Hello
Trying to figure out how to make a simple adapter for the 2 LCD:s that's needed for the LC, since the pinout is completely different, did anyone make a adapter card for it or what?
I'm thinking of making a perfboard with a ribbon cable in and do as in the tutorial document and 2 ribbon cables out with the correct pinout.
Does anyone have a simpler solution?
Check and double check resistors, near DIN, AIN port, sounds like "floating pins" i.e. they don't know if they are a 1 or a 0 and a hand over the pic will be enough to make it crazy.. so make sure you have them, they are not optional!
Yeah, the AC adapter solution seems to be working. And as far as i've read the crystal wont work. And my question was if someone had made a SMD tl074 PCB allready or have the brd file so it's possible to change package.
I've started to build a FM module, but i got smd tl074 and a "standard 2 pin" 14.318Mhz crystal. Have anyone made a circuitboard for thoose components? And is it possible to use wall-wharts instead to make the +-12v (or prefferably lower).
Just a question about the scratch pads, yuo wrote that it was 8cds ona hdd motor with a strap to an encoder. Is it a standard non indented rotary encoder or what? would love to see more info on that part if possible.
I bought a few extra 74HC165, 74HC595 and 4051. 74HC595 8kr (SEK) 74HC165 7,50kr (SEK) 4051 5kr (SEK) If anyone is intrested (preferably close to sweden) i'll converti it to other currencies. +shipping
Det ska inte vara några problem, får jag bara det i ett vadderat kuvert med returporto. Antar att du menar 18f452. Skicka ett pm om du är intresserad. Programmerar alla kretsar som finns på: http://www.robh.nl/picsoft.php#xwisp2 Är alldeles ny med midibox, har kikat in här några gånge men är på vär att bygga mig en sequenser :)
