sparx Posted February 25, 2008 Posted February 25, 2008 OK, have managed to get my 6582 up and running, I can hear the formatting sounds when I add a new bankstick chip and at switch on.BUT how do I change, from the control surface, the MIDI channel that the SID responds to?On the LCD it says 16 and I need to change it to 1.Have had a tweek, looked in the manual and searched the forum but can't find it, so can anyone help?Thanks and regardsSparx
nILS Posted February 26, 2008 Posted February 26, 2008 http://www.ucapps.de/index.html?page=midibox_sid_manual_up.html1) Press the left-most menu button2) Press the menu button under INS3) Press the menu button under Chn3) Use menu encoder to set channel4) Done.
sparx Posted February 26, 2008 Author Posted February 26, 2008 Thanks Guru Nilshttp://www.ucapps.de/index.html?page=midibox_sid_manual_up.html4) Done.Yes, I found that in the manual, but the option to change any channel isn't there.So, not done :'(Anyone else experience this or offer any help?Thanks and regardsSparx
nILS Posted February 26, 2008 Posted February 26, 2008 Not there? If that's really the case then the mb6582 firmware is really different - so I assume it would be faster for someone who's got an mb6582 than for me to dig through the source.Anyways - I'm curious now: 1) Does pressing the left-most/first menu button get you to the "Ensemble" menu?2) If so, what are the menu items you can select there? I don't see any changes to the menu structures for the mb6582.
sparx Posted March 2, 2008 Author Posted March 2, 2008 ThanksYes, pressing the left most menu button does get into the ensemble menu and I have the option of INS. Selecting this I get:Osc, Wav, S/R, Del,Atk,Dec,Sus,Rel,PRn,Trn,Fin,Por,Phs,PW,GSA,DetNo option, so it seems to chnage the MIDI channel.Anyone?RegardsSparx
nILS Posted March 2, 2008 Posted March 2, 2008 How did you end up in the OSCillator menu? What you describe is that opening the ENSemble -> INStrument menu brings you to the OSCillator menu page, which is weird.Again in the root menu, the one that reads sth like E002|A001 Ld Chn. 11***|Lead Patch[/code]press the menu buttons 1, 4, 3.
sparx Posted March 2, 2008 Author Posted March 2, 2008 How did you end up in the OSCillator menu?pressing the left most menu button does get into the ensemble menu and I have the option of INS. Selecting this I get:I can only report what I am seeing!I think there is a problem with this button as if I move the display so INS is in another position I can change now change the MIDI channel, so looks like I have found the cause of this if not the cure which I suspect is the cable linking the 2 boards. Will check laterThanks for your help, you truly are a MIDIBox Guru now Nils. How is the pokey board coming along?RegardsSparx
