1,240 -
28
Smithy last won the day on March 2 2024
Smithy had the most liked content!
About Smithy
- Birthday April 6
Contact Methods
Website URL
www.soundcloud/adriansmith
Gender
Male
Location
Cork, Ireland
Recent Profile Visitors
Smithy's Achievements
MIDIbox Guru (4/4)
42
Glad you got it sorted! You even coaxed @nILS back to the forum! Welcome back!
Have you used the diode test function with your multimeter to see if the LED illuminates? First thing I would check is if the anode and cathode are in the correct holes or if the LED is dead.
Absolutely beautiful build and much more affordable front panel design also. If you could upload the STLs to the MB-6582 wiki page under the "Panel Designs" section it would be the best place for them: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582 Otherwise they will not be preserved for future builders.
Update: MIOS Studio shows each button press with the Quad Genesis software so only LED testing is necessary. Hi everyone, I am half way through soldering the Front Panel PCB for MIDIbox Quad Genesis. I am finding that the SMT shift register ICs and SMT Resistor arrays are difficult to solder as the pads could be a little bigger as Sauraen mentioned in the wiki page and my SMT soldering isnt always accurate. This means that the connections can be unreliable and I am re-soldering each IC in order. I would like to test each LED and Button before soldering the remaining components (LEDs that go through the Front Panel, Numeric LED displays and Encoders are all thats remaining.) I have flashed MIDIbox NG to the core and can do some rudimentary tests such as lighting up all Red LEDs with the command "set dout all 1". I would like to be able configure the LED and Button Matrixes in MIDIbox NG so i can test each button and LED individually. This would really aid the troubleshooting process, verify each matrix is working before moving onto the next and will aid future builders also. If anyone could help me get started i would really appreciate it. You can find the DOUT matrix map here: http://wiki.midibox.org/doku.php?id=mbqg_fp#dout_matrix_map Thanks for your time, Smithy
Hi TK, It works for the latest post in the thread and the original post but none of the posts in between. It's a strange one!
Hi @TK., there appears to be an issue with the forum when editing an existing post. I tried editing a post in my "Build Guide: MIDIbox Quad Genesis" thread in the MIDIbox FM forum. This is the error that came up: [[Template core/front/forms/popupTemplate is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] I tried uploading a screenshot of the above error message in this post also but it said: Sorry, an unknown server error occurred when uploading this file. (Error code: -200) Thanks for your time, Smithy. d o
Smithy started following MIDIbox Quad Genesis and Build Guide: MIDIbox Quad Genesis
Just found a cheap source on AliExpress for the m3 threaded inserts for wood: https://a.aliexpress.com/_EwPghFj Be sure to select m3xm5x6mm
Also check out the wooden case that Technobreath designed. It's a simple case based on Sauraen's metal enclosure that he repurposed. I modified the 8 mounting holes so they would fit the wooden case. I'll be using 8 threaded inserts for m3 screws that I bought on eBay. You can find the pdf here: http://wiki.midibox.org/doku.php?id=mbqg_tb_case
Hey man. It's actually an FR4-Standard PCB. Non aluminium. But seems pretty robust anyway.
Hey phatline, I paid a total of $184.26 for the 5 sets of the front panel and rear panel PCBs. I'm negotiating a partial refund for the lack of paper and the 2 boards with marks on them. So that's $37 for 1x Front Panel and 1x Rear panel. I *think* Sauraen may have some green MBQG_FP PCBs that have not been sold, a few years ago he had some left at least. He is on travels at the moment so may not reply until he is home. The Genesis module PCBs are sold out on Modular Addict, so I'm not sure if any more are available. The MIDIbox Shop is closed down and Modular Addict (USA) is the new shop for PCBs. https://modularaddict.com/shop-by-brand/midibox-ucapps-de Best to check with Sauraen, another friend of mine is interested in buying a set of Sauraens PCBs and my panels also. I also need to try and prioritize the people who already have MBQG_FP PCBs. @Sauraen I could try and get some more people interested in buying PCBs by posting on relevant Synth DIY facebook groups and forums. When I complete the build guide I think more people would be enticed to build their own. Thanks for your time, Smithy.
Thanks dude! I filed a complaint with JLCPCB to get a refund due to absence of paper between the PCBs which I paid for and also a partial refund for the scuffed boards.
I have 4 Front Panels and 4 Rear Panels for sale. Please see this post:
Update especially for people who have ordered Sauraen's Front Panel PCBs. TLDR: I have 4 Front Panels and 4 Rear Panels for MIDIbox Quad Genesis for sale. Life got in the way of both me and @ssp, and we lost contact for a few years! Thanks for your help dude, and if anyone would like acrylic panels laser cut you should contact him! The good news is that I ended up converting the Front Panels in .fpd format to PCB format using Kicad with lots of editing and learning. Here's how the Front Panels came out: I also designedRear Panels and this is how they turned out: Please note that the mounting holes for the Front Panel are designed to fit the DIY Wooden Enclosure that @technobreath designed for me: http://www.midibox.org/dokuwiki/doku.php?id=mbqg_tb_case You will need to use brass inserts that take 3mm bolts, drilled into the top of the case to be able to mount it. I will update the Build Guide I'm making with details on how to do this: The rear panel will require using a jigsaw or small saw to cut out the rectangle for the Rear Panel. I am really happy the way the precision of the Edge Cuts and how the silkscreen came out. The Front Panel PCBs fit Saureans green pcb underneath perfectly as you can see in the first image embedded Unfortunately JLCPCB did not put paper between the pcbs despite me paying for that option and 2 Front Panel PCBs had had minor scuffs: Nothing a Sharpie Pen couldn't fix though. If you are interested PM me and I can try and get a price for shipping it to your country. Just posting to see if there's any interest now.
Editing Wavetables (was: Ctrlr based editor for MBSID V2)
Smithy replied to Smithy's topic in MIDIbox SID
I am using a 12V 2A PSU that was used for an external harddrive and have Altitudes PSU mod installed on my MB-6582 with the fancy RECOM voltage regulators. I've had the issue with the original C64 PSU and power brick also so there may be a short or grounding issue. I think I could feel a tingle before when touching the fan's metal grill. I've procrastinated the repair in fear of making it worse but I will attempt to fix it someday! Thanks for the help with the Arp, I will try it out! I love how Insidious has the 4 clickable waveforms per step, as well as sync, ring mod etc.. And how it's much faster in general to recreate a SID tune. Not sure if it's possible to copy that UI without losing some features in CTRLr. If I have anymore ideas on a UI I will post them in the relevant CTRLr editor thread. Thanks Thorsten!
