Steven_C Posted May 31, 2003 Posted May 31, 2003 Hello, I am really feeling like throwing my faders in the bin right now. I have spent an entire week (even skipping college to work on this) tweaking these things, and still I have unsatisfactory results. If anyone at all is happy with these faders, then please speak up as otherwise more people will be dissappointed like me, if they keep buying them. My faders refuse to work properly at each end of their travel, they stop at the wrong positions, and sometimes don't even move at all. I can't do a mix using this thing, as I'm afraid it will stuff up my mixes. can someone tell me how good the alps faders are? apparently LO's panasonics work ok, but he is using an old '877 firmware (lower resolution, I think) BTW, I tried offsetting the dc offset as I mentioned on the other thread, but no joy. Once you are happy with your project, it would be nice if you hang around for a while to help others who are having troubles, even if it is only occasional. (Thanks to all those who do help, though) sorry I'm in such a bad mood, bye, from Steve
d2k Posted May 31, 2003 Posted May 31, 2003 Hey Steve...Man i feel for ya - not least cos i've got 8 of these fellaz in all :-/...aint even tested them yet tho...Soz I cant be more help right now - but when/if I get them to work ok i'll report back...Hope it's just a minor thing...Peace...Dan
Steven_C Posted May 31, 2003 Author Posted May 31, 2003 Thanks Dan :) to be honest, I was a bit uptight when I wrote that, I should be more patient :P hopefully I'm just havin probs that are something to do with my own setup/circuit, and not probs that others will have to deal with.... I think I better take a break for a bit!! And then I'll take another look at the mios application code, see if I've missed some adjustment ::)bye, from Steve
Steven_C Posted May 31, 2003 Author Posted May 31, 2003 I searched through old posts, and could my problems be similar to these old posts? TK?quote....."Hello Thorsten, Ok, the Midi Overrun problem is solved . Thank You. I've wired up all the eight faders with cables less than 30cm. But i still have the problem of midi data intermittenly being sent by faders only moved by the motors. That is, if fader1 is assigned B0 00, and the motor is moving fader 1, it will sent out just a single value for example B0 00 02 or some other value at another time during automation playback. This happens also to all other faders only if they are moving. It happens intermittenly. If the automation playback is stopped, the midi output is stable with no jitter or false data being sent. I'm using Panasonic Faders, could this be in conflict with the delay settings you use in the Feedback elimination routines? Peace Frank"and...... "Hi Frank, I changed the timeout algorithm (slightly): up to now, the current fader value is copied into the "target" register during the timeout state after a fader has been moved. This should fix the problem (?) Link to the new firmware: http://www.ucapps.de/midibox_mf/midibox_mf_v0003.hex.zip Best Regards, Thorsten." But I still think my faders have a physical problem at the ends of their travel
Steven_C Posted June 1, 2003 Author Posted June 1, 2003 OK, for the benifit of those who have bought panasonics...the best setup so far....-6.5 volt motorfader voltage-0d  motorfader speed up/down-chunky cap (2200uF) across the 5v rails on adc input-another cap across supply for MF, after regulator-7 for adc deadband-3 for mf deadband-shorten all wires as much as possiblenow, there are no major errors anymore, when faders update, only small ones... say 0.4 db and once I had a midi value change from 100 to 95, but this size error is very occasional.<<<<<<update... bugger now they are bigger.... just ignore this post!!!>>>>>>>the faders hit pretty hard on their stops though, and there are still problems at the ends of travel... but this is only really a problem at the bottom... how often do you see volume faders at the top of their travel?? (except for panning hard right, or if you 'flip' to control other parameters with the Motorfaders)OK good luck, those using Panasonics, and if you discover improvements, please let us know!!BTW, if anyone is too scared to customise the settings to make a sysex file using MPLab and perl, I can help out. (for the first few times anyway)
TK. Posted June 1, 2003 Posted June 1, 2003 Hi Steven,the MF deadband value must be greater or equal the AIN deadband value, otherwise the motorfader driver tries to move the motors with a higher precision than the AIN driver can deliver the conversion values (=fader position), as an result you will notice those stuttering moves.I guess that all the caps between the AIN inputs and ground are not really required, especially high capacitance values can cause more problems than they should solve.More important is a good ground connection between the fader chasis, the Vss pin of the fader and the Vss pin of the core module.And (this is a new awareness) one 100nF cap across +5V and ground very near by the faders. I just have measured the signal quality of my MBLC with a scope and noticed some noise at the +5V input of the fader rail. Such noise is very common on a digital circuit and it can be eliminated by using small caps near by the drains. One cap should already be enough to fix this problem.See also the updated schematic:http://www.ucapps.de/mbhp/mbhp_mf_interconnections.pdfBest Regards, Thorsten.
