Primate
38 -
Everything posted by Primate
Hi, I'm in the middle of an MIDIBox project and it came to my mind that I could use a I2S compatible audio DAC (TI PCM1754 or PCM1781). I have been reading about the I2S synth on SVN repositories and have some questions: Is it possible to make this pinning: - LRCIN (WS) -> PA15 (J3:TDI) - BCKIN (CK) -> PB3 (J3:TDO) - DIN (SD) -> PB5 (J19:SO) - SCKI (MCLK) -> PC6 (J15B:E) or PC7 (J15A:E) If yes, how should the MIOS32_SRIO_SPI (in the mios32_config.h) be defined since neither SPI0 (J16) and SPI1 (J8) are used? Is it possible to use the DAC to make an audio output for headphones (i.e. while using Traktor)? Best regards
Core32 bootloader with openocd & parport wiggler
Primate replied to SMIDIRIN's topic in Testing/Troubleshooting
I successfully uploaded the bootloader...BUT via COM port (ROM based UART Bootloader method) :frantics: I wasted three days to get the JTAG going but with no success and I think that the COM port method is the easiest one. First of all less hardware components are required for the job (a COM port connector, four 100nF capacitors and a MAX232). Second and most important the bootloader upload is painless and quick. So all the noobs out there be aware of this. Never the less tnx to everybody who helped to get my Core going...and now for the fun :D Best regards, Primate -
I have placed all files (parport_lpt1.cfg, STM32F10x.cfg, STM32F10x_upload.script, project.bin) to C:\Program Files\OpenOCD\0.1.0\bin I have soldered a LED+resistor between Ucc and GND on the wiggler. I power it trough a USB, voltages are 2.9 V, I think that's ok. I'm using a Phillips 74HC244N, it has a little bit different pins then 74AC244 but I have taken that into account. Transistor and resistors are ok. I also doublechecked the wiggler connection. Do you maybe remember what errors? Here is what I get when I try to get it going: OpenOCD 0.1.0. C:\Program Files\OpenOCD\0.1.0\bin>openocd -f parport_lpt1.cfg -f STM32F10x.cfg Open On-Chip Debugger 0.1.0 (2009-01-21-21:15) Release BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS $URL: https://kc8apf@svn.berlios.de/svnroot/repos/openocd/tags/openocd-0.1.0/src/openocd.c $ jtag_speed: 0 Error: missing privileges for direct i/o Runtime error, file "command.c", line 456: Open OCD 0.2.0. C:\Program Files\OpenOCD\0.2.0\bin>openocd -f parport_lpt1.cfg -f STM32F10x.cfg Open On-Chip Debugger 0.2.0 (2009-07-18-09:50) Release $URL: http://svn.berlios.de/svnroot/repos/openocd/tags/openocd-0.2.0/src/openocd.c $ For bug reports, read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS parport port = 888 jtag_speed: 0 jtag_nsrst_delay: 500 jtag_ntrst_delay: 500 Error: Translation from khz to jtag_speed not implemented Error: missing privileges for direct i/o Runtime error, file "command.c", line 469: As you can see there are two repetative errors Error: missing privileges for direct i/o Runtime error, file "command.c" What are the odds that this is windows 7 related? -
Hi, I have a DIY wiggler made from schematics nILS posted, and a 0.4.0. version of OpenOCD. I'm stuck and need help. When I run OpenOCD i get this: C:\Program Files\OpenOCD\0.4.0\bin>openocd -f %MIOS32_PATH%\etc\openocd\interface\parport_lpt1.cfg -f %MIOS32_PATH%\etc\openocd\target\STM32F10x.cfg Open On-Chip Debugger 0.4.0 (2010-02-22-19:05) Licensed under GNU GPL v2 For bug reports, read http://openocd.berlios.de/doc/doxygen/bugs.html parport port = 0x378 Runtime error, file "C:\Users\Joc\Desktop\MIDIBox\trunk\etc\openocd\interface\parport_lpt1.cfg", line 11: invalid command name "jtag_speed" I also tried wit 0.2.0. version of OpenOCD but with no luck. I have a feeling it's a minor obstacle but I'm a total noob. Does anybody know where can I find an OpenOCD 0.1.0 installer (for Windows)? Also, does the Core have to be connected to the wiggler at all time? BTW, is it normal for a LED to lighten up when the wiggler is connected to the parallel port? By the schematics I thought that the wiggler needed a power supply from the STM32 core :unsure: -
