Okay, so my CS is working, but it goes crazy when I turn my encoder. I have a a Bourns encoder (PEC11-4220F-S0012) which is a 24 DET encoder. I'd like to change the encoder type but I cannot find the option at all in the FM source code. Where is it located? I grep'ed the whole folder and all I could find was some reference in "mios.h" which seems to be more of a decoding of what the options mean in a hex value.
;; used by MIOS_ENC_PIN_TABLE
MIOS_ENC_MODE_NON_DETENTED EQU 0x00
MIOS_ENC_MODE_DETENTED EQU 0x80
MIOS_ENC_MODE_DETENTED1 EQU 0x80
MIOS_ENC_MODE_DETENTED2 EQU 0x81
MIOS_ENC_MODE_DETENTED3 EQU 0x82
Further searching does not reveal any other reference to "MIOS_ENC_PIN_TABLE"
See readme.txt that comes with the .zip file:
Infos for customization:
  o some general settings can be found in the "Control surface settings" section
    of the setup_mbfm_v1.asm file
And in the setup_mbfm_v2.asm file around line 60 you'll find:
MIOS_ENC_PIN_TABLE
;; encoders 1-16
;;        SR  Pin  Mode
#if CS_MENU_USE_INCDEC_BUTTONS
ENC_EOT
#else
ENC_ENTRY  1,  0,  MIOS_ENC_MODE_DETENTED2 ; menu encoder
#endif
;; additional CS encoders
;;        SR  Pin  Mode
ENC_ENTRY  3,  2,  MIOS_ENC_MODE_DETENTED2 ; Multipurpose Enc #1
ENC_ENTRY  3,  4,  MIOS_ENC_MODE_DETENTED2 ; Multipurpose Enc #2
ENC_ENTRY  3,  6,  MIOS_ENC_MODE_DETENTED2 ; Multipurpose Enc #3
ENC_ENTRY  4,  0,  MIOS_ENC_MODE_DETENTED2 ; Multipurpose Enc #4[/code]
Read. Then: Read more.
End of  setup_mbfm_v1.asm
P.S.: README.txt of the current MBFM release is confusing, it contains some artifacts from the previous "flat" project structure - sorry about that! I already corrected this in the development version.
Thanks both of you.
I certainly came across several references to files that did not exist in my search, but I should have seen them in the asm anyhow. Many thanks.
