226 -
2
Everything posted by Narwhal
Cocoa/Objective C MIDI/Serial Communication
Narwhal replied to wackazong's topic in MIDIbox Tools & MIOS Studio
From the error message I was quite dumb. I just needed to copy the framework into my ~/Library/Frameworks directory. I have it running, but here is the gotcha. I have two versions of this program. The first version I named "XT Patch Grabber 2007", catchy name I know. This one works and grabs patches and puts the names into the columns of a table view. But.. its code is super super horrible, and some of the interface items are broken. It's really the first time I ever started to play with cocoa, so the code is all in one file, and may be exceedingly hard to follow. The second version I named "XT Patch Grabber 2008". This one has been built from the ground up to have a clean code organization, with view controllers and data controllers and the whole works. I think it's a darn good example of how I'd like build a cocoa app and interface. But this version of the program seems to be more of a work in progress, in that it doesn't yet actually do anything (that I can tell yet). It does however have most of the code to actually do the same things as the 2007 version. I just need to hook up the buttons, and fix the things that the new XCode complains about. I have all of next week off for vacation and this is a prime example of the kind of things I want to work on during that time. If you can wait until early next week, I'll share what I can get going because I don't think anyone should learn how to do this by looking at the 2007 version. Kurt -
I just wanted to let you know that I'm working on getting this ready, but the last time I looked at this code I had a PPC Mac and the previous version of XCode, so it's going a little rocky at the moment. I'm having to update the PYMIDI framework so it will contain PPC and Intel code. Pete has posted his framework in a less than useable format right now. I have it building successfully but it's failing to load the framework library for some reason. If anyone knows anything about cocoa frameworks, this is the error I'm getting: dyld: Library not loaded: /Users/kurtarnlund/Library/Frameworks/PYMIDI_2008.framework/Versions/A/PYMIDI_2008 Referenced from: /Users/kurtarnlund/Documents/Software Projects/My Midi Apps/XT Patch Grabber.2008/build/Debug/XT Patch Grabber.2008.app/Contents/MacOS/XT Patch Grabber.2008 Reason: image not found Kurt -
Ok I'll gather it up when I get home. The application finds a connected Waldorf XT then requests all the patches from it so that it can extract the patch names, and hopefully someday it'll write them out to a file in the format that logic uses so that my logic environment objects can have all the real current patch names. I've always wanted to take this application way further, but it rarely comes up very high on my list of things to do :-) It current does succeed at receiving all of the patches and remember it's window settings. -
Also I'd be happy to share the last application I was working on that used PYMIDI, but I can't guarantee that it's the best cocoa programming the world since I'm still learning its quirks. -
Yeah I have some code for this at home that works very nicely. Actually its a framework that you link into your code and it simplifies communications to, and management of, the midi endpoints. Check out Pete Yandell's PYMIDI framework. -
hehehe.. thanks for checking it out. On Friday, when I found out that this was actually playing in theaters, it really made my day. Stryd: I call that sound the whistle, because it sound like whistling at a girl. Once I hit on the guitar whistle idea I pretty much built the rest of the song around doing that at just the right time and then trying to get a tempo that would match with most of the transitions.
About 10 Years ago I wrote a piece of music for a friends animated short movie. At the time she had tried to sell it to Spike & Mikes Sick and Twisted Animation Festival, but I never had heard whether it made it into the festival, or if anything ever came from it. The other day I found out that the video has been shown in the film festival as early as last year and I thought some of you might like to check it out. WARNING: the movie is graphic and may be inappropriate for some viewers :-) But it's totally fitting for Sick and Twisted Animation Festival. I can't post a link directly to the video, but it's simple to get to. 1. CLICK HERE 2. Click on the CLASSIC Film Channel 3. Click on the Origami film by Jennifer Austin Enjoy, Kurt
You might want to post more details showing your function and how you are calling it. It'll help people correct your specific error. But that said, I think I can provide some help here. I can think of very very few cases with structures where you would ever want to pass them by value. The main reason you'd want to pass a struct by value would be if you wanted to modify the values without modifying the original structure values, but there are better ways to accomplish this even when you'd passes a pointer to the struct. Whenever you make a function call, the compiler must create assembly code which pushes your function parameters on a stack, then the function being called must pop them off of a stack. The more parameters, the more data-pushing-and-popping code needs to be create, and the more stack is consumed. When taken to extremes, this can equal a slow and inefficient app. When you pass a pointer to a structure, it is often smaller than the structure, because structures often contain multiple items. I believe on the PIC's used here that pointers are 3 bytes? Anyway, it boils down that passing pointers to structure is most likely the best way to pass a struct and will result in more efficient code. So, your function should be defined like this: void SetColor(led_color_t * p_color); This is not a multiplication :-) The * is letting the compiler know that the variable is a pointer. then you can access the elements of the struct using: p_color->COLOR[x] or.. p_color->RED p_color->GREEN p_color->BLUE
100% wait til it's completed. There are going to be some pictures and video that go way beyond what this module is doing, and you all are going to want to see them. ;D
I'll definitely be getting to my clean up mode and moving to the new structure. It just wasn't at the top of my list because I'm trying to learn everything very very quickly. I'm definite in cowboy development mode.. sorry about that, I just think that it has to be with the amount of time I have. Really it boiled down to me pushing forward too fast and missing the facts that I should have updated, and I should have set the define for the actual processor type rather than assuming it was the same as the 18f452. When I release this, it'll be all cleaned up, playing by the rules, and able to be use usable by multiple chip types. I promise. ;D Kurt
Problem solved. Stryd had me remove the j5_io init call and I initialized the tristates and the adcon1 myself in the first lines of Init() in my main.c. And it worked! I'm so excited! I can't wait to finish off the simple stuff remaining. Kurt
Ah Haaa! <light bulb goes on> Ok, I am aware of the usage of PIC_DERIVATIVE_NEW_ADC in j5_io.inc. So I guess I assumed that the 4620 must not qualify as a a new adc because I hadn't seen any file that indicated it would qualify as that. I did search the pic18f4620 header file assuming this define would be in there. The problem is that I don't have a hw_flags.h file. It doesn't exist in my project directory, and it's not in the j5_io modules directory. . Searching my hard drive, I found a version of the hw_flag.h file and I can see now that the 4620 IS a new style adc, and it's absolutely the case that my code is built with PIC_DERIVATIVE_NEW_ADC undefined. So BINGO this has to be the problem. But.. To address this condition where I don't have a hw_flags.h, I only found two copies of it and neither of them were in the repository directories. One is in a j5_dout_v1d directory that is a j5 dout example app that I downloaded, and the other is in the midibox_sid_v2_0_rc25 directory, another download. I don't find the file anywhere in my entire copy of the svn repository. #1) Where exactly is this file supposed to reside normally? #2) Where is the appropriate place to include this header file? Obviously it's of vital use to the j5_io.inc file, but it isn't included there? Is that just an oversight, or is there something deeper I'm missing? Thanks for the help TK!! This is the most certainly what the problem is and I can hardly wait to try it out.
