WhoopJohn
    4
Everything posted by WhoopJohn
  1. With a bit of confidence you can strip surface mount off boards. It often helps to clamp the board vertically and run a cow's hoof iron tip up and down one side while prising that side slightly off the board. The other side is then easy. I keep seeing these new Yamaha with OPL cards on UK ebay for not much spondoolicks - there always seems to be someone selling them. My link
  2. OK, maybe your mum did, but nowhere in this thread do I see a mention that you need to expose the solution and your material under UV light, otherwise you can end up with brittle material with a white bloom and micro-pits in it. What particular UV source did your mum teach you to use?
  3. OK thanks, I knew there must be one somewhere - I kept missing it.
  4. I am about to embark upon building this project as I have a bunch of the OPL3 chipsets, but the one thing I cannot see anywhere is a schematic for the MIDIbox FM. Does one exist?