Hi, I'm also planing to work on a new project and I did some research (btw very very nice work with the tutorials :frantics:) but I didn't know that you can assign free I/O pins to i.e. AINs. Does this mean that the number of pots, buttons, LEDs or even MIDI IN/OUT ports is limited by the number of free I/O pins (and my programing skills)? If so than this Core32 is more powerful than I thought :drool: One more question just to make sure, I presume that there is no need to ground the unused pins on the STM32 like the analog input pins on the PIC core, right? Best regards
Hi, I was also planning to make a new project including a CODEC from TI for line outputs on my MIDIbox. So far I'm going for the PCM1792A (a x2 output, 132dB SNR, 24-bit, 192 kHz Stereo DAC), but I'll have to see how to implement it in the MIDIbox (using STM32 core). Keep us posted!!! :rolleyes:
How is it going with the buttons?
Yeah I found that out recently but tnx anyhow. Maybe I'll post a video if I get the time and the camera ;) Bye
Tnx very much for that...sincerely I didn't think that could be done that way
Yeah but on which channel and note??? :P I didn't develop my own firmware and I don't know the DOUT channel of other accessible firmware...
Why? Btw I'm in the programming phase for my controller so as soon as I figure out the Traktor LED control I'll let you know.
Tnx for the info about the vmidibox, I didn't know for that. Although I can't "assign" LEDs to pots (or can I ???) only buttons, and therefore I'll need customized firmware for my controller... I'm currently using MTE's Traktorizer firmware...you can see from the picture it's not suited for my needs. Anubis.JPG Anubis.JPG
Yes I did and now I'm trying to make the app which is not going as I planned. I didn't manage the "Setup and install" for the app development. Also I didn't quite figure out the app development (read program logic). To be honest I really have little time for app development research (because of the other things on my mind) so if you have some directions I'll be glad if you share it with me. I was searching the forum for that matter but it takes a lot of time to get some useful info. I was also wondering how to setup Microsoft Visual Studio C++ for the app development? ???
Fond the problem. The power supply, the power connector on the case to be more accurate. It was making a short circuit which apparently effected the PIC long enough to make him go bad. Anyway tnx to everybody who helped!!! Regards
Yes it works but with a new PIC :P I only want to determine what went wrong and why so I can prevent it from happening again (and maybe help somebody with a similar problem in the future). The reboot surely didn't occurred. I also didn't notice anything out of the ordinary on the PC, further more I've tested the controller on a laptop also. One more thing, the LEDs didn't light on startup as usually although I had the voltages as described in the earlier post. The INOUT1 test was OK in the end. I've also tried to check out the PIC memory via chip burner and I wasn't able to either write or erase the the memory (had an error message) which indicates, to me, that the PIC didn't work properly. Maybe it was the PC's fault but I somehow doubt it. I'm wondering did maybe the power supply fail on me (read there was not enough current) or was there a short circuit...hmmm
Hi guys. Yesterday I was back from a trip and continued detecting what was causing my controller not to work. To make a long story short I couldn't get the controller to work (although the re-installation of the drivers resulted a good INOUT1 TEST) so today I bought a new PIC and guess what...it was the PIC's fault after all. Everything is OK now (:D) but I still don't know what caused the PIC to malfunction, do you have an idea? I would like, if possible, to prevent and avoid this to happen again. Regards
Now that I have some hints I'll check them all and report what have I done. Thx once again! ;)
NO Thorsten thank you for the help! Ok I've made the test on a Desktop computer and the OUT MONITOR doesn't reflect to the IN MONITOR. Furthermore I have tested the MIDI interface on a laptop and situation there is the same. I'll reinstall the drivers because nothing else comes to my mind how to solve this.
