URBatORB
27 -
Everything posted by URBatORB
Only 1,62 V at the 5 V output of the improved PSU
URBatORB replied to URBatORB's topic in MIDIbox SID
Hello, Hello, second measuring directly at the C64 PSU: At the 5 V DC = 8,9 V At the 9 V AC = 10,2 V At the 5 V improved PSU 2,3 V At the 14 V improved PSU 17,6 V I think I found the failure. It is a short circuit / loose connection between 5 V + and - at the original DIN Connector from the C64. The circuit indicator peeps sometimes if i connect it between the + and the - PIN-connection (the C64 PSU is not connectet during the test). Or is it due to the unloading of the capacitor(s)? Nevetheless, the C64 PSU is damaged :'( -
Hello, that's very curious. When I test the voltage directly at the C64 psu plug, I get 10 V. I had the 5 V before I connected the improved PSU to the Core Module. But I can't find an error at the Core Module (as recommended the 7805 is not stuffed and I have shortened the input/output line at the board and connected the psu to the J2). Mhmmm, I'll test the Core Module again later. I'll stuff the 7805 and test the Core Module with a cheaper wallwart, maybe there is still an error. But another question, can I destroy the C64 Plug by an error at the Core Module? -
	Hello, I get only 1,62 V at the 5 V output of the improved 4xSID PSU. If I measuren the 14 V output I get 14,19 V - that seems to be OK. But what is wrong with the 5 V output? Can anybody help? /Daniel
	Yes stryd_one, agreed, crashes are a risk with every software. But I never had one with Live at a session. Just keep your System clean from any unneeded software, disable wireless lan, bluetooth and so on and of course use premium hardware. Then everything will be fine. ;) For the beginning without any outboard a software will be alright. But consider, that you possibly need some additional (VST-)softsynths (Reason for example is full equipped and you can't expand it with 3rd Party Products). Live has only the Simpler and the Impulse. But it's expandable with al lot of 3rd Party Plugs. /Daniel
	Hello, Cubase and Logic are more for Recording purposes. Both programms are like a virtual multitrackrecorder - and therfore not really good for live purposes. I worked for Years with Cubase until I got Ableton Live. Ableton Live is good for recording, remixing and of course for live performances + DJ Sets. Ableton Live is very intuitive and flexible, like a mixture of a multitrackrecorder and a MPC (Did you ever worked with a Akai MPC???) with a lot of integrated effects. There is too much to say. Get the the demo from www.ableton.com, watch the videos which are showing Live's functions and trust me you'll be amazed.
	Die Shop-Cookies sind bei SLP auf der Platte, daher die Fehlermeldung. Conrad hat neuerdings eine TÜV garantierte Preisstabilität. Hehe, das wundert mich nicht wirklich.... ;D Reichelt hat seit kurzem ALPS Fader. Guckst Du hier: High End 100 mm ALPS http://www.reichelt.de/?SID=26X3sXxKwQARoAACpD7g8aef55fac2ebe136a1a3f0185a79ea058;ACTION=3;LA=2;GROUP=B28;GROUPID=3713;ARTICLE=73879;START=16;SORT=artnr;OFFSET=16 Preis/Leistung 100 mm ALPS (Stereo) http://www.reichelt.de/?SID=26X3sXxKwQARoAACpD7g8aef55fac2ebe136a1a3f0185a79ea058;ACTION=3;LA=2;GROUP=B28;GROUPID=3713;ARTICLE=73873;START=16;SORT=artnr;OFFSET=16
Difference between rectifier B40C800 and B40C1000
URBatORB replied to URBatORB's topic in Parts Questions
OK, I wasn't 100% sure. ;D Thanks -
Thanks for the fast reply. I ordered a B40C800 and got a B40C1000. Now I think the B40C800 were simply out of stock. I have a square DIP Version. I looks like that one: ~ IIII - ~ IIII + Do you know were I have to connect the 9V AC and the conduction from the Powerswitch? I can't find information according to that rectifier version. Daniel -
	Hello, what's the difference between rectifier B40C800 and B40C1000. Or better for understanding; what does the indentification say? B = ? 40 = 40 volts C = ? 1000 or 800 ? Can I use a B40C1000 instead a B40C800 for the improved SID PSU? Thanks, Daniel
