psyreactor
    17
Everything posted by psyreactor
  1. Happy B-Day Wilba :frantics:
  2. hi *.* I can put together a bulk order in the wiki and receive pm, to build lists and confirm the orders, working to free the person who receives and forwards. All this I might start doing it on Saturday to finish my Vacation! I offer to make me not forwarding because I live in Argentina and costs would be high. sorry for my English, I speak Spanish. Best Regard Lucas
  3. hi *.* If the price 0.60 eur? I scored with 100 Black/Red! :frantics: (Drehknopf DK16-190V3 A.6/4,5 AT=14 schwarz soft-rot 3092 (red on black)) I live in Argentina Sorry for my English, I speak Spanish. best regards Lucas
  4. hi *.* works! :frantics: :frantics: Thank you very much for all your help!. Comment on the solution in case anyone happens the same, the leg 28 and the 27 were short, of left Sid (unexplainable, but marked continuity, scraping a little about the pads, was eliminated continuity). That life is beautiful in stereo. :D :D best regards lucas.
  5. hi my English is very very bad!! sorry! What type of power supply do you use? if your power supply is 12V regulated to measure the 12V pins must be bridged JBP This is what happened to me, I use 6581 The JBP prevents the voltages passing through the diode bridge, as you continued imposition of the JP in 6582 or 8580 if this is your type of SID. I hope, have helped best regards Lucas
  6. hi *.* I still can not run the sammichSID stereo. change, the left BC547 transistor. And it maintains the same symptom, in the drum kit xx patch, which should sound in the left channel sounds very very low and if any patch I put it in mono, not sound directly. you can get the printed design to measure the continuity of the track. Help please! best regards Lucas.
  7. hi punk The plug is stereo and are denon stereo headphones. After much measuring and remeasuring tensions, and not getting anywhere. :wacko: :wacko: I just started assembling the core of the second kit, with the same sid and the same controller board, success!, stereo sound . The question I have is, will not be left output transistor is causing the problem?. If someone has a better track, would be of great help! :laugh: Tomorrow I replace the transistor! PD: Punk your Spanish is 100 times better than my google tranlate! :thumbsup: best regards Lucas.
  8. hi *.* sorry, my English is horrible! :tongue: :tongue: Symptoms The problem I have is that it sounds mono. When I load the drum kit 1 of the pacth sounds bad, if I configure mono sound all sounds. Another thing I encounter in the patch of zelda, is that if you shoot a very short note, it sounds and then listen to the rest of the sequence, with very very low volume. What I have I use a 12V regulated supply. Two SID 6581. 470pf capacitors. Tests The measurements were successful. I spent the sid and starts playing mono, always the right channel. I have a SID 6582 (changing the capacitors and jumpers), I use to test, since I have reserved for MB6582, the same result. Change the 74HC595, the same result. The sammichSID works fine (menus, navigation, upload and patches) :sweat: . If you give me an idea where to go, I'd be very grateful. I have another kit to build, but I'm interested to work well first. Best Regards Lucas
  9. the information was in the WKI here, but moved here. The site is down and he had no funds to mantain the site, there is a mail where you can write. sorry for my English best regards Lucas.
  10. hi sorry for my English :tongue: We need to install subversion, we lower the dmg from here!, Once svnX downloaded subversion installed, which is a gui for subversion this is the link Open svnX and add the repository MIOS32 svn: / / svnmios.midibox.org/mios32 double click on the repo we added down the structure of the repository. Then download the binary of the STM32 toolchain from here, what Unzip and copy the STM32 folder in / usr / local /. Open a terminal and type ... sudo-s nano / etc / bashrc and add at end of file export PATH = $ PATH: / usr/local/stm32/bin export MIOS32_PATH = path_del_repo_svnx / trunk export MIOS32_BIN_PATH = $ MIOS32_PATH/bin export MIOS32_GCC_PREFIX = arm-none-EABI export MIOS32_FAMILY = STM32F10x export MIOS32_PROCESSOR = STM32F103RE export MIOS32_BOARD = MBHP_CORE_STM32 export MIOS32_LCD = CCD resource staff Store and are ready for the final step of lowering the Xcode Apple's page here (must register to download the Xcode). Remember the upper version of Xcode not working, if anyone has a method to use, I'm interested. installed and ready, and we can test our MIOS32 toolchain. Open a terminal and do the following ... cd $ MIOS32_PATH/apps/tutorials/001_forwarding_midi make-s Would have to leave it next --------------------------- Application successfully built for: Processor: STM32F103RE Family: STM32F10x Board: MBHP_CORE_STM32 LCD: CCD resource staff _____________________________________________________ So we ended up configuring everything, keep in mind that is MIOS32 relatively new and not much code midibox drivers there is only version 2 of the LC midibox not compile that no term to develop support for GLCD, if comments on all GLCD lines lc_lcd.c file compiled with support program for CLCD resource staff. This is the install process that worked for me! Again, sorry for my English! Any questions at your disposal. best regards Lucas
  11. +1 I'm in!!!
  12. hi In this direction are sold. http://www.voti.nl/shop/catalog.html Best Regards Lucas.