Steven_C Posted June 1, 2003 Author Posted June 1, 2003 Hey Thorsten, Thanks for the reply!I just did all those things, I removed the big cap, installed 100n, put a big thick ground wire to the ground of faders, deadband mf...8 adc....7, earthed my fader chassis,(previously I insulated them, wierd, but it got much less jitter... my electrical engineer friend said maybe it was a problem of Al panel, Steel faderdodies=mini battery) checked the panel earth, and now it is worse than it ever was :'(So, I think I'll pay an electrical engineer friend to fix it!! (I really wanna start to use this baby)thanks for all your help, it is much appreciatedbye, from Steve
Steven_C Posted June 1, 2003 Author Posted June 1, 2003 Hi everyone, Look, all my 'boxes seem to have jitter problems. This jitter seems to come and go. It must be something to do with my local environment, as why dosen't anyone else have such problems... maybe it's something unexpected, like the brand of solder I'm using or maybe some of the components are not up to scratch. LO's panasonics work ok... and I've set mine to 7 bit resolution too, yet still no joy.SORRY TO DISCOURAGE ANYONE.....Sorry I've been posting over and over again... the same crap everytime... I'm too impatient.... anyway I'm going to lie low for a bit... let yourselves be encouraged by those who have had some success!BTW... I changed both the adc and mf deadbands to 5, and it was improved.......Steve
LO Posted June 2, 2003 Posted June 2, 2003 What's wrong with you clowns? ;)Mine work real nice!PIC16F stays where it is for now I think after reading all the above probsSorry I know that post didnt help no-one
pilo Posted June 9, 2003 Posted June 9, 2003 huumm.. I'm going to go with the MF, but I haven't buy any MF yet... I'm a little scared by your experience Steve.. :-/The panasonic are cheap... I planed to use them...Well, it's maybe just a ground problem, but I didn't understand everything because I can't play with!Can it be a problem due to the PIC18F?????
Steven_C Posted June 9, 2003 Author Posted June 9, 2003 I'm a little reluctant to try the pic 16f877, as I don't think it runs the LC emu, but I would give it a go if someone can email me a logic environment just to test it out? (not ready to get into that environment just yet!)still havin probs... but it is usable...maybe I'm a bit too fussy. I get errors... approxiamately 2-3 over 50 faderbank switching cycles e.g. 22 midi volume becomes 23, and audio volume -47db may fluctuate between -50, and -43dB.... Can someone with a bit of mixing experience on the LC tell me if this is worth worrying about??please answer me, so I can get some sleep at nights ;) instead of thinking for solutions...he he!I'll try to get someone with a cro to look at it soon....Steveedit... I'll try putting some ferrite suppressor beads on the ain input leads, and the power lead tomorrow, when I go to Jaycar. (Handy, it is across the road from college! I sneak over there when the teacher is not looking sometimes!!! ;D)
Steven_C Posted June 10, 2003 Author Posted June 10, 2003 ok, something else is wrong as well.... I tried all those things. Does anyone know how many times you can write the application over sysex, before you 'wear out' the PIC?
pilo Posted June 10, 2003 Posted June 10, 2003 hheeeuuu it's an EEPROM? so as many as we want??? I think about a thousand if not...
Steven_C Posted June 10, 2003 Author Posted June 10, 2003 hmmm... I think I must be getting close to 1000!(changing settings all the time!)does anyone know how to put a small delay in the program, to make the midi handler wait a little bit between sending a pitchbend (volume) message and the point in time where the fader has reached its last moved position?(my faders are sending midi before they have reached their last movement position)... or is the motordriver moving them after they have finalised their correct position???....Steve
TK. Posted June 16, 2003 Posted June 16, 2003 Hi Steve,this delay is already available: the MF driver doesn't trigger events for about 50 ms after the fader has been moved. The only case where events are sent is, when the fader didn't reach the target position. Ok, I will think about some new analysis applications which will help to narrow down the root cause. For example a "jitter monitor" which visualize the signal noise. Please hold the line ;-)Best Regards, Thorsten.P.S.: programming the flash more than 1000 times is no issue, I assume that most PICs can be burned more than 100k times without problems
TK. Posted June 16, 2003 Posted June 16, 2003 Hi Steve,I've just programmed the "jitter monitor" which allows to measure the signal noise. It would be an important input for me how much noise influence the AIN results of your MIDIbox. Could you please check this?The application can be found under Concepts->MIOS->DownloadBest Regards, Thorsten.