I've reconfirmed that the hardware works perfectly when connected to J8 J9, so it seem to certainly be a software problem. On observation that may be a clue is that, when connected to any of the J5 locations, it always shows that one of the buttons is pressed when it boots up.. whereas when its connected to J8/J9 it never shows such until a button is actually pressed. Perhaps a timing issue when reading DIN via port-a or port-e? I don't think it's of any real importance, but I am using a 18f4620.
I used the web access to view the diffs and applied them by hand.. It certainly looked promising, but it didn't work.
hmm ok.. I'll check that out. Mine is dated July 9. snvmios isn't letting me connect right now. Kurt
This weekend I've been trying to get the scan matrix to work when connected via J5 (A0..A3). I'm using the sm_fast.asm example and the j5_io.asm examples together. The code setup: in sm_fast.asm I've defined latch and port definitions as follows: #define SM_SRIO_LAT_SCLK LATA ; Pin D.3 #define SM_SRIO_PIN_SCLK 3 #define SM_SRIO_LAT_RCLK LATA ; Pin D.2 #define SM_SRIO_PIN_RCLK 2 #define SM_SRIO_PORT_DIN PORTA ; Pin D.1 #define SM_SRIO_PIN_DIN 1 #define SM_SRIO_LAT_DOUT LATA ; Pin D.0 #define SM_SRIO_PIN_DOUT 0 Init() of main.c is: void Init(void) __wparam { MIOS_AIN_UnMuxed(); MIOS_AIN_DynamicPrioSet(0); MIOS_AIN_NumberSet(0); // set J5 A.1 to be input and all other lines to be output J5_IO_Init(0x2); // initialize the timer function for the debounce counters // we want to setup the timer with a frequency of 1kHz = 1 mS // prescaler 1:1 should be used // calculate the required number of clocks for this period: // clocks = period / 100 nS = 1 mS / 100 nS = 10000 MIOS_TIMER_Init(0x00, 10000); //10000); // initialize the scan matrix driver SM_Init(); // initialize the shift registers // I'm hoping to eventually be able to use the SRIO driver! - please oh please MIOS_SRIO_NumberSet(0); // DONT USE THE MIOS SRIO DRIVER!!! } The Hardware Setup: I've created a small board that just a DOUT X2, and a DIN X1. It's wired into J5 A.0 - A.3. I've connected this board to the norman J8 J9 location and it works fine. When I connect it to J5 though it seems that the software isn't getting the input correctly. Using a scope, I can see the DOUT being strobed low just, and when I press a button in the matrix, I can the lines going into the DIN pulsing low as that column is scanned by the DOUT. But I'm not getting any recognition, by testing the sm_button_value variable, that a button has been pressed. Is there something I'm missing here? Shouldn't this work? Kurt
RC2 and RC3 Core Port:Pin values are swapped in TK's pin list document. needs attention: http://www.ucapps.de/mios/mios_pin_list.txt The wiki has it correct, but of course all yesterday it was unavailable. http://www.midibox.org/dokuwiki/mios_pin_list
There is a module called j5_io that sets up the J5 pins to be inputs and/or outputs.
Not sure what "blog this sucker" really means, but I will gather all the info into one place when I get done.. right now I'm too stressed. I now officially have two weeks to get this doing what I need it to do. More on that later :-X For now, here is a tasty video of the current state.
It just occurred to me that if you aren't making use of the CAN interface, I don't think you have to worry about the pull up resistor. You could always give it a test without it.
The Vd (+5v) pin is right nearby.. perhaps that might be a good location.
The real hack here: I need a support that holds the big play/rew/ff/rec/etc.. buttons at the bottom. I'm not really feeling like replicating their board and then etching my own version. If I did that then why not just etch all of the internals and make my own all-in-one. Nah. I take the main board and chop off the lower section using a jig saw then wire straight to the button backs. Don't forget the encoder that I recently got working.
Here's where I think things start to get good. I was trying to figure out how all these things were going to be supported in here. I wanted to use plastic sheets, but I couldn't find any place that sold them around here. Actually I didn't even try that hard, I just happened across mini plywood while at the craft store. Plywood was perfect. It's strong, light weight, and can be easily glues into strange shapes. So after a little planning I built a large surface that would hold the power supply, a DIN, and a DOUT. Then I built a bracket that mounts to the right-most screw posts and supports a smash core board in the back of the unit.
