17 -
About psyreactor
- Birthday 05/31/1982
Gender
Male
Location
Buenos Aires, Argentina
Contact Methods
Jabber
marianilucas@gmail.com
psyreactor's Achievements
Happy B-Day Wilba :frantics:
hi *.* I can put together a bulk order in the wiki and receive pm, to build lists and confirm the orders, working to free the person who receives and forwards. All this I might start doing it on Saturday to finish my Vacation! I offer to make me not forwarding because I live in Argentina and costs would be high. sorry for my English, I speak Spanish. Best Regard Lucas
hi *.* If the price 0.60 eur? I scored with 100 Black/Red! :frantics: (Drehknopf DK16-190V3 A.6/4,5 AT=14 schwarz soft-rot 3092 (red on black)) I live in Argentina Sorry for my English, I speak Spanish. best regards Lucas
hi *.* works! :frantics: :frantics: Thank you very much for all your help!. Comment on the solution in case anyone happens the same, the leg 28 and the 27 were short, of left Sid (unexplainable, but marked continuity, scraping a little about the pads, was eliminated continuity). That life is beautiful in stereo. :D :D best regards lucas.
SammichSID: Final pre-flight checks failed :(
psyreactor replied to ElectroDruid's topic in MIDIbox SID
hi my English is very very bad!! sorry! What type of power supply do you use? if your power supply is 12V regulated to measure the 12V pins must be bridged JBP This is what happened to me, I use 6581 The JBP prevents the voltages passing through the diode bridge, as you continued imposition of the JP in 6582 or 8580 if this is your type of SID. I hope, have helped best regards Lucas -
hi *.* I still can not run the sammichSID stereo. change, the left BC547 transistor. And it maintains the same symptom, in the drum kit xx patch, which should sound in the left channel sounds very very low and if any patch I put it in mono, not sound directly. you can get the printed design to measure the continuity of the track. Help please! best regards Lucas.
hi punk The plug is stereo and are denon stereo headphones. After much measuring and remeasuring tensions, and not getting anywhere. :wacko: :wacko: I just started assembling the core of the second kit, with the same sid and the same controller board, success!, stereo sound . The question I have is, will not be left output transistor is causing the problem?. If someone has a better track, would be of great help! :laugh: Tomorrow I replace the transistor! PD: Punk your Spanish is 100 times better than my google tranlate! :thumbsup: best regards Lucas.
hi *.* sorry, my English is horrible! :tongue: :tongue: Symptoms The problem I have is that it sounds mono. When I load the drum kit 1 of the pacth sounds bad, if I configure mono sound all sounds. Another thing I encounter in the patch of zelda, is that if you shoot a very short note, it sounds and then listen to the rest of the sequence, with very very low volume. What I have I use a 12V regulated supply. Two SID 6581. 470pf capacitors. Tests The measurements were successful. I spent the sid and starts playing mono, always the right channel. I have a SID 6582 (changing the capacitors and jumpers), I use to test, since I have reserved for MB6582, the same result. Change the 74HC595, the same result. The sammichSID works fine (menus, navigation, upload and patches) :sweat: . If you give me an idea where to go, I'd be very grateful. I have another kit to build, but I'm interested to work well first. Best Regards Lucas
the information was in the WKI here, but moved here. The site is down and he had no funds to mantain the site, there is a mail where you can write. sorry for my English best regards Lucas.
hi sorry for my English :tongue: We need to install subversion, we lower the dmg from here!, Once svnX downloaded subversion installed, which is a gui for subversion this is the link Open svnX and add the repository MIOS32 svn: / / svnmios.midibox.org/mios32 double click on the repo we added down the structure of the repository. Then download the binary of the STM32 toolchain from here, what Unzip and copy the STM32 folder in / usr / local /. Open a terminal and type ... sudo-s nano / etc / bashrc and add at end of file export PATH = $ PATH: / usr/local/stm32/bin export MIOS32_PATH = path_del_repo_svnx / trunk export MIOS32_BIN_PATH = $ MIOS32_PATH/bin export MIOS32_GCC_PREFIX = arm-none-EABI export MIOS32_FAMILY = STM32F10x export MIOS32_PROCESSOR = STM32F103RE export MIOS32_BOARD = MBHP_CORE_STM32 export MIOS32_LCD = CCD resource staff Store and are ready for the final step of lowering the Xcode Apple's page here (must register to download the Xcode). Remember the upper version of Xcode not working, if anyone has a method to use, I'm interested. installed and ready, and we can test our MIOS32 toolchain. Open a terminal and do the following ... cd $ MIOS32_PATH/apps/tutorials/001_forwarding_midi make-s Would have to leave it next --------------------------- Application successfully built for: Processor: STM32F103RE Family: STM32F10x Board: MBHP_CORE_STM32 LCD: CCD resource staff _____________________________________________________ So we ended up configuring everything, keep in mind that is MIOS32 relatively new and not much code midibox drivers there is only version 2 of the LC midibox not compile that no term to develop support for GLCD, if comments on all GLCD lines lc_lcd.c file compiled with support program for CLCD resource staff. This is the install process that worked for me! Again, sorry for my English! Any questions at your disposal. best regards Lucas
+1 I'm in!!!
hi In this direction are sold. http://www.voti.nl/shop/catalog.html Best Regards Lucas.
hello I interezado in the sid buy, I send you a pm. Best Regards. Lucas.
Saludos a todos, Tengo dudas con mi primer proyecto.
psyreactor replied to psyreactor's topic in Español
Ya he actualizado el layout y los datos del proyecto. Alguien podrÃa guiarme con estas dudas, de donde puedo sacar información de sobre esto. 1- Cuantas placas AINx4, DINx4 y DOUTx4 puedo conectar a un core, ya que si tengo un limite que no me permita controlar todo los potes, botones, leds, etc. tendrÃa que unir varios cores. 2- No he encontrado documentación de la programación con ejemplos de como accionar solo un pote, solo un botón, etc. para empezar a probar. Por lo que leà explican como instalar las herramientas para poder compilar el programa. 3- Información de como se manejan los canales midi, tanto para enviar como para recibir información. (Aunque por lo leÃdo también tendrÃa que introducirme en el mundo de Max, ya que a partir de la versión 8 de live estarÃa disponible Max for Live. Gracias ;) -
El post anterior lo publique antes de ver el post de Sasha. Le he pedido disculpas por MP y retire la imagen, subiré un layout realizado por mi. Sinceramente no creà que generarÃa tanta discordia modificar un jpg, para mostrar lo que tenia ganas de hacer, siendo que lo primero que hice fue mencionar su trabajo, como base para lo que yo tenia ganas de hacer. Pero sinceramente pido disculpas.