Lets go shopping :) ... your input wanted
URBatORB replied to thestruggler's topic in Parts Questions
Hello, I'm very satisfied with the Alpha Pots. I have these: http://www.banzaieffects.com/Alpha-16mm-split-shaft-10k-lin-pr-17257.html I think my pots are nearly the same as yours, but with a shorter metal-split-shaft /Daniel -
	Ja, danke für die Info - ich hatte die ganze Zeit schon den Eindruck etwas übersehen bzw. überlesen zu haben. dh. 'nen "Single-Sid-Synth" könnte ich mit dem PIC18F4260 machen, zum späteren Kaskadieren benötige ich jedoch den PIC18F4685, den ich, weil das Board kompatibel, ist einfach austauschen kann. Die Slavemodule kann ich dann kaskadieren indem ich die ID der Slave-Pics entspechend ändere. So nun hab ichs wohl auch kapiert. Danke ;), Daniel
	Hallo, so, da bin ich wieder, nach dem chronischen Freizeitmangel der letzten Monate möchte ich endlich noch das Frontpanel meiner Midibox64 fertigstellen und parallel den Sid-Synth beginnen. Nun habe ich mal so ein paar "Feststellungen" unten aufgelistet (die mir der ein oder andere hoffentlich bestätigt) um sicher zu gehen, dass ich hier keinen Fehler mache: -> SID Synth V2 benötigt den PIC18F4620 -> Auf dem PIC18F4620 läuft auch V1.7 mit dem angepasstem MIOS und Bootloader -> Für eine Kaskadierung von 2 Sids (oder mehr) benötige ich zusätzlich zum Core Module noch das MBHP_IIC_MIDI -> Die aktuellen Core-Platinen sowie SID-Platinen können für die V2 verwendet werden. -> Bis auf die Änderungen des CC- (neu Page up), Edit- (neu Page down), Link- (neu Shift) Buttons ändert sich nichts am Panel von TK -> Auf der Wishlist steht noch was von von der Verwendung des PIC18F4685 (wegen des ECAN Interfaces) - den kann ich doch später bei Bedarf austauschen?? ggf. das ges- amte Modul??? Grüßle, Daniel
	Hello guys, Im finally back again. I had to do a lot the last few month in my company (part project leader in introducing a new business software for the investment management....) since I began my Midibox 64 project. So the spare time wasn't enough for all my hobbies. The panel is still in development (the very beta is at the gallery) but the parts for my next project, the SID Synth, are ordered ;D. In my opinion the first post should be a link to my myspace account where you can listen to my latest tracks. Enjoy it - an feel free to post your (honest) comments. http://www.myspace.com/urbiwan Regards
	The Joysticks from my Thrustmaster Joypad are working with my Midibox too. From one I had removed the spring - it still works fine. :D /Daniel
	... so das Problem mit den doppelten IDs bei den Tastern wäre gelöst. Nach näherer Betrachtung (und ausgedrucktem Schaltplan!!!) fiel mir auf, dass ich die Taster an J6 von D1 bis Vs angeschlossen hatte anstelle von D0 bis D3 (peinlich). Tja, manchmal muss man(n) einfach nochmal darüber schlafen. ;)
	... "the photon controller". Only for the really cool people with sun glasses 8) on stage at night. ;D
	Hallo Thorsten, danke. Ich muss mal schauen wie ich das mit den LED's realiseren kann. Das höchste der Gefühle in Sachen Programmierung war Visual Basic in meiner Schulzeit (ist aber schon laaange her) - wenn sich jemand der Sache gewachsen fühlt, nur zu, schreibt mich an. Ich könnte wetten, dass es noch andere Ableton-Midiboxler gibt, die dieses Feature begrüßen würden. Für reine Mute-Zwecke in Mixer Applikationen könnte man das sicherlich auch verwenden. Dann habe ich die beiden Module also richtig angeschlossen. Ich werde heute abend mal die DIN Platine auf auf Kurzschlüsse usw. hin durchpiepen (habe sie gestern nur mal optisch überprüft - war auch schon spät). Wäre doch gelacht, wenn ich das Problem nicht finde, nachdem alles auf Anhieb geklappt hat. Grüßle, Daniel
	Hello, that ist maybe the best solution. I asked only because I had soldered the the standard DOUT resistors today. Certainly can I solder your additional proposed restistors in serial or not? Thanks!
