS AND SETTIN what it means?
well, actually i'm trying to understand how can i change the configuration for my display ??? i have a couple of lcd, one is a 2x16, the other is 2x40 i know that i should write somewhere to didplay 4 elements for the first and 10 for the second but... i mean, i don't understand wich file i'm supposed to download, the source code i have too many main.asm on my desktop and i'm going crazy can somebody try to explain how it works? i have to change the mios configuration? from my mbsid? from a particular file on my desktop? and when the file is ready i just have to upload it by midi? i feel so stupid and tired at the same time try to think at me like a baby that needs to learn(and i'm learning...)
hey guys, i found a place here in italy that could cut some nice frotpanells for a really good price but to spend less, the minimum order is at least 10 pieces they can do lasercuts on variuos materials like polycarbonate, alluminium, wood.. for 1 they asked me almost 150 euros but for at least 10 (no matter if they are differents) the price goes down to 40/50% less so if somebody is interested... just let me know
ye well i have 4 bigger pads for the drum sounds and 4 smaller pads for "special effects" how can i add the midifeatures?
there's anybody here that knows if is possible to midify this old toy drum from yamaha? cheers
i would love to add a couple 8580 to my configuration there's anybody here that want to sell a couple of these sid chips?
[SOLD]wanted: SID chip - will trade it for a c64 psu..
tokyomatik replied to Wisefire's topic in Fleamarket
hey ! i also have an extra c64psu, and i'm looking for an 8580 sid chip so if somebody is interested to this trade... tokyomatik@libero.it let me know -
do you mean the 10 microfarad electrolithic cap? maybe the one that i soldered is not working.... i also noticed that if you touch the ground of the audio output for a while, suddenly the audio signal disappear and to have it back i have to switch off the sid if the problem can be solved changing that cap, i'll do it let me know thanx
ok guys, finally my sid is making some noise and i like it, but after the interconnection test i tried to check also the output with the oscilloscope just to see waveform and i noticed that there is a small tension of 1v coming out of it....is it a problem?
