Matrix12x
76 -
Everything posted by Matrix12x
Other than the patches that were in the install of the SID app, are there any other archives of MBSID patches?
How many people have tried it yet?
What keyboard did you use?
nice :)
Gloss Red and Gloss Black MB-6582 panel sets back in stock : )
Matrix12x replied to julianf's topic in Fleamarket
I would be up for Red if we get enough people for Red. Otherwise Black is fine. I liked the glossy look of your panels in the photos. I would also prefer the standard fan cutout. -
That looks great, much better that my home made panel. :) I would be interested. What do you think shipping to NY, USA might be in the ball park of? -
that really looks great. I was actually going to monitor temperatures on my unit. -
Panel mounted, LEDs being soldered tomorrow. I can't wait, I am in the home stretch for a completed MB6582!!!!!!! The base PCB has ben put through it's paces and works great!!
Thanks. Heck, I think I will post my 4685 for trade for a 4620.
I saw that the MB SEQ V3 page said to use the 18F4620, I have a PIC18F4685 with MIOS already on it. Is it possible to use this PIC? They seem comparable, and the PIC18F4685 has more program memory. Just wondering.
Do you mean that the LEDs would not protrude through the panel? Also, I just found my first mistake. Painting the backside of the panel. The JB welded standoffs peel paint if any pressure is placed upon them. I just had to replace half of them tonight. Now I am JB welding right to the aluminum, eliminating any paint in the areas I have to attach.
great work. The first one was even lower budget than this. ;-)
I just started epoxying the standoffs to the panel. I should have this mostly finished in a day or so.
Thanks. :-) I think I am going to use a clear plastic overlay, although I am afraid that cutting the holes in the laminate will look even crappier. Is the Avery type stuff ok? Is it available in only a few sheets? I just dry fit the control PCB and found I definitely had to open some of the button holes with the next size drill bit to allow for my off center drilling. Has anyone else drilled a panel at home for their MB8562?
Really cool. The plastic box is a great reuse of materials from around the house. What else have you used the milling machine for? I wanted to get an XY table for my drill press so I can cut some nice clean vents, as well as other more woodworking type things.
Here is a picture of the panel I drilled: http://picasaweb.google.com/lh/photo/AsbEERCzXIoSDPBVnrp4mg?feat=directlink A little wavy on those LEDs on the left, but heck, alot cheaper than Frontpanel express. ;-)
I drilled my panel, I think it looks like 90% of what I would of liked. some holes ended up a little off. I may have to open up 1 or 2 of the button holes. I painted it a flat black in the paint shop at work and that looks great. I will post pics when I finish things off a little better. Thanks for all the great hints like slowing the speed of the drill press and stepping up drill sizes for a cleaner cut.
I am having a similar problem. I am on a Mac OSX 10.5.7, using mmj. I can go edit a patch, no problems. I can exit that screen no problem, I go to edit another patch and it always crashes. 100% of the time.
I completed the rear panel and now I am 90% done drilling all the holes on the front panel. Only the LCD hole left to cut. I used the jig saw to cut the fan hole and the 25 pin D connector hole. They looked kind of cruddy, but a bit of filing and sanding and they are ok. I had the paint shop at work paint the rear panel. I'll post pictures soon.
This is a "cool" idea. ;) Anytime you can pull heat from an IC it is a good thing. It will also help reliability long term. I am definitely going to order some.
So I dropped the speed of my drill and what a difference!! nice clean no chatter holes. I should have this drilled by the end of the weekend. Thanks for the pointers everyone.
when drilling aluminum on a drill press what speed should I set the drill for? I primarily have drilled wood with this press so far. so when using the same speed, I made a very chattered looking 1/4 inch hole. any advice is welcome.
The transparency sounds cool and it will allow for graphics pretty easy. I was afraid with the jigsaw of making it too home made looking. although I could probably come up with a jig and a fence or two.
Has anyone taken the panel from the Pactek case and made the front panel with this yet? I was looking for lessons learned or recommendations. I printed out the FPD file and use it as a guide for drilling. My 1 yr old was helping in the photo below. http://picasaweb.google.com/lh/photo/h3SVi3vZ4EoKIQCUV3NX7w?feat=directlink What is the best way to cut the LCD hole without a milling machine? I was thinking about getting this painted black at the paint-shop at my job and maybe laser marked when done. I'll probably have to tell them it's for a piece of test equipment for my bench. ;)
Glad to hear you are ok!! Thats such a generous thing you did.
