hi at the moment im working on my DIN module and i cant get it to work properly. im using a 16 input din. i tried using one push button and it worked, but its not displaying the note on the LCD...wat can be the problem?
and do i need to modify any part of the program?
10x
1) "16 input din" = DINx2?
2) Where's the board from? (diy, mike, smash...)
3) What application do you have installed?
Helping is kinda hard if we don't know what we're trying to help you with. ;)
but once i push the button it starts to send lots of random messages
with AIN connected or without AIN?
If it is without AIN Connected you'll have to ground J5.
ok. When you press a button, you'll get a (Note-On?) message.
What are the following messages. The same?
The only advice from now is to check and doubleckeck your soldering and wiring...
greets
Doc
Oh, you PCB looks really nice  :D You are aware you'll now have to answer some question about how you DIY'd it, right?
