115 -
About kroutshev
- Birthday January 1
Contact Methods
Website URL
https://myspace.com/misterbindalive
Gender
Not Telling
Location
France
kroutshev's Achievements
![Rank: MIDIbox Addict (2/4) MIDIbox Addict](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
Hi, is it normal that i have not received pm ? K.
This is where i have read that => http://www.sifam.com/knobDetails.asp?kType=Knobs_Collet&Type=3_02_S151 Base diameter: 15.5 (mm) Height (inc cap): 14.3 (mm) Shaft Depth: 7 (mm) 2 Colour: Y Pack size: 10 pcs And about fussy one 0.5$ ea, are they available ? and i need pointer close to shaft, is it ok ? Thanks. Bruno
Hi Altitude, Ok in that case i'd like to order knobs which are for 0.50 ea, fussy knobs with Grey Base/Black Middle and Red pointer I need 80 of them. And about "3/02/S151 250" knobs, i have read that i can order 10 minimum. I need 20 of them with C151 caps in red. Please could you tell me if i'm right ? Thanks a lot. K.
Ok Altitude, i'm not sure about two colour soft touch collets, they are used in x0xi0 kit and i have asked Brian to be sure about reference. I suppose that's 3/02/S151 006 Pointer close to shaft. About these knobs do you if i need to order caps or it's already include ? i need those which caps are removable to mount them in the "Bank and Mode selection" x0xb0x potentiometers. I don't know if i must order about shaft size 6 mm or 1/4 in ? [Edit] Ok confirmation from Brian, 3/02/S151 250 quantity = 20 About caps color and quantity reference C151 red 4 Orange 4 Green 4 Blue 4 Yellow 4 The others one i need : 3/04/DRP110 006 and pointer close to flat, Black Body Quantity and colors for Pointer : Red 16 Orange 16 Green 16 Blue 16 Yellow 16 If you have advise for x0xb0x use i'm very interested in case i have made a mistake. Thanks a lot. K.
I'll finalize my order that week-end. Have a nice time. K
Ok, i'll check dimensions tonight and i will post asap ! Thanks.
Ok, i have to cut the pots like when you used knobs provided in ladyada kit, few years ago ;-) But the diameter is ok. In that case i'm interested !
Hi Guys, i'm interested to buy them for x0xb0x, i like these one "3/04/DRP110 006" Can i use them for my x0x or i must modify pots before ? Thanks for your help. K.
Hi, if there's a bulk order for these knobs i'm interested ! I need few for x0xb0x ! Thanks K.
Hi Phunk, i have received knobs today ! Perfect, thanks a lot. K.
Ok i have tested with mono cable and i have the same phenomen ... sound is very low when jack is entirely plugged ... i have checked solder joints and it's ok !! Do you think that jack plug is bad ?
Yes i have tried another cable but this cable is used actually with my first sammich and it's good ! Yes i have checked solder joints. About Connector i have a question to wilba : the two connectors include into kit are the same ? Is there on stereo and the other mono ? Thanks.
