48 -
Everything posted by warpboy
Seq V4 problem : stop working when I choose another pattern !
warpboy replied to warpboy's topic in MIDIbox SEQ
hello, I was so happy with my session working again that I've not answered to your question : I have no guarantee about the reason : - quick electrical interrrupt -SD card problem, removed while it was saving datas.... I'll keep an eye, but It seems the reason is an external problem to the seq V4 and not inside it . Best regards -
Yeeeeeeeeeees, thank you so much Thorsten !!!!! We have a live tomorrow, of course the midibox seq V4 is the heart... Today we have sun, if it's the same for you, take a beer ;-) Best regards Fabien -
hello Thorsten, thank you so much. To be a bit more clear, the problem is with the group 2 only, when I want to go from the pattern A6 to A7, I can't !!! lcds freeze, no more control enable, I have to re-start the sequencer. Best regards Fabien04-2015.zip -
Hello, Everything was working well for a long time, but now when I open the session that I use, I can't change from from one pattern to another. It seems I have the problem only with group 2 when I change from A6 to A7 pattern The sequencer lcds stop working, but It continues to play.... I have tried to create a new blank session. It works, but I have to understand what is the problem. Seq v4 software is V0.87 The SD card is the same till now... Any idea ??? Thank you in advance Warpboy
hello, I'd like to buy the core32 for a NXP lpc 17. let me know your price+shipping Could be interested by a joystick, do you have some pics ? best regards Warpboy
Hello Willitr, interested in the core8 kit. mail sent ! best regards
For Sale: MIDIbox SID V2 Synth - Boards and Parts
warpboy replied to polyhedron's topic in Fleamarket
hello Polyhedron, I'm interested in 2 cores boards. mikes-elektronikseite sell core V3 kits at 12,9€ each let me know ! Best regards Warpboy -
Hello, FFW, PM sent for LPC1769 core Thank you
Hello, first I wish you all the best for 2015 and I add a couple of beers for you TK. Midibox gears are full part of my live set, using already one seq V4, one seq V3, as soon as possible a new seq V4 + Aout NG( thank you TIM aka "not Mike" from Smash TV for selling again Seq V4 CS pcbs) and a 4xsid6581 for the next month! THX :thumbsup:
it was the same for me!!!! I've already a seq v4, bought here (sold by Esotericlabs) It's for me the best companion for live playing, I was waiting already in June of 2014 (last year!!) to build a second one and thank you Tim aka "not mike" :hyper:
Hello to the Midibox community First, I WISH EVERYBODY THE BEST FOR THIS YEAR !!! as every day :rolleyes: I have looked at midibox shop for new seq V4 pcb and it's arrived : back in stock I know many people where waiting for them, and I can't resist to share the info... Yeaaaah, thank you Mike ! And a new web site, great, great day
Hello, I'm really interested in this project !!! if possible I'm in for one board set thanx :thumbsup:
problem with compiling new setup midibox cv / Mplab 7.4
warpboy replied to warpboy's topic in MIOS programming (Assembler)
after measurements, if I look at out A ( pin 12 ) of the DAC, each time I increase of 1 octave the voltage increase of 200mV....Is it correct ? and it's the same for all the others outputs ( there is only outputs D and F that don't work for all notes) -
Hello TK, I'm using AOUT NG kit from smash tv. I'm using it in unipolar mode and calibrate the CV 1 to 8 with P1-P8 ( 5K multiturn trimpot) Out D (pin 15) from the DAC isn't working too , Out D = 0v I've looked for a short between the traces around the DAC, everything seems to be ok. I 've checked for +/- 12v and 5V on aout NG board. TL074 and the DAC are correctly supplied. Does it means I have burned the DAC ? :pinch: Thank you Fabien -
Hello, my midibox cv is fully assembled, but I have a problem with the cv. when I go from one octave to the next, the voltage increase only of 0,5v instead of 1v??? could it be a problem with my asm file or one problem with the DAC ? Thank you by advance Warpboy -
Hello TK, Thank you, it works, at the first time !!!! Now I'll add the encoder to my .asm file ( midibox CV with Aout NG : 2buttons + 1 encoder version) Thank you for all the midibox projects :queen: -
hello, I'm trying to compile my own setup.asm file (J5 enabled+encoder+aout NG) in mplab 7.4 (pc version) here is the result on my screen : Clean: Deleting intermediary and output files. Clean: Done. Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F452 "setup TORB.asm" /l"setup TORB.lst" /e"setup TORB.err" Error[108] C:\MIDICV\SETUP TORB.ASM 2 : Illegal character ( ) Error[129] C:\MIDICV\SETUP TORB.ASM 4 : Expected (END) Halting build on first failure as requested. BUILD FAILED: Wed Jan 09 04:28:51 2002 I don't understand why I've two errors. The Expexted END is not in the original .asm file downloaded on UCAPPS.... Any idea to help me compiling my config ? my midibox CV is ready to start ....but before I need to update and make and .hex file thank you by advance for helping me :-) W
Hi MTE, do you have some Chips still in stock ? I'm really interested!!!! Thank you W
hello, thank you Altitude for these infos. I don't understand why when I open setup_808_default.asm (with a text editor), I see C code and no asm....maybe I false (newbie stupid question..) then how can sdcc re-compile after an edit, if sdcc works with C program, it'll not recognize an asm extension file ? :wacko: Thank you by advance Warpboy
hello, do I have to install MSYS and GPUTILS too ? I just want to re-compile an ASM file after an edit in wordpad Thank you Fabien
hello, thank you for your reply. I'll try to install sdcc ... My seq works and I've made first tests using trigs outs ( I've connected bd and snare trigs at shift register #1) It's perfect bassdrum works better that I expected :frantics: Thorsten, you're THE king :ninja:
hello, I'd like to modify setup808 default.asm, I use mplab v8.46 + mpasm (pc version). When I click to compile this file I have plenty of errors (for this try, I don't modify anything in the asm file, just try to compile it!) you can see these errors in the attached file. I'm sure these errors are newbie problem... help is welllllllllllllllllllllllllllcome thank you
I'm stupid...so studpid.... :ike: I did three times the wiring....and three times fully faulse! I have inverted D0 to D7 with other eight pins (VS,VD,VO,RW...etc) Now it works. Button are connected, I have the leds to connect..... To be continued ! :frantics: Thank you again
I can add some infos : contrast works correctly, luminance has no effect. I have looked at J15 checked and re-checked point by point, it seems good. Should I look at RB0 to RB7...? The LCD is HD44780 compatible. Should I see any message on the LCD without DIN DOUT connected? (mios app & mb808 asm files are in the pic) I posted a screen capture of mios studio. Any idea ? thank you