	Hallole, kann mir jemand Tipps geben wie Ich die Taster/LEDs konfigurieren muss? Folgende Situation: 8 Spuren mit jeweils 2 Tastern, jeder Taster hat eine eigene LED Die erste Tasterreihe ist für das Starten der Clips in Ableton Live verantwortlich. Bei Betätigung sollte die LED leuchten und mir signalisieren, dass die Spur läuft. Die zweite Tasterreihe ist für das Stoppen der Clips verantwortlich. Bei Betätigung sollte die zugehörige LED leuchten und mir signalisieren, dass die Spur gestoppt wurde. Die LED der ersten Tasterreihe, die für das Starten der Clips verantwortlich ist, soll logischerweise erlöschen. Mir scheint so, dass Programmierarbeit auf mich zukommt *zitter* - ich habe doch keine Ahnung. Noch eine Sache zum Core Modul ist J9 oben und J8 unten (Eagle File)? Mehrere Taster haben in der Midiboxsoftware die gleiche ID - ich habe so den Eindruck, dass ich DOUT (obere Stiftleiste) und DIN (untere Stiftleiste) vertauscht angeschlossen habe. Nach dem ersten Test viel mir das nicht auf, doch nun habe ich 16 Taster angeschlossen und beispielsweise haben die Taster für Kanal 3&4 die gleiche ID in Mios (also in diesem Fall Button #4). Grüßle, Daniel
	Hello, I have some blue LEDs with 2500 mcd lying around - they are a "little" bit too bright 8) for controller appliances. Did anybody use blue LEDs, and how many mcd did they have? I need them for my Ableton Live Controller (night and day use). thx/Daniel
	Nice Tune, that's what I want. Check "www.munich-radio.de" out. My preferred soldering radio! ;) / Daniel
	Hi, das mit dem umfunktionierten Steckernetzteil scheint mir auch die beste Lösung zu sein. Bausätze kosten so um die 20,- €. Ist mir etwas zu teuer. Für das Geld besorge ich mir lieber schöne Knöpfe! ;D " :P " ! ;)
	Hallo Lötbrüder und -schwestern ;), kann mir jemand einen Tipp und/oder Erfahrungen für ein Einbaunetzteil (technische Daten wie das empfohlene Reichelt-Steckernetzteil für die Midibox 64 also 9 V 500 mA) geben. Ich dachte an einen prof. Bausatz (wäre mir die liebste Lösung) oder an ein auf einer Lochrasterplatine selbst gebautes NT. Was muss ich bezüglich der Abschirmung beachten? Besten Dank mal im Voraus! /Daniel
	Guten Morgen Thorsten, alles klar, danke für die schnelle Antwort. Sobald ich den Widerstand habe, werde ich ihn anstelle des Transistors einlöten. ;D
	Hallo Thorsten, Du bringst Licht ins Dunkel (Im wahrsten Sinne des Wortes) - einen passenden Widerstand habe ich immo leider nicht zuhause (nur noch mOhm und kOhm). Dh. also ich löte den Transistor raus und den Widerstand ein? In welche beiden der 3 frei gewordenen Löcher darf ich dann den Widerstand einlöten 3&2 ? (Nummerierung gemäß Eagle File)?. Oder ist es nicht einfacher direkt an den Minus Pol den Widerstand zu löten und direkt an den Spannungswandler zu gehen (dann kann ich halt die Helligkeit nicht mehr regeln, müsste ich mal ausprobieren)? Ich bin auch ein absoluter Newbie. Grüßle und danke mal soweit! Daniel PS: Habe eben den ersten Test mit 4 Tastern und 8 Fadern gestartet (23.45) - alles geht und ich freue mich wie ein kleines Kind. Danke für dieses absolut geniale DIY Projekt!