First of all thx for the quick response TK ;) TEST INOUT1 MIDI MONITOR OUT: timestamp [unknown] | SysEx: F0 00 00 7E 40 01 02 00 00 00 00 00 00 F7 Nothing on MIDI MONITOR IN. Starting upload of bootloader_v1_2b_pic18f452.hex Hex file contains code in MIOS range, forcing reboot for upload via 1st level bootloader! The reboot request will lead to an error acknowledge, please ignore! Waiting for upload request... As I understand in this test it is necessary to send a .hex file and see what is on the IN and the OUT monitor? (Sorry but I'm confused after two days of trying to get this running)
Hi guys. I have built my MIDI controller and everything was working fine till yesterday when I powered up the unit and nothing happened. Since then I was trying to solve the problem but unsuccessfully and I really hope you could help me. So I have a controller with 16 pots, 8 buttons and 32 LEDs connected with the PC via E-MU Xmidi 1x1 USB Interface. As I mentioned everything was fine which makes things more confusing. Now I can't upload apps (neither the mios and the bootloader) and here is what I get when I try to upload: Starting upload of app.hex Sending block #1 00003000-000030FF there it stops and nothing else happens. App timestamp [unknown] | SysEx: F0 00 00 7E 40 00 02 0C 00 00 20 26 7B 65 2F 02 4F 5E 2A 78 16 3D 72 57 41 51 6F 15 3C 0D 1E 79 2B 60 6F 77 4A 5E 0A 5F 3C 55 70 5D 3B 65 2F 04 6F 5E 2A 78 28 7D 72 57 43 13 6F 15 3C 12 3E 79 2B 61 0D 77 4A 5E 07 2F 3C 55 70 40 3B 65 2F 00 1F 5E 2D 78 02 1D 72 6F 40 13 6F 16 7C 01 2E 79 37 61 1A 77 4A 5E 09 4F 3C 55 70 05 7B 65 5F 00 33 5E 2D 78 03 3D 72 6F 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 04 F7 MIOS or Bootloader timestamp [unknown] | SysEx: F0 00 00 7E 40 01 02 00 00 00 00 00 00 F7 I have also troubleshooted the core: * TEST PROG1: bootstrap loader has been burned successfully before but now I can't do it * TEST CORE1: done that * TEST CORE2: / * TEST CORE3: everything OK (doublechecked) * TEST CORE4: I have 4.88 V except on the Tx of the PIC18F452 (pin 25) where the voltage is 3.7 V (with the cabel plugged in) * TEST CORE5: ground OK * TEST CORE6: OK * TEST CORE7: OK * TEST CORE8: OK * TEST CORE9: OK (doublechecked) * TEST CORE10: I didn't notice any request messages at all * TEST CORE11: I'm 99% positive this is OK * TEST OUT1: LED doesn't flicker * TEST OUT2: I think this is not required since the controller worked properly with the ground line of MIDI Out port As I searched the forum I noticed that somebody had a similar issue but since I don't understand German so well I didn't figure out how to solve the problem. If I had missed out some info let me know and thx for the help!!!
Well I have the tools (specially because my dad is a repairman) except an laser cutter and the compound miter saw,lol. But to sacrifice some time so I can get a satisfying and precise result isn't a problem for me. LOL but tnx for the support and the belief in us Balkans! :D
Yesterday I went to cut out the aluminium to the desired dimensions. After the guy has done the cutting job all I have to do is to quote noofny. "if you want something done right - just don't give it to the retard at the metal yard in Arncliff" In my case retard from Zagreb but it's amazing that people who do something every day can't do it properly. I attached some pics so you can see what the retard did. There's also a pic of a rough shape of the controller casing. The PCB is coming on friday and I can't wait to see it. I'll keep you updated. Cheers. fus.JPG fus.JPG
Tnx for the info but I'll have the chance to check it out when Anubis is finished (I hope that will be in 2-3 weeks :P). But of course you will be updated!
I'm intending to use this feature on my controller so I'll let you know if it works.