  13. hello I interezado in the sid buy, I send you a pm. Best Regards. Lucas.
  14. Ya he actualizado el layout y los datos del proyecto. Alguien podría guiarme con estas dudas, de donde puedo sacar información de sobre esto. 1- Cuantas placas AINx4, DINx4 y DOUTx4 puedo conectar a un core, ya que si tengo un limite que no me permita controlar todo los potes, botones, leds, etc. tendría que unir varios cores. 2- No he encontrado documentación de la programación con ejemplos de como accionar solo un pote, solo un botón, etc. para empezar a probar. Por lo que leí explican como instalar las herramientas para poder compilar el programa. 3- Información de como se manejan los canales midi, tanto para enviar como para recibir información. (Aunque por lo leído también tendría que introducirme en el mundo de Max, ya que a partir de la versión 8 de live estaría disponible Max for Live. Gracias ;)
  15. El post anterior lo publique antes de ver el post de Sasha. Le he pedido disculpas por MP y retire la imagen, subiré un layout realizado por mi. Sinceramente no creí que generaría tanta discordia modificar un jpg, para mostrar lo que tenia ganas de hacer, siendo que lo primero que hice fue mencionar su trabajo, como base para lo que yo tenia ganas de hacer. Pero sinceramente pido disculpas.
  16. Gracias por sus comentarios!!! Cimo tenes razón fue muy desconsiderado de mi parte no pedir permiso a Sasha, ya que el layout es de el, le envié un MP pendiéndole disculpas por no haber solicitado su permiso. Si no recibo una respuesta despublicare la imagen y realizare una nueva. Con respecto al tema de la electrónica, no tendría problema ya que soy técnico electrónico. Con la programación me llevo bien, pero C no es mi mundo, yo utilizo PHP, aun que los dos lenguajes son similares deberé aceitarme un poco y tomar algunos apuntes de la facu y mucho google. Ahora tengo algunas dudas puntuales. 1- Cuantas placas AINx4, DINx4 y DOUTx4 puedo conectar a un core, ya que si tengo un limite que no me permita controlar todo los potes, botones, leds, etc. tendría que unir varios cores. 2- No he encontrado documentación de la programacion con ejemplos de como accionar solo un pote, solo un botón, etc. para empezar a probar. Por lo que leí explican como instalar las herramientas para poder compilar el programa. 3- Información de como se manejan los canales midi, tanto para enviar como para recibir información. (Aunque por lo leído también tendría que introducirme en el mundo de Max, ya que a partir de la versión 8 de live estaría disponible Max for Live. Con esta información creo que ya podría comenzar. Desde ya muchas Gracias ;)
  17. Antes que nada me presento mi nombre es Lucas soy de argentina - Buenos Aires. Estuve leyendo muchos post del foro e informándome, viendo varios proyectos muy interesantes de otros usuarios. En esta búsqueda me tope con este proyecto de Sasha, que es un controlador para live y mixer de audio, a mi particularmente me interesa solamente el controlador midi para Ableton Live. También busque controladores comerciales para ver las utilidades que plantean los fabricantes de controladores y me tope con el controlador de Akai para Live. Acá dejo los links para que vean el proyecto de sasha y el controlador comercial de Akia. Mi prototipo realizado en photoshop, donde utilizado la imagen de sasha para realizar las modificaciones que me parecían interesantes del akai. Proyecto de sasha http://www.midibox.org/forum/index.php/topic,10662.0.html Controlador Akai APC40 http://www.ableton.com/touch Ampliada Detallo algunas características Botones = 169 Faders = 9 Ratary encoder = 16 Display de 7 Segmentos = 12 => Avance del track en modo Arreglo LED RGB = 48 => 144 LED (esto es para la matriz de clips, ya que si hay clip cargado el botón se iluminaría de naranja, si esta en play verde y rojo si se esta grabando en ese clip, los led rgb tiene 4 pines uno por cada color y una para la GND) LED = 108 =>para botones que se ilumina cuando son activados Ring LEDs = 176 => 11 Led en anillo para cada rotary encoder LED Vumetro = 120 => LED Bar la lado de los faders Esto seria más o menos mis ambiciones :o Aclaro que leí mucho pero entendí poco, ya que no se mucho de ingles, pero estoy seguro que ningún proyecto de los realizado se adapta a lo que yo necesito. Las dudas que se me generan son las siguientes, cuantas placas AINX4, DINX4 y DOUTX4 se pueden conectar por cada core. Si es que se pudieran conectar por Ej.: 6 de cada una, debería programar una aplicación que pueda manejar todos, es posible que programando en c pueda controlar todo esto, porque según lo leído en c el programa compilado ocupa mucho mas espacio y no seria soportado por el PIC del core. O me convendría usar las aplicaciones ya creadas (ej. Midibox128, Midibox64E, Midibox64) encadenando varios cores. Estoy de vacaciones, pero cuando vuelva dentro de 15 días pediré por SmashTV's mi primer core y 4 de cada modulo para experimentar. Primero necesitaría evacuar estas dudas y después supongo que surgirán otras así, seguiré buscando y solicitando su ayuda. Desde ya muchísimas gracias a todos por apoyar y desarrollar estos proyectos.