Steven_C Posted June 17, 2003 Author Posted June 17, 2003 Hey TK, thanks for the reply! I have since increased my power supply capacity, and noticed slight improvemens in jitter factor. My 'box is now good enough to use without worrying about my mixes getting messed up! Though I look forward to such features ahead in the future!BTW, even though it goes against logical thought, I still feel my 'box goes better when I set MF deadband lower than AIN value, I do AB tests, to check which value works better, before settling on a value. But I'll be trying Alps faders soon, if Rowan in NZ can hook me up with a good deal!! (LO will probably remind me of how well his panasonics go again now!) bye, from Steve ;DP.S. Hey TK, I am so happy now that I have a great system jto work with, instead of the mouse!! I'll post you a pic soon. (gotta borrow a proper camera, my digital keyring camera is bad!)
Steven_C Posted June 19, 2003 Author Posted June 19, 2003 Hey TK, man you are so qwuick!BTW... your post above my last one in this thread wasn't visible to me until today... wierd! I uploaded your new jitter monitor, and there seems to be no jitter at all, when the faders are stationary, which is kinda wierd. hmmmbye, from Steve(you seem to place your posts in stealth mode these days)
Steven_C Posted June 19, 2003 Author Posted June 19, 2003 This is what seems to happen during use...I switch fader sets, the faders move to their new positon, however, they move to within about 3-4 mm of where they should stop. (total range of about 6-8 mm) then, shortly after, (usually within a second) the value changes on the computer screen by even up to 6 midi values sometimes!. This really sounds like a jitter problem, but I can't see how, as the deadband is 5 for both motor and ain (I changed it back to what you suggest) Judging by your jitter monitor, I am not getting enough jitter for this to happen... ??? oh well.... I still think this controller is cool though! ;)bye, from Steve
TK. Posted June 19, 2003 Posted June 19, 2003 Stealth mode? Hm.... maybe too much coffee ;-)The results given by the monitor are showing that you've no jitter on the AIN lines, this is very good! This means also that you can decrease the AIN deadband to 1, and the MF deadband to 3 or higher (but I think that you've already tried this). But it makes sense to use these settings and to vary only the motorfader voltage AND the calibration value (motor speed) for upward and downward movements.Maybe I should integrate the calibration feature also into  the LC application so that you are able to start some experiments with the settings without reburning the PIC.Best Regards, Thorsten.P.S.: the described effect (fader stops ca. 4 mm beside of the target position) means that the faders are too fast, so that they never reach the exact position. A timeout will happen after 5 retries, thereafter the MF driver will send the "real" position. You can slow down the fader with a lower MF module voltage and with the Up/Down calibration value.
Steven_C Posted June 19, 2003 Author Posted June 19, 2003 Hmmm... I'll take a deep breath and try some new settings (again!) but I might wait until tomorrow. (have to open the case again!) I have been keeping the voltage high, as I think sometimes when the faders have to move only a little, they don't have enough torque to move, and instead they just stay where they are, and this is what logic thinks the new position... but don't believe that for now, I'll try changing the voltage soon. (I just tried MF dBand 5, ain 3, as well as mf 3 and ain1, like you suggested, but .....
Steven_C Posted June 19, 2003 Author Posted June 19, 2003 could I try putting some caps in somewhere to suppress the PWM control of the motors, in case it is leaking into ain? or is that a waste of time?btw too much coffee... me or you? ;)
Steven_C Posted June 19, 2003 Author Posted June 19, 2003 after another hour of tweaking, I think that these faders don't have enough startup torque... only solution I can think of is re-winding the motors, considering I have 8 spare damaged faders, this might be worth trying... but the ends of the armature turnings are probably spot welded on though. And the motors will probably need more current if they are modified... anyone have any suggestions?
TK. Posted June 19, 2003 Posted June 19, 2003 Thats a very interesting input! It makes sense to increase the PWM voltage level for the first miliseconds when the fader starts to move. I will try this on the driver sideBest Regards, Thorsten.
TK. Posted June 19, 2003 Posted June 19, 2003 Update: I just have integrated a new function into MIOS which allows to set the "startup speed". Just another value which can be tweaked ;-) Resulting from this possibility, the Up/Down speed can now be decreased to 0x03 (before the change it was 0x10). The Faders are starting faster now, but they are reaching the target position more smoothly. Now I will integrate a calibration menu into the LC application so that the values can be optimized in direct interaction with the host software. :)Best Regards, Thorsten.
